Old 07-22-2011, 05:05 PM   #1
ibmenace's Avatar
Trader Rating: 39 (100%+)
Default charging 12volt start box battery???
I have not used a start box for a while and when i did i charged my battery with a car battery charger. I just got a new box and a 12 volt 7 amp battery. The box has everything wired to charge off the charge jacks. I do have a multi charger and the leads to plug in the front of the box or i have a large white plug that will plug into the bottom of the box. But if i plug into the bottom they're is two of the white plugs where the motor and battery are ran together i guess you would say in series. Which is best to charge from and if using my multi charger what setting would i charge a 12 volt 7 amp battery at?
ibmenace is offline   Reply With Quote
Old 07-22-2011, 05:08 PM   #2
Suspended
Trader Rating: 202 (96%+)
good question, i use to just use a car charger also. but switched to lipo.
D8 "HARA", OS SPEED, ,SAVOX 1267/68 SERVOS, BYRONS 25%, SPEKTRUM DX3R PRO
D8T GO GXII ,SAVOX 1267/68 SERVOS, BYRONS 25%, SPEKTRUM DX3R PRO
NMRCC -(northern michigan rc club)
inferno13 is offline   Reply With Quote
Old 07-22-2011, 06:45 PM   #3
ibmenace's Avatar
Yeah i can see me switching it to lipo soon also. Dang battery is to heavy!
Nobody???
Old 07-22-2011, 06:54 PM   #4
BradS's Avatar
Nobody???
Does it really matter if it is heavy? I saw two lipos catch fire last weekend. Unfortunately you need to use them in the electric cars to be competitive, but why risk it for a starter box.
BradS is offline   Reply With Quote
Old 07-22-2011, 07:10 PM   #5
cordarrow's Avatar
Trader Rating: 17 (100%+)
1 amp or less through the charge jacks. If your charger doesn't have a lead acid circuit...get a wall charger.
It needs a very low, long charge.
cordarrow is offline   Reply With Quote
Old 07-22-2011, 08:43 PM   #6
ibmenace's Avatar
I would not have thought it would take such a low charge rate considering the size of the battery. Here is what it says in my manual.
pb- [ lead acid ] max. charge voltage; 2.4v/cell
allowable fast charge current; 0.4c or less
minimum charge voltage cutoff level; 1.75v/cell or higher
I am not sure how to interpret this. And if i do charge though the front jacks, what would the connection plugs on the bottom be useful for?
The battery is a torqmaster hcap0800.If anyone has charger they're battery using a lipo/nimh/nicd/pb and recall what setting you used please hook me up. Thanks.
Old 07-22-2011, 09:22 PM   #7
Trader Rating: 30 (100%+)
Put it on pb setting smf charge at 2.5
jewn_beef is offline   Reply With Quote
Old 07-22-2011, 09:27 PM   #8
Suspended
lipo is the best thing for any starter box! you run them in 500.00 to 1000.00 cars why worry about a 50.00 to 80.00 starter box? ive never seen one catch fire in a starter box, but have seen many melted 1000.00 buggies and truggies
Old 07-22-2011, 09:37 PM   #9
Trugsta's Avatar
Send a message via MSN to Trugsta
Ive been running 3600 wolfpacks in one box and Venom 3000's in my other one.
is there anything I need to do to run lipos or just plug em in and go.?.
Starter box 1.is a Losi Truggy box.
starter box 2. is a Q-world 3 way box,
If that helps any.?.
Proud Member of S.C.O.R.C.
Losi 8T2- Novarossi P5/Novarossi and GRP pipes.
spektrum DX3S. SAVOX servos. "Race till it MHZ"
A huge thanks to.
www.motorsaver.com (the absolute best filters and savers on the plannet).
Trugsta is offline   Reply With Quote
Old 07-22-2011, 09:40 PM   #10
Suspended
just switch to a high current plug like deans or even a traxxas plug, the tamiya plugs will get hot and melt.
Old 07-22-2011, 10:31 PM   #11
you charge this battery at 1/10 the amp hour of the battery. Charge it at 0.7 amps this is the normal way to charge this battery.
TEAM BFL Banned for life
Sparky4u is offline   Reply With Quote
Old 07-22-2011, 10:46 PM   #12
Trugsta's Avatar
Thanks Inferno13.
I didnt mean to hijack the thread Just thought it was the apropriate place to ask..
A huge thanks to.
Old 07-23-2011, 02:58 AM   #13
Uga
Uga's Avatar
I am charging my 7A PB battery on iCharger with following settings:
cutoff voltage: 2.5V
charge current: 3-4A
with standart voltage setting at 2.4v it never seems to fully charge the battery, with 2.5v I can get all & amps into the battery. Battery is not getting warm or anything, I've been running the same battery for 2 seasons now and it's still good. Going to switch to LiPo anyway..
-=Xray XB4=-
-=Xray XB8E=-
-=Schumacher Cougar KF2=-
-=Awesomatix A800X=-
Racing in Latvia
Uga is offline   Reply With Quote
Leaving RC cars.. huge sell!!! NOTFASTENOUGH R/C Items: For Sale/Trade 19 09-18-2003 09:47 PM
Rivergate 45 amp Power Supply, Raytek Temp Probe. Novak XXL FM Receiver, Starter-Box racer rich R/C Items: For Sale/Trade 28 10-27-2002 10:04 AM
