Old 10-17-2005, 06:45 AM   #1156
Davidka's Avatar
Trader Rating: 75 (100%+)
So close yet so far was put there because everybody knew about the car coming out long before it actually did. I believe that Adam Drake has already pulled down some big wins with the car.
Chad B. will certainly be a big help.
Old 10-17-2005, 07:46 AM   #1157
WeatherB's Avatar
Hey guys,
I was running my Jammin yesterday at a new track and noticed that the chassis kept bottoming out upon landings after jumps. Even if I land the car on all fours I can hear the clunk of the chassis hitting the ground. I don't see the same problem with the Hyper 7s at our track so something is wrong with my setup.
Stock springs preloaded to arms level
30wt shock oil
Stock tires and rims
Shocks mounted to inner holes on tower
tnx
WeatherB is offline   Reply With Quote
Old 10-17-2005, 08:58 AM   #1158
uwadockers's Avatar
Originally Posted by the buggyman
you have the oils backwards. You are having problems with the rear on jumps becuse of the shock oils. also if you are going nose down after the jump hold the throttle in the air and that should bring the nose up. I always would run 40w up front and 30 or 35 in the rear. Try that you will see a huge difference.
It's personal preference really.. Heavier oil in the front would give you stability.. Heavier rear would give you more steering..
uwadockers is offline   Reply With Quote
Old 10-17-2005, 09:25 AM   #1159
macnkitty2002's Avatar
can you run the same viscosity front and back to attain both characteristics?
Team Associated RC10B4.2
Losi Rock Rey
macnkitty2002 is offline   Reply With Quote
Old 10-17-2005, 09:54 AM   #1160
Aaron Waldron's Avatar
Welcome to Chad Bradley to the Jammin' team!
Aaron Waldron - LiveRC
www.liverc.com
Aaron Waldron is offline   Reply With Quote
Old 10-17-2005, 03:55 PM   #1161
Default New Jammin Brakes
Anybody have a picture of the new Jammin Brakes, and how to set them up? A guy at my track gave me some new disk brakes and said they were the new jammin ones. They are black with some fibers in them and about as thick as 3 or 4 of the metal brakes.
t-roth is offline   Reply With Quote
Old 10-17-2005, 04:38 PM   #1162
i want to achieve more steering on my jammin buggy. i notice that the steering plate has three positions for the steering rod, and the manual recommends the center hole. can i change to one of the outer holes to get more turn in? also, how much camber do you guys run in the front?
Losi Rock Rey
Old 10-17-2005, 05:42 PM   #1163
arghh's Avatar
longer arm will make a car wider and shorter arm will make it narrower.. whats the advantage / disadvantage of this situation
arghh is offline   Reply With Quote
Old 10-17-2005, 06:10 PM   #1164
Anyone else having problems with the bottom shock mount screws stripping out and the grub screw not holding and the screw backing out. I tried using some of these http://www2.towerhobbies.com/cgi-bin...?&I=LXD368&P=0 and they work well don't strip or back out. The only problem is the material they are made of must be soft because they bend. Does anybody know if someone makes screw pins like these out of titanium.
rcjunky is offline   Reply With Quote
Old 10-17-2005, 06:24 PM   #1165
supralative's Avatar
Trader Rating: 16 (100%+)
Send a message via AIM to supralative Send a message via Yahoo to supralative
I used the holes closest to center of the buggy...furthest from the front.
I typically ran about 2 degrees of camber.
Son N.
www.hyperspeedmotorsports.com
www.oklahomanitroclub.com
supralative is offline   Reply With Quote
Old 10-17-2005, 07:22 PM   #1166
WheelNut's Avatar
Send a message via MSN to WheelNut
I moved the steering links to front holes and noticed an increase in steering. I believe this is because it changes the ackermann angles to a more aggressive posistion. I really like it with the link in the front holes since I run on a very tight track.
WheelNut is offline   Reply With Quote
Old 10-18-2005, 02:34 AM   #1167
arghh's Avatar
how will the car perform..
Old 10-18-2005, 04:36 AM   #1168
i run on a very small, tight track too. i think i'll move the steering links as you said. how much camber do you run?
Losi Rock Rey
Old 10-18-2005, 06:51 AM   #1169
uwadockers's Avatar
Try not to meddle around with the ankleman's position.. Centre hole is just nice.. If you want more steering, shift the rear upper shock position to the outside (meaning more vertical).. It will give you more active steering.. The above is just my personal opinion.. Also shorten the wheelbase.. Car will be nimble and appropriate for short and technical track..
Old 10-18-2005, 06:57 AM   #1170
x-ray addict's Avatar
NEED HELP!
Can someone give me an expert opinion on differential oils? What is a good combination? What are the pros and cons of using heavy and light oil? I've been getting some mixed info and i have a hard time figuring out which one is true. Thanks guys
x-ray addict is offline   Reply With Quote
Jammin/Hongnor X1 - so close yet so far jono mad racer Nitro Off-Road 5 05-08-2011 06:40 AM
anybody close ????? slowpokeRRR Minnesota and North/South Dakota Racing 0 08-24-2007 10:21 PM
close please pwnzor R/C Items: For Sale/Trade 0 06-29-2007 12:40 PM
close Big B R/C Items: For Sale/Trade 0 02-02-2007 10:29 PM
please close racenut123 R/C Items: For Sale/Trade 1 04-30-2003 05:08 PM
