Old 10-06-2005, 08:50 PM   #1111
mikejr718's Avatar
Send a message via ICQ to mikejr718
Default JAMMIN OPTION PARTS
Offroad season is over here in Nebraska and I was wondering about new option parts available for the X1CR.
1) Are the shocks listed on the Jammin site the new ones for the X1CR(big bore and lengthened) or are the just the truggy shocks listed as also fitting the buggy????
2) I have heard rumors of an updated brake cam to address the sticking problem. Is this an upcoming option or just a rumor????
The shocks and the brakes are the two areas that I spent the most time working on during the summer and am looking forward to fixing them for good this winter. Otherwise the buggy is one if the toughest out there. Many times races seem become durability contests and in this area the jammin always seem to win.
mikejr718 is offline   Reply With Quote
Old 10-07-2005, 04:44 AM   #1112
Hugh's Avatar
Trader Rating: 14 (100%+)
Got my P7 on the way for my Jammin X-1. I've got a 9886 pipe to run on it,but does anybody have any better suggestions for a pipe and glow plugs for 30%? I was thinking maybe a JP-2 pipe running McCoy MC-9 or MC-59 plugs.
Hugh is offline   Reply With Quote
Old 10-07-2005, 05:13 AM   #1113
macnkitty2002's Avatar
i run an RB-S5 with the JP-1 and MC-9 plugs with 30% with a 7 mill venturi. that seems to be a good setup for me on short tracks. i could actually run close to the same setup on a larger track just by putting in the 8 mill venturi and a higher clutchbell. this probably didn't help you...
as for the diff set-screw problem: do you think that by simply adding heavy duty thread locker, or some silicon glue to the set screw will stop the leaking?
also, i can't find 27.5 wt shock oil. do you think that i can combine half 30wt and half 25wt to the shock to achieve approximately a 27.5 wt oil? or will the two not mix together?
Team Associated RC10B4.2
Losi Rock Rey
macnkitty2002 is offline   Reply With Quote
Old 10-07-2005, 11:40 AM   #1114
I wouldn't use threadlocker on any plastic - apparantly its not too good for it but sure, wack some silicone or maybe even shoegoo?
au_Nightmare is offline   Reply With Quote
Old 10-07-2005, 11:55 AM   #1115
Hugh's Avatar
I've had soo many people over the years tell me it's okay to use threadlock on plastic,and EVERY time I tried it,it ends up melting the plastic. So I second au_Nightmare's advice.
Old 10-07-2005, 03:25 PM   #1116
melting the plastic? threadlocker doesn't get hot.
Losi Rock Rey
Old 10-07-2005, 03:49 PM   #1117
It is not heat that melts the plastic, its the chemical reaction. I've read plenty times don't use threadlocker on plastic so I've never done it and Hugh as first hand experience..
If you feel you need 1st hand experience go for it
Old 10-07-2005, 05:12 PM   #1118
so does it just strip the threads on the inside of the plastic?
Losi Rock Rey
Old 10-07-2005, 05:41 PM   #1119
Hugh's Avatar
Yes.
Old 10-07-2005, 06:11 PM   #1120
L.Fairtrace's Avatar
Trader Rating: 23 (100%+)
Send a message via AIM to L.Fairtrace
YAY
Awesomatix USA - EaMotorsports - RocheUSA - MonTech - Sanwa - BSR Racing Tires - TQ Wire - Solaris Racing Tires - Side Piece Racing
180 and 360 Raceway. Best on the East Coast. Take your pick
L.Fairtrace is offline   Reply With Quote
Old 10-07-2005, 07:31 PM   #1121
WheelNut's Avatar
Send a message via MSN to WheelNut
Well thanks for the very constructive comment! And thanks for wasting space on the Rctech server!
WheelNut is offline   Reply With Quote
Old 10-08-2005, 08:37 AM   #1122
i have finished building my kit and i am installing the servos now. you know how the kit comes with the servo horns with adapter for Futaba, JR, Airtronics, and Hitec? well, the adapter does not fit my hitec servo, which is brand new. or do the adapters need to be pressed on there pretty tightly? i don't want to damage my servo. also, i have noticed on some of my other cars that the servos make a humming sound when they are not moving. however, when you twitch the servo a bit, it stops. is this sound anything bad??
one last thing, can i mix 25wt shock oil and 30wt shock oil to get a 27.5wt oil? or does this not work?
Losi Rock Rey
Old 10-08-2005, 11:32 AM   #1123
Sometimes the adapters are pretty tight. If your using a high torque high speed servo, it should have a metal gear at the end to press it onto. The adapter will give before the servo will. My adapter gave the other night on my airtronics 94359 when someone decided to use my truck to slow down at the end of the straight away. Hope this helped.
mikeand00 is offline   Reply With Quote
Old 10-08-2005, 03:38 PM   #1124
i guess that makes sense. so the adapters act like another servo saver. thats cool.
what about my other question:
Losi Rock Rey
Old 10-08-2005, 05:59 PM   #1125
WheelNut's Avatar
Yes you can mix the oils. Although to let you know Losi and trinity both make 27.5wt oils. The spline adaptor in my kit fit very tightly on the servo as well, actually one of them broke on me while I was trying to install it, but I had a spare lying around.
Jammin/Hongnor X1 - so close yet so far jono mad racer Nitro Off-Road 5 05-08-2011 06:40 AM
anybody close ????? slowpokeRRR Minnesota and North/South Dakota Racing 0 08-24-2007 10:21 PM
close please pwnzor R/C Items: For Sale/Trade 0 06-29-2007 12:40 PM
close Big B R/C Items: For Sale/Trade 0 02-02-2007 10:29 PM
please close racenut123 R/C Items: For Sale/Trade 1 04-30-2003 05:08 PM
