Old 07-07-2011, 02:47 PM   #1
Default Preparing 1/8 nitro for a muddy race
I'm attending a race this weekend. Unfortunately, the weather forecast is not too optimistic - most likely it will rain. The track is definitely not hard packed, rather loose dirt so I hope there won't be any pools.
I'm curious how do you guys prepare your buggys/truggys for muddy conditions.
1. Setup. What changes in comparison to standard setup?
- increase ride height
- IBeam/Bow-Tie type tires
- what about oils and other aspects i didn't mention?
I'm not experienced in terms of setup...
2. Engine tuning. Any differences in comparison to the 'normal' sunny day?
3. Chassis protection. What should i do to prevent any damages due to excessive amount of water/mud inside the car? For example I don't have water resistant servos, reciever. Any tips for that?
I have arm mud guards but I'm afraid it's the only protection at the moment.
Any input will be appreciated.
I've got only one day to prepare my Losi 8T1.0 so be quick!
Thanks,
Donat
Donat is offline   Reply With Quote
Old 07-07-2011, 02:51 PM   #2
808gx7r's Avatar
- IBeam/Bow Tie type tires
Thanks,
Donat
watch some of the videos from the 2008 worlds. they used thinner tyres etc
cody king had tape all over his car
Mugen Mbx6t / O.S SPEED / Byrons / Savox servos / Futaba
Agama A8 Evo / O.S SPEED / savox / futaba
Hpi Blitz/sc10 CASTLE CREATIONS.
Driving the best quality cars in the market.
808gx7r is offline   Reply With Quote
Old 07-07-2011, 03:23 PM   #3
RCmayor's Avatar
Send a message via Yahoo to RCmayor
I usually just pack my car up and call it a day. :-)
Hows that for preparation?
RCmayor is offline   Reply With Quote
Old 07-07-2011, 03:30 PM   #4
nitroexpress's Avatar
No matter what you do, you'll be carrying a load of mud around. Engine cooling fins will clog. In these types of mud races, engines tend to blow from overloading and undercooling.
I'd call it a day and become a spectator.
nitroexpress is offline   Reply With Quote
Old 07-07-2011, 03:35 PM   #5
Team Tekin
yzracer758's Avatar
Trader Rating: 17 (100%+)
Run your practice buggy.
-Get a can of Maxima SC1 and coat your buggy in it right before you hit the track.
-Tall Lugs that are spaced far apart
-Toilet paper/Paper towel inside your receiver box to soak up any water/moisture.
-Duct Tape body to chassis if possible
-Dont over drive the track, stay smooth and roll a section of jumps if your not 100% confident your going to come out on your wheels. Corner marshals in the mud will take forever to get you.
Tekin, Inc. | XRAY | RC America | Hudy | Protek RC | Exotek Racing | Factory-RC Products | Proline Racing | Avid RC | Vision Racing Products | Paint By Smiley | SOR Graphics | Carolina Custom Anodizing
Jeremy Potter
Tekin C.S. Manager
yzracer758 is offline   Reply With Quote
Old 07-07-2011, 03:36 PM   #6
RCmayor's Avatar
But in reality these are the things I have seen done. Some are more important for a long main when mud buildup gets worse and worse.
  • Use small pin tires, no big lugs. Our tires don’t spin fast enough to “clean out” like on real trucks.
  • I have seen rain tires made with no foam in them so they balloon up and throw the mud off, again small pin tires.
  • Duct Tape flaps over the flywheel hole and spur gear hole covered. The flap for the flywheel is made so the sticky side is folded over. When starting the pit guy folds the flap forward and then it naturally flaps back to cover the hole.
  • If it is a really long main use a second old body over your main body, at about the 1/2 way point the pit guy will tear off the outer shell. Duct tape the first inner body to the mud guards.
  • No wing, mud just builds up on it.
  • Maybe richen the top end a couple hours. The engine is gonna be working hard pulling the extra weight around, this will keep it cool.
  • Fresh clutch and bearings. You don’t want to go out on a long main with worn out clutch and bearings. This part of the car will be getting extra hot.
