Old 06-30-2011, 07:18 PM   #1
Default jato 3.3 help
I have a jato 3.3 not sure. Its not pullin wheelies on low end it bogs alil on take off so it wont pull wheelies any ideas?
arcticcatracing is offline   Reply With Quote
Old 06-30-2011, 07:50 PM   #2
Trader Rating: 24 (100%+)
If it bogs with lots of smoke out of the hole lean the LSN 1 hour at a time until you get a nice launch. Once you lean the LSN your idle (RPM's) will want to go up. Turn the idle screw down accordingly.
If it bogs out of the hole with little to no smoke and sounds like it wants to die out richen the LSN and you will need to turn the idle screw up accordingly.
Factory settings on a 3.3 or a 2.5 should be right around 1-1/2 LSN or flush with the throttle horn and about 3-1/2 to 4 out on the HSN for reference.
got_nitro is offline   Reply With Quote
Old 06-30-2011, 08:07 PM   #3
Ya it smokes wen u hit the gas it idles high wen u get it goin, wen u get it goin into mid range to top end it goes good just low end sucks
Revo 3.3 or Jato 3.3 traxxastar21 Nitro Off-Road 34 11-01-2009 06:06 AM
Jato 3.3 help~! RcRacer12 Nitro Off-Road 19 07-09-2009 04:28 PM
