Old 07-05-2011, 11:09 PM   #1
Default Any tips on traction?
Was recently at the track after a very long break from r/c (about two years). I purchased a Losi 8B 2.0 and was trying it out for the first time, mainly working out a feel for things again. I noticed the rear end was a little loose and losing a lot of traction in the corners, on throttle. Tried a few different set ups without much success, I'm also running 3 degrees of tow in on the back. Any tips would be appreciated, maybe diff oil weights etc....
Lex7 is offline   Reply With Quote
Old 07-05-2011, 11:33 PM   #2
ohh EPiC FAiL's Avatar
Trader Rating: 51 (100%+)
start with your diff fluids 5k in front 7k in center and 3k in rear. that's a great starting point and works well on most tracks.
TEAM FEARLESS RACING
I Race: Losi 8ight-E 2.0
I Crawl: XR10(almost VP10)
I Support: Futaba--Holmes Hobbies--Savox--Castle Creations--Tekin
ohh EPiC FAiL is offline   Reply With Quote
Old 07-06-2011, 10:04 AM   #3
tires... its amazing how much effect tires have on the amount of traction you have.talk to people at your local track to find out what works there.
Track mngr SliverFox R/C Raceway
clay is for pottery dirt is for racing
Turn left to go right...
markkris is offline   Reply With Quote
Old 07-06-2011, 10:24 AM   #4
i also had a 8 2.0 and the same happen to me...
first take off the shocks and look for any suspension binding...
a 5k in the center make the car more forgive ( for me)
check if the rear is spins alot if so put 3 k oil in the rear diff
try 55 pistons in the rear with 30 oil ( that help alot)
depends on the track that you race but putting 14 clutchbell make the car more forgiven
try a softer clutch setup
segreda is offline   Reply With Quote
Old 07-06-2011, 10:31 AM   #5
Trevor Williams's Avatar
Trader Rating: 195 (100%+)
+1000
you will be chasing setup every single day if you arent using the right tread/compound....talk to the top 3 in the local pro class
RC10-B6d | RC10-B64d
SmacTrac
#WeAreAE #ReedyPower #AE4Life
Trevor Williams is offline   Reply With Quote
Old 07-06-2011, 10:41 AM   #6
Originally Posted by Trevor Williams View Post
+1000
+2000 I think tires are 90% of setup.
1airborne
serpent cobra 811TE, Cobra 811T,Serpent S411TE,rebel12 pan car, VPfuel, Buku clutches, Novi motors
1airborne is offline   Reply With Quote
Old 07-06-2011, 12:11 PM   #7
johnny t's Avatar
+1000. If you have a binding suspension any changes in setup are less effective if not moot. I know most use the, "if the suspension flops down on its own" standard to check for bind but that really is not good enough. the car finding traction is a very subtle high frequency event, so even the smallest of bind in the moving parts can break traction. I have helped alot of people at the track where their suspension readily drops under its own weight but was still incredibly sticky.
do the hingepins fall though the arms under thier own weight? even when dirty?
do the ball ends flop back and forth with no effort?
are the swaybays adjusted with some freeplay, or snugged down that they drag?
the more friction free you make the suspension the more traction you get. it can be as much a gain as going to a grippier tire.
johnny t is offline   Reply With Quote
Old 07-06-2011, 01:04 PM   #8
All very good suggestions, thank you very much. Let the quest begin, lol.
new to tracks any tips? AxBlunt-_FOrc3x Electric Off-Road 45 01-07-2011 08:48 PM
Tips on sanding Rubber touring tires for carpet Leester Electric On-Road 20 11-28-2004 03:09 AM
Any1 knows about the Hobao Hyper10 EP ?how was it?.good?.any tips and tricks? HyperSpeed Malaysian R/C Racers 151 12-03-2003 04:44 PM
