Old 07-01-2011, 08:38 PM   #16
Trugsta's Avatar
Send a message via MSN to Trugsta
Originally Posted by SPARKY426 View Post
OK....took the head, carb and fuel tank off. Cleaned any excess fuel from inside the engine, and took the carb apart to check it. Put everything back together and then blew through the exhaust tube, draining any fuel from the tank. I had just picked up a quart of Traxxas 20% fuel, so I put a little in my filler bottle, shook it around and drained it. I then filled the tank 1/4 way, shook it a bit and blew the fuel through the tubing and dumped it. Mounted the tank, filled with fresh fuel, the fuel flowed better, and...BAM...the S.O.B. started !! Now, let's see what happens in the AM...LOL.
Thanks for all your help guys!!!!
Chris
P.S.....how would I use a hair dryer if I'm in the middle of a field?
Good stuff Glad you got it sorted..
to answer your question about the hair dryer I have a 12v attachment that plugs into the cigerette lighter in my car so I can take the heat gun anywere but my local track has power so its never a problem..
even If you heated the engine up and start it for a minute or so before you leave home then set your piston to bottom dead centre the engine should(providing you dont have to go too far). hold atleast alittle of the residual heat to make starting alittle easier..
Proud Member of S.C.O.R.C.
Losi 8T2- Novarossi P5/Novarossi and GRP pipes.
spektrum DX3S. SAVOX servos. "Race till it MHZ"
A huge thanks to.
www.motorsaver.com (the absolute best filters and savers on the plannet).
Trugsta is offline   Reply With Quote
New buyer needs help please A4life Rookie Zone 15 11-10-2010 06:19 AM
New guy needs help with charger tiko Rookie Zone 30 02-04-2009 07:22 PM
Ok, new guy new guy needs a monster truck dylan-d Monster Trucks 21 05-03-2004 08:45 AM
