Old 09-05-2005, 08:54 AM   #961
WheelNut's Avatar
Send a message via MSN to WheelNut
It broke in the lower section, across the hub, the front lower quater came apart right around the hinge pin, and it cracked right up under the mud scaper thing mount. Perhaps aluminum is avaliable from somewhere?
WheelNut is offline   Reply With Quote
Old 09-05-2005, 01:14 PM   #962
bigl's Avatar
Trader Rating: 31 (100%+)
the new shocks will not give you more drop unless you grind down the arm where it hits the chassis. the new chassis that is out i was told will let you get more drop also
bigl is offline   Reply With Quote
Old 09-05-2005, 02:05 PM   #963
speedy2's Avatar
jammin rated #2 in toptesting of 6 topbuggys around
777, jammin, mbx5, xb8, ttr, storm gs
by rc extreme buggys
http://www.rc411.com/video/other/bgycagematch.mov
speedy2 is offline   Reply With Quote
Old 09-05-2005, 05:53 PM   #964
arghh's Avatar
or just grind/dremel the chassis where the arm hit..
btw more rear toe out and more anti squat plate will automatically make more droop isn't it..
arghh is offline   Reply With Quote
Old 09-05-2005, 07:37 PM   #965
JusBox's Avatar
You have to read that article with a grain of salt - all those cars (except maybe the GS) are top notch.
JusBox is offline   Reply With Quote
Old 09-05-2005, 09:35 PM   #966
LOL, still at it after over a month?
StephenB is offline   Reply With Quote
Old 09-06-2005, 02:20 AM   #967
arghh's Avatar
hehe...
Old 09-06-2005, 03:03 AM   #968
JusBox's Avatar
Yah sure why not.
Old 09-06-2005, 03:55 PM   #969
bigl's Avatar
droop is how far the arm travels down so the only way to get more droop is to grind the chassis or the arm. i would not grind the chassis because you will not be able to take droop out if you want
Old 09-06-2005, 05:39 PM   #970
arghh's Avatar
only a little grind on chassis and u can got a lot of more droop... no issue if u want to use down travel limit screw once again.. instead the limit screw will sit much better on the chassis cause the chassis face where u grind is now parallel with the arm something like this \\.. before it look like this _\
Old 09-06-2005, 09:45 PM   #971
supralative's Avatar
Trader Rating: 16 (100%+)
Send a message via AIM to supralative Send a message via Yahoo to supralative
whats up guys
just got my X1 CR Pro
going to get a new throttle and brake linkage kit and it should be ready to go
i know its not the for sale section but does anyone have a really nice custom painted body for the X1 for sale?
no damage to it no rips tears or anything
if so please contact me at
supralative@yahoo.com
Son N.
www.hyperspeedmotorsports.com
www.oklahomanitroclub.com
supralative is offline   Reply With Quote
Old 09-07-2005, 06:59 AM   #972
What linkage kit are you going to buy?
Brad8283 is offline   Reply With Quote
Old 09-07-2005, 10:24 AM   #973
I am going to give this one a shot. I will still use some of the stock parts...wont use the ball and cap set up.
Son N.
Old 09-07-2005, 11:26 AM   #974
DerekB's Avatar
They are all top notch racers and why they were tested together to find out which we thought was the toppest notch of the notches.
Velocity RC Magazine
www.vrcmag.com
DerekB is offline   Reply With Quote
Old 09-07-2005, 08:34 PM   #975
ok the buggy is basically done and ready to go
just visually looking at the steering throw
the buggy doesnt seem to have a wide range ofmotion
i have my endpoints maxed out as far as it allows and it just doesnt look
like it has more steering throw than my hyper7 c hub did
i am using an airtronics 94358 for steering, buggy has been set up on a HUDY system and it just visually doesnt seem good
middle hole on ackerman plate...might move it to the hole toward rear of buggy and see if that helps
it has the B plate on in the front for caster too
should i be worried???
Son N.
Jammin/Hongnor X1 - so close yet so far jono mad racer Nitro Off-Road 5 05-08-2011 06:40 AM
anybody close ????? slowpokeRRR Minnesota and North/South Dakota Racing 0 08-24-2007 10:21 PM
close please pwnzor R/C Items: For Sale/Trade 0 06-29-2007 12:40 PM
close Big B R/C Items: For Sale/Trade 0 02-02-2007 10:29 PM
please close racenut123 R/C Items: For Sale/Trade 1 04-30-2003 05:08 PM
