Old 06-28-2011, 08:11 AM   #16
Originally Posted by Mark _australia View Post
(and if anyone knows why the link at the bottom about mixing oils to make different weights no longer works, or where the mixing article is, can you let me know please? )
That link hasn't worked in a long time, here´s another: http://www.scriptasylum.com/rc_speed/oil_mixer.html
NitroVein is offline   Reply With Quote
Old 06-28-2011, 10:11 AM   #17
Trevor Williams's Avatar
Trader Rating: 195 (100%+)
Originally Posted by Bus View Post
Dont over drive? Dont Be a hack??????
what kind of racer are you?! lol j/k
Slow is FAST!
RC10-B6d | RC10-B64d
SmacTrac
#WeAreAE #ReedyPower #AE4Life
Trevor Williams is offline   Reply With Quote
Old 06-28-2011, 11:37 AM   #18
Trader Rating: 36 (100%+)
The original oil mixing link no longer works because it was purposely deleted. It was deleted because GE Silicones was purchased by a new Co called Momentive, I believe.
NitroOB4You is offline   Reply With Quote
Old 06-28-2011, 04:39 PM   #19
saw
It is possible when your car bottoms out the piston will be further up in the shock body with the extended shock ends. On some cars that could tear your badder. If your piston is close to hitting the bladder with short shock ends it could hit with long shock ends. Lets say that the shock ends are 2mm longer and you keep the same ride height your pistons will be 2mm higher in the shock body than before so when you bottom out the piston will be 2mm higher.
Agama USA
Rc Pro Products
saw is offline   Reply With Quote
Old 06-28-2011, 09:39 PM   #20
Tdiddy's Avatar
Send a message via Yahoo to Tdiddy
Originally Posted by liquidsky View Post
Picture please
I can't figure out how to post a picture on this website!
The dialog box says "Upload of file failed"
Any ideas what I'm doing wrong?
Mark Thomas
Really cool since 1975.
Tdiddy is offline   Reply With Quote
Old 06-28-2011, 09:43 PM   #21
T. Herwig's Avatar
Trader Rating: 25 (100%+)
Send a message via AIM to T. Herwig
What file format are you attempting to upload? (Check extension after file name)
You could also use an online image host such as Imageshack, Photobucket, etc.
Tyler Herwig
Tekno RC teknorc.com ∙ JConcepts jconcepts.net ∙ Spider Hobbies spiderhobbies.com ∙ SMC smc-racing.net ∙ Upgrade RC upgrade-rc.com ∙ Kustom RC Graphics kustomrcgraphics.com
T. Herwig is offline   Reply With Quote
Old 06-28-2011, 09:44 PM   #22
Brad S.'s Avatar
Trader Rating: 39 (100%+)
"DONT HIT THINGS OTHER THAN RACE LINES" By Trevor Williams is the best thing I've read/heard all day. lmao.
Brad
~Brad Shearer~
Team Associated ~ Motiv ~ JConcepts ~ Team Gravity RC ~ MIP ~ 92zerodesigns.com ~ Shearer-It Paint Designs ~ LiveTime Scoring ~ LiveRC.com
Brad S. is offline   Reply With Quote
Old 06-29-2011, 12:15 AM   #23
Teufel Racing's Avatar
Trader Rating: 26 (100%+)
Where to star, where to start?
Man there are so many tips, tricks, and mods to choose from these days and plenty of sourses to pull from. The choise is yours.
When in doubt, ask the local fast guys for help. Unless they are total D. bags, they'll usually give you good info on things like tires, inserts, setups, and things like that. Usually that kind of info seems to be what many are after and places such as this makes it hard to get good help sometimes.
Use a Sharpie on your rod ends to mark where the ball cup ends on the rod. Helps for a fast replacent of a broken ball cup track side and you should be pretty close to the length the rod was prior to the ball cup brake.
When running threaded shock bodies, index the threaded shock collar with a dremel or Xcato blade. Helps with setting the shocks equally by just counting the number of turns of the shock collar. Could also just use a set of calipers to measure them. Also gives a visual reference point to see if the shock collars stay in place or if they have been moved after a crash.
When running threaded shock collars, if there is enough room on the shock body, you can run two shock collars per shock. Reason is that it will allow you to "double nut" the collars, like what you would find on a rear shock of a dirt bike. The reason is to help ensude that the collar doesn't move in the event of a crash or being hit by another car/truck.
There's probably a million other things out there to try or learn from and everyone has "their" way of doing things.
J.Mikoliczyk
ZX6 - RB6 - MP9e
Fantom Racing, Cheater Racing
Houston's Engine Service
Teufel Racing is offline   Reply With Quote
Old 06-29-2011, 04:28 AM   #24
rider313's Avatar
Trader Rating: 94 (100%+)
Default Tires!
I will talk tires here. Most ppl forget tires are the most important thing when it comes to hooking up on any track. It kills me when guys ask what time works then say yeah I got those, open there tire box and pull out a set of dirt caked treads.
I would like a fresh set every time I births track. But that would be costly. So after I use a tire I clean it with my tire scrubber in water then give em a simple green scrub down. This way they feel most consistent time and again. For storage I zip them up in a 1 gallon zip lock bags. They always come out fresh just like a new set.
Dan Williams
MNRC Chairman
---Xray, RC America, Pro-Line Racing, FX Royal, Hudy, KO Propo, 92zero Designs, Vision Racing Products, RW-Mods, Team Loosenuts, forddesigns.net--- Big Thanks to: Wheel Brokers Track and Shop, Pine City MN~ "Stompy"
rider313 is offline   Reply With Quote
Old 06-29-2011, 10:35 AM   #25
Totally agree with that. Clean tires are happy tires.
