Old 07-18-2011, 10:24 AM   #1
Trader Rating: 26 (100%+)
Default can't get tires to balance
I am trying to balance a set of truggy Bowties on a set of JConcepts wheels the foams I got in them are the newer ribbed ones that are grey. No matter what I do I cannot get them to balance.
These are brand new wheels and foams. Any tricks u guys can share?
☆ Losi 8T 2.0 ☆ OS Engines ☆ VP PowerMaster ☆ AKA ☆ HiTech ☆ F-Bomb Graphix ☆
555 Raceway, Bartow FL - http://www.facebook.com/555Raceway - Be a part of the rebirth!
SDelaney is offline   Reply With Quote
Old 07-18-2011, 10:30 AM   #2
rider313's Avatar
Trader Rating: 94 (100%+)
PL foams that came with the tires? If so you will have to add a whole stick of clay to balance em and they will still be off. Just get em as close as you can and call it good.
Dan Williams
MNRC Chairman
---Xray, RC America, Pro-Line Racing, FX Royal, Hudy, KO Propo, 92zero Designs, Vision Racing Products, RW-Mods, Team Loosenuts, forddesigns.net--- Big Thanks to: Wheel Brokers Track and Shop, Pine City MN~ "Stompy"
rider313 is offline   Reply With Quote
Old 07-18-2011, 01:44 PM   #3
The foams came with a set of hole shots I got. Like i said, they are new though if the PL foams are no good what foams should i switch to?
Old 07-18-2011, 02:50 PM   #4
cordarrow's Avatar
Trader Rating: 17 (100%+)
A typical tire balancing mistake is to weight the wheel on the outside.(near the wall & ribs)
It will check balanced, but rotational forces will still throw the wheel out...where it flexes, the open side of the wheel.
The problem is find something that will stay in this area...and keeping the weight out of harms way...there's very little clearance at full turn.
Get it as close as possible to the open side...and hope it stays there. I glue it on...but the balance always seems to change. I've usually worn the treads out before I need to mess with it.
cordarrow is offline   Reply With Quote
T.R.C.R. ---Pit's Talk--- teambighead Northwest Racers 25139 07-11-2017 03:31 PM
T.O.P. Racing "Photon" 1/10 EP Touring Car keithander Electric On-Road 9064 06-14-2017 12:46 PM
ROAR... can we get a rule change? Trips Electric On-Road 32 12-24-2008 05:01 PM
