Old 08-24-2005, 06:35 PM   #946
arghh's Avatar
why the front/rear swaybar need different in length and size and what they can do with the adjustable setting
arghh is offline   Reply With Quote
Old 08-24-2005, 07:00 PM   #947
L.Fairtrace's Avatar
Trader Rating: 23 (100%+)
Send a message via AIM to L.Fairtrace
That name fits you soo well.
Awesomatix USA - EaMotorsports - RocheUSA - MonTech - Sanwa - BSR Racing Tires - TQ Wire - Solaris Racing Tires - Side Piece Racing
180 and 360 Raceway. Best on the East Coast. Take your pick
L.Fairtrace is offline   Reply With Quote
Old 08-25-2005, 10:07 AM   #948
supralative's Avatar
Trader Rating: 16 (100%+)
Send a message via AIM to supralative Send a message via Yahoo to supralative
whats up guys
will be joining your ranks soon
just got me a X1 CR Pro
it will be a little till i tear it all down and set it up to my likings
in the mean time i will race my Hyper 7 still and post up pics
of the progress on the X1
Son N.
www.hyperspeedmotorsports.com
www.oklahomanitroclub.com
supralative is offline   Reply With Quote
Old 08-25-2005, 05:04 PM   #949
WeatherB's Avatar
Hey guys,
I got a X1 CR pro and am having some chassis tuning problem... The car likes to flip a lot while cornering.
I tried the orignal out of box setup and tried moving the front and rear shocks to the most inner hole but both didn't help.
tnx
WeatherB is offline   Reply With Quote
Old 08-25-2005, 09:21 PM   #950
arghh's Avatar
try to set all the softest/thinners at the rear... soft spring, thinner diff oil, thinner shock oil
Old 08-26-2005, 01:50 PM   #951
bigl's Avatar
Trader Rating: 31 (100%+)
what is your set-up like right now how much camber are you running -2,-2.5 is a good starting point all around also where is your rear camber link in the shock tower, another thing that helps is to cut off the inside and outside row of pins on your tires
let me know what your set-up is like and maybe i can help
bigl is offline   Reply With Quote
Old 08-26-2005, 04:10 PM   #952
WeatherB's Avatar
Hi,
I'm running -1.5 camber front and -2 rear.
The rear linkage is in the middle inner on the shock tower and outer on the hubs.
Old 08-26-2005, 05:59 PM   #953
WheelNut's Avatar
Send a message via MSN to WheelNut
WeatherB- Is the car built correctly? If it is all built properly with the stock setup you should not have any trouble with flipping in corners unless your running on a super high grip track (traction rolling). Are you sure its not a driving problem? Perhaps your just running the wrong lines? Watch the fast guys at your track, try and emulate them as best you can and ask them for driving tips on your track. I can tell you that my buggy with the stock setup will not flip while cornering on any surface.
WheelNut is offline   Reply With Quote
Old 08-26-2005, 06:13 PM   #954
WeatherB's Avatar
I was running it on pavement so for sure it was traction rolling, just looking for ways to minimize it.
I ran at an *actual* track today and didn't have any problems.
Old 08-27-2005, 10:52 PM   #955
WheelNut's Avatar
Well if your traction rolling probably the best solution to your problem would be to limit the down travel significantly so that at full extension your ride height is only 15-20mm, add stiffer springs and set your ride height at probably around 12-18mm. Thicker sway bars would also help.
Old 08-28-2005, 06:30 PM   #956
arghh's Avatar
Originally Posted by WheelNut
limit the down travel significantly so that at full extension 15-20mm, add stiffer springs and set your ride height at probably around 12-18mm. Thicker sway bars would also help.
do all this set up have to done on one side only or both front/rear..
Old 08-29-2005, 07:09 PM   #957
WheelNut's Avatar
It must be done at all four corners of the buggy. If not the handling will be very unbalanced.
Old 09-04-2005, 09:47 PM   #958
arghh's Avatar
do i need to use the new longer shock if i want more droop on the rear
Old 09-04-2005, 10:07 PM   #959
WheelNut's Avatar
Argggh-Yes you do. I think you need the new towers as well.
Has anyone else had trouble with their rear hubs? I broke one on a light snag in the middle of a qualifier yesterday and it looked like mabye there could have been an airbubble in it. Since I couldnt find anyone else with a Jammin and with no good hobby shop in at least 400km I had to resort to GS parts to fix it. I figure I'll pick up a few extra plastic suspension parts for spares right away here.
Old 09-04-2005, 10:48 PM   #960
arghh's Avatar
heard somebody else also had this problem, seem that this hub is consider important sparepart must have.. on what area actually it broke
Jammin/Hongnor X1 - so close yet so far jono mad racer Nitro Off-Road 5 05-08-2011 06:40 AM
anybody close ????? slowpokeRRR Minnesota and North/South Dakota Racing 0 08-24-2007 10:21 PM
close please pwnzor R/C Items: For Sale/Trade 0 06-29-2007 12:40 PM
close Big B R/C Items: For Sale/Trade 0 02-02-2007 10:29 PM
please close racenut123 R/C Items: For Sale/Trade 1 04-30-2003 05:08 PM