Along those lines, when mounting up a new set of tires (unless i'm lazy and by premounts). Clean the bead of the tire and wheel with motor spray or alcohol. Gives a better bond. I use some eletrical tape to keep the tire bead seated in/on the wheel. I know there are the cool tire bands that people use and I have used thoes as well. The issues is after a while those bands tend to strech and not be as tight fitting like they were when new. The e tape allows me to set the bead as tight or loose as I want/need it to be and you can usually pick up a 5 or 10 pack for a few bucks at Harbor Freight or Home Depot.
J.Mikoliczyk
ZX6 - RB6 - MP9e
Old 06-29-2011, 11:12 AM   #26
Gonna steel one from a guy who helps me A LOT. Put your tires in a bag of WD40 overnight to soften the compound. Clean them real good before mounting, but if you need to soften up a set of mediums just soak in some WD40
☆ Losi 8T 2.0 ☆ OS Engines ☆ VP PowerMaster ☆ AKA ☆ HiTech ☆ F-Bomb Graphix ☆
555 Raceway, Bartow FL - http://www.facebook.com/555Raceway - Be a part of the rebirth!
SDelaney is offline   Reply With Quote
Old 06-29-2011, 01:17 PM   #27
put a thin layer or any kind of greese on your exhaust and manifold gaskets. Makes a much better seal, a crapload easier to take on and off and they will last longer
reuse your manifold springs by cutting bending
vet wrap for the best air filter cover in the history of the universe (some dont like)
pick up a huddy set up book
goody's hair bands at wall mart for throttle return bands, works way better then gmk supply and there about a gazillion for a buck or two
water balloons for shock boots, stretch with air hose, pull and tug, clip the ends for a perfect shock boot for about 1/100th of the cost
brake cleaner for motor spray and anything that you would use nitro blast for
graphite powder and spray for cvd's, hinge pins, servo saver post ball joints, pillow balls etc. way cheap. Oddonnell lube is just as good but two or three times the price.
If you have a nintendo wii, the hand strap on the end of the nunchuck makes a excellent arm band for your radio
ebay will save you butt loads of money when buying parts
never tighten down "gromets" down to hard on servos and fuel tank.
You can shim just about ALL the play out in the servo saver, ankerman bushings.
greese your orings, ring gears, and outdrives
always debur your clutchshoes
go to auto zone and get a flywheel puller for like 5$ works just as good as a 50$ one.
Harbor freight has kick ass digital calipers for a fraction of the cost. Use can also get 8 inch long shaft instrument drivers for less then 5$ awesome for tuning.
dont count needle turns on your carburator or retune from factory settings everytime. this is bad.
lucky 7 engine sealent will last forever
if you are going to freeze a pipe to get dents out do not fill it all the way with water, check often
NEVER go the wrong way on a track if there is even one other car on it.
where gloves when marshaling
throw your temp gun in a lake
always balance your tires it makes a unbelievable difference
tune at the track, not at home
heat sheild your fuel tank and body
use piano wire for pipe hangers
never where sandles
always check your screws and buy your screws and hardware from TONY!
do not discharge your lipo's all the way
set your idle gap before you put the filter on
clean cooling head and check plugs often
video games can be great practice
buy a transponder they are expensive but well worth the money
use the right foams for the right tires, same goes for wheels
use ARO to clean head button, and top of piston if need be
Do not death grip the screws on your buggy
always cusion your reciever from shock
test your failsafes and endpoints regularly, if you switch engines you could be in BIG TROUBLE!!
Use a one piece mount
replace the pins in you bones yourself, chainbreaker works awesome, look on ebay for it. Less then 40$ and one of the best investments i have made
dental probes are underrated, so are deep sockets
keep a log of your adjustments at the track
body lexan for mud guards
i am not even going to get into clutchbell and diff shiming, just make sure it's right!
if you suck at driving and need some excercise, go to the track by yourself
mean people suck, dont be a douche
take care of your stuff and it will last
"You are not understanding the fundamental principles of my fragmented personality"
Mugen
dreaux is offline   Reply With Quote
Old 06-29-2011, 01:28 PM   #28
Cant learn how to drive or tune or how setups will effect YOUR driving style from the internet.
Wrench on your stuff.
Learn to drive......... practice makes perfect.
Wrench Time is important.
Listen to the Pros..... They are Pros for a reason.
TLR - Spektrum - Horizon - TLR 8ight 4.0 - TLR 8ight-T 4.0 - TLR 22 4.0 - Orion
token is offline   Reply With Quote
Old 06-29-2011, 01:42 PM   #29
AZRC4Me's Avatar
Car setup is important, but tires are everything. Spend the money on the right tires and right compound. I see guys buy medium compound tires and run em when it's 70 degrees out then chase a setup all day because their car is loose. Pick the tire, then adjust the setup accordingly.
Practice running clean laps, if you can't clear the triple everytime consistently, don't do it. Mains are won by the most consistent driver, not necessarily the fastest. Have some discipline, you are always faster on your wheels than on your lid with your nitro horn screaming.
Sean Gaffney
...where some sponsors used to be...
AZRC4Me is offline   Reply With Quote
Old 06-29-2011, 01:48 PM   #30
If anyone is going to throw your exergen temp gun in the lake like they were told above. I will take them off your hands and pay the shipping.
Team Associated, JConcepts, M2C Racing, Big Pimpin Paints
Chris Reilly is offline   Reply With Quote
