Old 07-19-2011, 09:53 PM   #1
TX_Punisher's Avatar
Default Pre 2011 XRAY diff bevel and satellite gear lifespan?
Mine started making some noise the other day which led me to wonder, how long are other guys getting out of their satellite gears? (or how many gallons perhaps)
How often are you pre 2011 XB808 owners changing diff fluids?
XRAY XB9 & XT8 ☆ Airtronics M11X ☆ Novarossi Powered☆ Werks Fuels ☆ Hitec
TX_Punisher is offline   Reply With Quote
Old 07-19-2011, 10:57 PM   #2
Cade's Avatar
I usually change them after 2 races. Maybe after 1 race sometimes, not that I need to. I just like to
Cade "Young Gun" Whitenton
Thanks to all of my sponsors!
RCAmerica | Xray | FX Engines | Hudy | Pro-Line Racing | Airtronics l Avid Bearings | Powermaster Racing Fuels | StickIt1 Racing | Red Rock Hobbies | BUKU |
Cade is offline   Reply With Quote
Old 07-20-2011, 09:00 PM   #3
rfleck's Avatar
Trader Rating: 58 (100%+)
The gears inside the diff would normally outlast the chassis and rest of the car.
One big race a a couple of clubs races then you should probably change fluid.
Ron Fleck Jr.
Nemoracing USA!
Agama-Beta-Bullitt!
rfleck is offline   Reply With Quote
Old 07-20-2011, 09:13 PM   #4
Well that's interesting. Since this is my first XRAY maybe you can answer this:
With the diffs apart and dry and with the four satellite gears in place inside the case, if I place slight pressure on the top of the pins while spinning the coupling, should there be any noise? I'm getting a clicking sound both wet and dry when I do this and was told there should be no noise at all.
Hopefully that makes sense.
Old 07-20-2011, 09:24 PM   #5
And to be more specific, I'm talking about the smaller side gears, or spyder gears, as some would call them.
Old 07-21-2011, 01:21 AM   #6
That's entirely normal, the clicking sound is caused by the gears engaging eash other. However just make sure you have the 964030 3.5x12x0.2 shim behind the satellite gear as mentioned in the manual page 7 & 9.
Powered by: MASTERCARD and VISA
If you're in control, you're not driving it fast enough!
XRAY / NOVAROSSI / SANWA / AKA TIRES / BYRON FUEL
ganymede is offline   Reply With Quote
Old 07-21-2011, 12:05 PM   #7
Damn. Hope I didn't just order a complete set of gears for nothing then.
