Old 09-19-2005, 09:11 AM   #1021
Bone$'s Avatar
Im currently running a Hitec 945mg servo in my Jammin i dont feel im getting the full amount of turning i should be getting. My endpoints are maxxed on my radio what can i do to get more out of it please advise. What are your setups and what do you think?
Bone$ is offline   Reply With Quote
Old 09-19-2005, 10:15 AM   #1022
supralative's Avatar
Trader Rating: 16 (100%+)
Send a message via AIM to supralative Send a message via Yahoo to supralative
check your steering dual rates
i was in the same position as you maxed out endpoints and all
my dual rate was only at 50%
its all good now
Son N.
www.hyperspeedmotorsports.com
www.oklahomanitroclub.com
supralative is offline   Reply With Quote
Old 09-20-2005, 12:18 AM   #1023
arghh's Avatar
instead of all the setting/tuning (toe, camber, droop, diff, shock, castor, hole position, anti squat, ride height, anti roll bar), what else modification can be done to this car to make it more superb...
arghh is offline   Reply With Quote
Old 09-20-2005, 12:41 AM   #1024
Aaron Waldron's Avatar
Captured hinge pins, Jammin' carbon brakes, one piece engine mount, Lunsford turnbuckles, and a lot of practice time :-)
Aaron Waldron - LiveRC
www.liverc.com
Aaron Waldron is offline   Reply With Quote
Old 09-20-2005, 01:23 AM   #1025
arghh's Avatar
no aaron..., i mean modification and not setting/tuning by the option/upgrade part..
ex:- dremel back of the rear hub to get longer wheel base, dremel lower arm to get more droop, making new hole on rear shock tower to get longer rear upper arm linkage.... what else...???
Old 09-20-2005, 01:44 AM   #1026
Oh! haha
That's all I've messed with so far. I haven't done the rear arm thing in a while either..I think the longer camber link helped, so I've just been running my rear hubs spaced back but not dremeled.
I did dremel the front arms slightly to make sure I can get full lock-to-lock steering without the caster blocks hitting the arm.
www.liverc.com
Old 09-20-2005, 09:40 AM   #1027
Bone$'s Avatar
its all good now
What does the dual rate control?? Im running a JRXS3 Radio do i have that adjustment??
what stearing servos are you guys running and how much torque do they have??
Old 09-20-2005, 10:23 AM   #1028
dual rates in a short sense controls how much throw you have with steering from side to side
it does it evenly..not more to one side nor the other...end points take care of that
look through the manual and stuff it should tell you where its located on the transmitter
i run airtronics 94358 200oz of torque
Son N.
Old 09-20-2005, 10:52 AM   #1029
Bone$'s Avatar
So you said that yours was at 50% did you go up to 100 or down to 0 to get better response?
thats a baaaaddd servo!
Old 09-20-2005, 11:18 AM   #1030
You go higher to get full throw.
I run a 94359 for steering and throttle. The 359 is the same servo supralative is running, with ALL metal gears, and a heat-sink case.
www.liverc.com
Old 09-20-2005, 09:01 PM   #1031
arghh's Avatar
what about the bodyshell.. heard many racers modify their bodyshell position to place it more lower and aerodynamic
Old 09-20-2005, 11:27 PM   #1032
Default new x1-cr setup
aaron, what is your latest x1-cr setup with the new shocks, towers, chassis, etc.? thanks
eekern is offline   Reply With Quote
Old 09-21-2005, 12:49 AM   #1033
arghh - I haven't done anything to the body. I'm running a Pro-Line wing on my car..it definitely sits lower than the stock one.
The bodies available now are different than at first..the new ones sit lower.
eekern - I didn't change my setup at all actually...obviously, the pistons and oil inside the shocks are different (I'm not sure what pistons Jay handed us that day..but I'm running 50 in the front and 37.5 in the rear) but the rest of it is all the same.
www.liverc.com
Old 09-21-2005, 05:54 AM   #1034
How many racers are running the jamin out your way, percentage wise. Go ahead give it a guess.
Homer Allman is offline   Reply With Quote
Old 09-21-2005, 09:09 AM   #1035
Bone$'s Avatar
Being a new owner of a Jamming X1CR what would you upgrade to improve the car further other than the one pice motor mount i have that.
Please give me what you would do and what it improves overall?
Jammin/Hongnor X1 - so close yet so far jono mad racer Nitro Off-Road 5 05-08-2011 06:40 AM
anybody close ????? slowpokeRRR Minnesota and North/South Dakota Racing 0 08-24-2007 10:21 PM
close please pwnzor R/C Items: For Sale/Trade 0 06-29-2007 12:40 PM
close Big B R/C Items: For Sale/Trade 0 02-02-2007 10:29 PM
please close racenut123 R/C Items: For Sale/Trade 1 04-30-2003 05:08 PM
