losi 1/8 shock problems
#31
I had the same problem and what I did was to get a 2-56 set screw and put in the shock shaft first then you have to cut down the piston screw a little and drill out the hole in the piston that the screw go's in so the piston rotates on the shaft when the screw is bottomed out on the set screw ,use the set screw to adjust the piston so it rotates on the shaft ! result is the piston will spin on the shaft with out backing the screw out of the piston ..
#32
#35
I do not understand what a number is going to tell me about my droop, I can say without an issue that my droop is set to limit my down travel before my shock bottoms out, I dont need a number to tell me this. Currently my arms are set to the point that they do not even sit level with the chassis they slop up, so I have negative droop trying to keep the shocks from pulling apart. so too much droop is not the issue.
#36
1. bad threads screw/shaft ... you took care of this with a new shaft and screw
2. wrong shaft.... what is this for, buggy or truggy, 1.0 2.0 front, rear ????
3. no loctite on the screw ... you say you took care of this with applying locite
4. too much droop ... you dont know your measurement, you CANT say 100% this is not your issue. buy or borrow calibers or a ruler with MM listed.
it only can be one of these things, your either not tightening the screw enough, wrong shaft, not putting loctite on or filling up the shock to soon or to much droop. What are your shock location also?
#37
imo droop has nothing to do with the shock piston screw coming loose ! It's the vibration from the engine and drive train that makes them come loose! with my method the piston screw bottoms out on the set screw and the piston will spin freely . myself and a few others that I have shown have been doing this mod for years and have never had one loosen up yet ! you don't even need lock tight ! (just saying )
#39
If using the same brand of thread-lock for all failures, have you considered changing brand? Maybe to one from Locktite or Permatex? And then alt least for this application, preferably one of the permanent types.
#40
#41
I saw someone else mention it before, and I may not be sharp enough to see that you already said you do it this way BUT...
Do you send that little screw thru the shock piston first, then apply the thread lock, then screw it into the shock shaft? I had this happen once when I was putting the loctite on the screw then screwing it thru the piston and the shaft at the same time. This left all loctite in the plastic piston and none in the threads of the screw. After putting the piston on the screw first I have never had this happen again.
#43
Shocks
Jason....I have an extra set of shocks for a losi that I have run and never had that problem at all... I will give them to you at the next race to run and this way can see if its your setup or those shocks that you have now.....If they pull out or bend it doesnt matter since I dont run losi any more.
#44
#45
A bad engine bearing that buzz's when you rev it up will cause this as well ,,
just for kicks try this put a un-lock nut and a washer on say the top shock mount ,leave it loose ,start up your engine and watch what happens to the nut when you rev up to 30k rpms.
