Old 07-11-2011, 12:08 PM   #16
tq_racing's Avatar
Trader Rating: 65 (97%+)
Send a message via AIM to tq_racing Send a message via Skype™ to tq_racing
brother tried the limiter and it still did. think i might buy some new shocks and try from there
Jason Littlejohn
JL GRAPHICS for all your paint & vinyl needs!!
www.facebook.com/jl.graphics1
tq_racing is offline   Reply With Quote
Old 07-11-2011, 12:14 PM   #17
scwrod's Avatar
Well, the way I see it the screw is being pulled out or the piston is rotating and backing the screw out.
Good Luck.
hbracing.com tritonrc.com raceaka.com
scwrod is offline   Reply With Quote
Old 07-11-2011, 12:22 PM   #18
wiggit's Avatar
I also havent heard of this problem or experienced it either.
Finger is pointing to over extending the shock shaft and pressure is on piston and screw.This wont last long like this loctite or not.Build the shocks again reset droop to say 94.5(just try shorter amount) do a test run.It its fine then its over drooping the shocks in your current set up.
You may also be over tighting the screw due to current shock blow out and maybe stripping them now.I also use red locktite that comes with kit.Dab in the shaft and on screw after piston is on tighten and let set over night but have also used rite away.
How are you measuring your droop?
Good luck
Proudly Supported By:
TRL,Nitrotane,Spektrum,Xcelorin
Fastlane Graphix
Dado
wiggit is offline   Reply With Quote
Old 07-11-2011, 01:15 PM   #19
Stanton's Avatar
Put the screw all the way through the shock piston and then put some new red Locktight on the threads. Wipe it off and use a rag to clean it. Re-apply red Locktight. Make sure to wipe off any excess and just leave a film on the threads. If you get liquid in the female shock-shaft threads, the screw will hydro-lock and feel like it is tight. Locktight is anaerobic and will not set unless threads are completely seated. It sounds like this is your problem.
Once you have this correct, tighten the screw with a good quality .050 Allen tip driver. You need a quality tool like MIP or Hudy, not a cheap L-key Allen wrench.
After you have the shock re-built and mounted, check and make sure the droop screw is limiting the A-arm travel and not the shock. Itís possible that your arms are warped and causing the shocks to limit your travel.
I canít think of any other reason your shocks would be coming apart.
Horizon Hobby/Spektrum/Byrons/TLR/Houstons Engine Service
Stanton is offline   Reply With Quote
Old 07-11-2011, 01:37 PM   #20
wiggit's Avatar
well i guess for all the guys out there like mike.....
Dont fill female part of shock shaft full of locktite lol
Hey how have you been?It has been a while.
j/k for mike
Fastlane Graphix
Dado
Old 07-25-2011, 01:14 PM   #21
Littlejohn Dsgn's Avatar
Trader Rating: 47 (98%+)
Thought I would chime in since I am the OP brother. The droop is set to allow about 3/16" of the shaft to be in the shock before the piston hits the bottom, I have tried putting fuel tubbing in to help as well. Bought new shafts and screws, lock tighted them in and let site for 36 hours before filling with oil.
At this point I am pricing out a different brand of shocks to replace the losi with, at this point I have tried everything, even switched pistons thinking that might be the issue.
Scott Littlejohn - Owner of Littlejohn Design
Fleet - FT B4.1(FS) - FT T4.1(FS) - Emaxx - Micro T's (4)
Littlejohn Dsgn is offline   Reply With Quote
Old 07-25-2011, 01:19 PM   #22
808gx7r's Avatar
i had this same problem when i ran a 2.0B. ruined my bladders everytime. however... one i loctighted them and stoped cartwheeling on the track i never had the problem again.
Mugen Mbx6t / O.S SPEED / Byrons / Savox servos / Futaba
Agama A8 Evo / O.S SPEED / savox / futaba
Hpi Blitz/sc10 CASTLE CREATIONS.
Driving the best quality cars in the market.
808gx7r is offline   Reply With Quote
Old 07-25-2011, 01:32 PM   #23
Yup tried the locktight, even tried the no cartwheeling thing (to some sucess too ) never had my bladders ruined though.
Old 07-25-2011, 01:40 PM   #24
8T
8T's Avatar
We've been running Losi 8's and 8T's since they came out. Never had this problem, nor seen it happen! Do as others have mentioned and use red loctite after cleaning the screws and shafts with contact or brake cleaner. Do not put anything on the shaft between the piston and the shock body. There should be no type of limiter in there. Set the droop like mentioned above and you should have no problems. Also, ask someone with a Losi at your local track to have a look see, they may be able to help!
8T is offline   Reply With Quote
Old 07-25-2011, 01:41 PM   #25
808gx7r's Avatar
if you have new shock rods and screws the only way they should come out is if they are continously hitting the bottom of the shock body... does the losi shocks run a shim under the piston??? when i run without one on my mp9 they come loose. with its fine.
Old 07-25-2011, 01:57 PM   #26
We have done as others mentioned with the locktight after cleaning with break cleaner and letting dry over night, also have tried with and without limiting with fuel tubbing. Droop has been set and reset by multipule people at the track who have tried to help us with this issue to no avail.
Old 07-25-2011, 02:02 PM   #27
808gx7r's Avatar
seriously here. if its becoming a pain.. slab a bunch of lictight down there (make sure it is not moist (so cleaned properly)) then put it together, torq the screw tight and let it sit for 24 hours.
if that comes out... YOU are doing something wrong somewhere
p.s if your using the wrong screws... then that could be your issue.(remembering losis arnt metric)
Old 07-25-2011, 02:09 PM   #28
losi_racer's Avatar
Trader Rating: 25 (100%+)
What's the droop .how are you setting the droop .
Byron Fuels/AKA Tires/Radiopost/TKO/Viper Rc/Dialed Inc/Empire Metal Product/Advantage Racing Products
losi_racer is offline   Reply With Quote
Old 07-25-2011, 02:21 PM   #29
I am using the scews that came with the new shafts, so I am assuming Losi would package the correct screw with the shaft.. Also I am putting a decent (not to much not to little) amount of locktight on them when screwing them in, getting them tight but not over tight to strip them out.
I do not have a droop quage to give an exact number, I put my chassis up on a block, and my arms are about level with the chassis with no shocks installed, fully extend the shocks next to the buggy and I have a good amount of extra down travel left in the shock, eye to eye is longer then monting point to mounting point.
What I do not understand is I have gottne new shafts, new screws, new pistons. Had several other people look things over (since this has happened at least half a dozen times already) and no one can figure it out. If its an uncommen issue then I guess my only option is to switch over to a different brand of shocks.
Old 07-25-2011, 02:30 PM   #30
808gx7r's Avatar
last thing to try is new shock bodies... as yours could have warped putting pressure on piston then when u land hard it puts xtreme pressure on the piston(pushing it up forces it to strip or start to unwind)
Losi 1/8 8ight E 4wd Thread tyhodge07 Electric Off-Road 8898 11-17-2015 05:31 PM
Losi 1/8 L8IGHT Model Race Roller Lars Johnson Oval, Larger Scales and More 23 09-04-2008 07:30 PM
New FWD only Tmaxx 3.3 VS Losi 1/8 Raminator (Lots of Pics) MattP Monster Trucks 17 07-29-2008 01:51 PM
