Old 07-05-2011, 03:12 PM   #1
8T
8T's Avatar
Default Losi brake disc issue
A couple of weeks ago i installed the updated losi brake discs on my 8T 2.0. Last Saturday my front brakes would not release when when i got back on the gas. I backed the caliper screws out so the fronts weren't working and the problem went away(a long with braking power!). Just took the center diff out and the front disc has what looks like 2 spots that are blistered/ delaminating! It looks like a bulge and material is missing in these 2 spots. Any clue to why this is happening?
tia
8T is offline   Reply With Quote
Old 07-05-2011, 04:09 PM   #2
Trugsta's Avatar
Send a message via MSN to Trugsta
Sounds to me like you may have got a faulty part.?.(happens sometimes)
I've never had or heard of this issue before with the losi break discs (the black ones) de-laminating.
So it might be an idea to contact losi or take them back to were you baught them from and show them. im sure you will get a replacement.
Proud Member of S.C.O.R.C.
Losi 8T2- Novarossi P5/Novarossi and GRP pipes.
spektrum DX3S. SAVOX servos. "Race till it MHZ"
A huge thanks to.
www.motorsaver.com (the absolute best filters and savers on the plannet).
Trugsta is offline   Reply With Quote
Old 07-05-2011, 06:33 PM   #3
Shane Racer's Avatar
Your brake caliber is sticking on the back side of the brake pad. Change the bads and I bet you problem will go away.
KYOSHO AMERICA-Novarossi-M2C racing-Competition Heat-Grandview Hobbies-Fastraxx Hobbies-TKO-Clockwork-The Ohio RC Factory
Shane Racer is offline   Reply With Quote
Old 07-05-2011, 06:44 PM   #4
JAMMINKRAZY's Avatar
Trader Rating: 17 (100%+)
Also make sure you adjust the gap in your pads correctly. The black discs will need a larger gap than the older fiber discs. The gap should be 8mm between the center diff mount and the head of the screw(not between the pads!).
-Koby Kubrin-
Thanks to my Sponsors:
Serpent America | Team Novarossi | Desoto Racing | Race AKA | Ridgeway Bodies
JAMMINKRAZY is offline   Reply With Quote
Old 07-05-2011, 06:54 PM   #5
8T
8T's Avatar
I changed the pads and screws when i put the new discs on. I also added .5mm to adjust for the thicker discs. Never seen anything like this! I'm going to replace everything and see what happens. What do you guy's think of pad return springs! I've seen the answer, ofna, pen springs, and the losi shock springs(xx4 i think)?
Old 07-05-2011, 06:58 PM   #6
Trader Rating: 46 (98%+)
i use the answer rc springs. they work great!! also check and make sure your brake acuator lever isn't worn down to far. i had mine wear out and the brakes would stick no mater what i did.
consistency will get you better results than speed, but if you have both-look out!!
Agama A215T
thanks to Tony Bacon, Dialed-rc hobbies, Nemoracingusa.com
nitroal is offline   Reply With Quote
Old 07-05-2011, 07:40 PM   #7
rider313's Avatar
Trader Rating: 94 (100%+)
Make sure the screws holding down the top plate aren't over tight causing binding to. Also the break cam can wear into the plate and cause it to stick.
Dan Williams
MNRC Chairman
---Xray, RC America, Pro-Line Racing, FX Royal, Hudy, KO Propo, 92zero Designs, Vision Racing Products, RW-Mods, Team Loosenuts, forddesigns.net--- Big Thanks to: Wheel Brokers Track and Shop, Pine City MN~ "Stompy"
rider313 is offline   Reply With Quote
Tekno Conversions Thread teknorc Electric Off-Road 10250 01-30-2017 01:30 PM
Adam Drake talks about the new 8ight 2.0 Sylvain Nitro Off-Road 545 05-30-2010 05:57 PM
losi brake disc set alexrckid Nitro Off-Road 20 03-05-2010 02:41 PM
*LOSI 8IGHT BUGGY FOR SALE WITH HOPUPS* MattP R/C Items: For Sale/Trade 19 08-30-2007 09:47 AM