  • Most servos are water resistant even though they don’t say anything about it. Especially the ones you should be using in a race car.
  • Might want to use an air filter made for rain. Usually no foam is exposed on these, it is just a plastic shell with the foam inside.
Old 07-07-2011, 06:52 PM   #7
rider313's Avatar
Trader Rating: 94 (100%+)
I actully find that a sniper or grid iron in super soft works best in wet conditions. They don't load up and over heat the clutch and motor. Yet they still yeild awesome traction.
Set your tune a hour or so rich. The excess mud will really cause you mill to heat up and towards the end of a run will start to lean out.
I liberally spray the whole underside of the car with WD40 and the mud falls right off and repells most of the water.
This OS what I did last time rain came in as a factor.
Dan Williams
MNRC Chairman
---Xray, RC America, Pro-Line Racing, FX Royal, Hudy, KO Propo, 92zero Designs, Vision Racing Products, RW-Mods, Team Loosenuts, forddesigns.net--- Big Thanks to: Wheel Brokers Track and Shop, Pine City MN~ "Stompy"
rider313 is offline   Reply With Quote
Old 07-07-2011, 06:52 PM   #8
rider313's Avatar
Poop double post.
Dan Williams
MNRC Chairman
Old 07-07-2011, 07:48 PM   #9
jammin32j's Avatar
I have also seen people use Pledge on their cars to help the mud not to stick. If you are running Truggy I have seen people put a buggy body on first and then the truggy body to help keep the mud off. Most of all run your mill rich. Another thing you can do to help save your servos is pack grease around the output shaft to help keep water from getting in.
VP Pro, Agama
Hitec-7955's, 3Pk----AKA Racing Tires
Absolutehobbyz.com____Dirtrc.com
O'Donnell, D.I.R.T. R/C ultimate Tire Gluer
Jeremy Davis
jammin32j is offline   Reply With Quote
Old 07-07-2011, 07:56 PM   #10
Try to post some pictures of your adventure.
http://www.liverc.com/photos/albums/..._0590Friday/md
Old 07-08-2011, 03:32 AM   #11
After you get done running, might as well replace ALL of the bearings because they will have drawn moisture and will rust.
cbonner99 is offline   Reply With Quote
Old 07-08-2011, 05:13 AM   #12
Orion_2kTC's Avatar
During the JConcepts Spring nats in Omaha we had 2 days of raining. Many guys were duct taping the bottoms of their a-arms to block mud. A couple even wrapped and taped the whole arm/driveshaft/shock assembly area in plastic bags. The parts were still free to function. Also WD-40 was being sprayed everywhere else that was exposed.
One of my teammates duct taped an old body onto his electric then taped over each of the vent holes. He also taped the bottom of the chassis just so he didn't have to do any extra cleaning. He did the same for his nitro and both cars came out pristine compared to the rest of the cars.
Orion_2kTC is offline   Reply With Quote
Old 07-08-2011, 06:33 AM   #13
Thank you! Wow those are tips for severe conditions! I don't expect such a disaster!
If it's raining THAT hard I'm sure the race will be cancelled.
Unfortunately i don't have any small pin tires but i do have some shitty blocks (half way worn citys ). Will they be ok?
I didn't express clearly. I shouldn't use the word 'muddy'...
I'm not planning to destroy my truggy. I'm only trying to be prepared if it's wet or slightly raining. I'm sure none will be interrested in sailing.
Thanks again for the tips, but honestly I hope I won't have to use them!
Old 07-08-2011, 07:47 AM   #14
rider313's Avatar
Shitty blocks should do just fine.
Dan Williams
MNRC Chairman
Old 07-08-2011, 07:49 AM   #15
Trevor Williams's Avatar
Trader Rating: 195 (100%+)
unless there was something at stake, I would think about not running your car in those conditions.
RC10-B6d | RC10-B64d
SmacTrac
#WeAreAE #ReedyPower #AE4Life
Trevor Williams is offline   Reply With Quote
2010 TAS State Titles (1/8th Offroad) H9 Australian Events 163 01-03-2011 02:47 AM
