what lipo for ofna truggy starter box?
I'm trying to decide on what lipo i should get for the ofna truggy starter box. it will be for a dnx408. How many cells and mah shall I get. I want good power from the starter box and i want it to last a LONG time! Im sure i have space in the starter box, so let me know what's a good size. Also, does it matter the 'C' rating of the lipo? Is 15C lipo packs okay?
thx
thx
As long as it's 4s and at least 20C, you'll be good.
I personally use this: http://www.amainhobbies.com/product_...Ah-Starter-Box
I own two of the very same lipo's and they work great.
That might work just fine, but is it worth the hassle?
Zippy 4S-HK USA $17.47
Turnigy 4S-HK USA $19.11
I am using this:
http://hobbyking.com/hobbyking/store...idProduct=8852
This will work too!
http://hobbyking.com/hobbyking/store...idProduct=8913
This will work too!
Sure loads of newly found "buddies" around you when you bring out that box...
To all those with the same setup, you WILL eventually have the same problem.
Theses starter boxes have little, flimsy contacts that, in stock form, handle ALL of the current the motors pull. Not quite the hot setup, IMO.
I had the same issue, so I made new contacts from copper(1/2" copper tube, smashed flat and cut/dremel'd to fit), but I still wasn't happy with the performance I was getting.
So I took it one step further and added a relay to handle the current.
This setup may be overkill, but it ALWAYS works and it's one less thing to worry about come race day.
And yes, it WILL start a Mack truck....
I like the idea of running a relay, is that an automotive relay? Any specific specs?
Any wiring diagram? Thanks!
