Old 07-05-2011, 09:37 AM   #1
RC Everything's Avatar
Red face Differential Gear Problem
Hi All
Please see attached image, what do you think that cause this to happened? This is the center differential of my Hyper 8 buggy. This gear is facing the rear differential. This is the second time it happened.
I have totally rebuild the center differential with all new parts after the first time it happen. And after just one run, the gear became like that. When the gear is in this state, since this gear is the one that facing the rear differential, the rear wheel will not move if I open the throttle. The front wheel is spinning but the rear wheel just don't move. By then, I know the gear is striped.
Since this is the second time it happened and I have used all new parts to rebuild, I am quite sure that the problem might not lay in the center differential itself. It might be something else that caused it. Can be the clutch bell, or others.
I am using 3-5-1 differential oil the first time and use 3-7-1 for the second time.
Anyone got this experience? Please share with me...
Thanks...
RC Everything is offline   Reply With Quote
Old 07-05-2011, 09:52 AM   #2
beidle99's Avatar
You may need some shims to space the gear closer to the small gears. Check your manual it may recommend 2 shims and if they are missing the gear may not be meshing properly.
beidle99 is offline   Reply With Quote
Old 07-05-2011, 10:44 AM   #3
Stubbs's Avatar
Trader Rating: 57 (100%+)
+1
There should be a small shim behind each of the 4 spider gears, and also a larger one behind each of the 2 side bevel gears. If those are missing, your mesh is too loose, which will cause the gears to slip.
Mike Stubblefield - www.capefearraceway.com
"If you're not racing to have fun, then you're doing it WRONG."
"All you need is WD-40 and Duct Tape. If it moves, and it shouldn't, use the Duct Tape. If it doesn't move, and it should, use the WD-40."
Stubbs is offline   Reply With Quote
Old 07-05-2011, 01:18 PM   #4
Check your diff case and make sure where the diff pins ride is not worn also.
** Scott's Hooker Service** Craftworld and Action Hobbies**Craco Cryogenics** Hotbodies D8T **Fusion X Engines** Byron Fuels ** Hitec Servos ** Spectrum **AKA Tires**
nothin special is offline   Reply With Quote
Old 07-06-2011, 05:57 AM   #5
Thank you all for the reply. All parts in the rebuild are new. Build according to manual too. Anyway, I will put in more shim to make it more secure.
"How To Properly Build And Break In a Ball Differential and Slipper Clutch" racer53 Electric Off-Road 396 06-11-2017 08:15 AM
SC10 which differential gear or ball??? cliffhanger Electric Off-Road 88 08-23-2014 02:46 PM
Spec-R Gear diff review P.I.M.P Electric On-Road 890 08-31-2013 04:16 AM
