Old 08-10-2005, 07:24 AM   #916
Regional Moderator
daniz24's Avatar
where can I fing the PDF manual for the X1CR. Thanks
daniz24 is offline   Reply With Quote
Old 08-10-2005, 08:43 AM   #917
lazarus's Avatar
Default manual
http://www.ofna.com/pdf/x1cr.pdf
lazarus is offline   Reply With Quote
Old 08-10-2005, 11:15 AM   #918
the buggyman's Avatar
The problem I had with the E-clips is when the front wheels turned all the way the inside of the wheel would rub off the e-clip. This was with wheels other then Ofna because the car had a lot of steering throw. The captured pins are not stronger, as a matter of fact I took them of the rear hubs because they bent. The captured pins are better but if you don't feel like spending the extra money I found that the Hot Bodies Lightning 2 front hub clips fit perfect and they are designed with only 1 e-clip and the other end is like a flat head of a nail, and they only cost like $2.00 and worked great.
the buggyman is offline   Reply With Quote
Old 08-10-2005, 05:49 PM   #919
WheelNut's Avatar
Send a message via MSN to WheelNut
If the E-clips start giving me trouble I'll change em over to the screw type.
I just finished the buggy, well actually I just need the engine which will be here tommorow. Check it out.
Jammin X1 - so close yet so far-jammin3good.jpg   Jammin X1 - so close yet so far-jammin5.jpg   Jammin X1 - so close yet so far-jammin4.jpg
WheelNut is offline   Reply With Quote
Old 08-10-2005, 08:10 PM   #920
Sgt_Morrow's Avatar
Are the diffs in a Jammin the same as a 777? I have both Buggys and the diffs look the same except the 777 has a front locker diff.
Sgt_Morrow is offline   Reply With Quote
Old 08-10-2005, 10:07 PM   #921
WheelNut's Avatar
Judging by the fact that the torsen diffs made by Jammin for the X1 also fit the 7.5 and 777 according to the Jammin site I would say they are the same. The centre diff seems to be the same as well, although the Jammin has 2 more teeth than the Kyosho, but Jammin also sells a 46t version as well.
Have you guys seen the new longer shocks, I just noticed these on the Jammin site. I'm assuming that these are for use with the 5mm tower on the upper row of holes. Its strange though, they look as if there are no shock boots, just some kind of seal to keep the dirt away from the the O-rings and possibly clean the shafts at the same time.
Old 08-10-2005, 10:15 PM   #922
Ya whats the deal with these parts. Anyone know when their going to be available?
Brad8283 is offline   Reply With Quote
Old 08-10-2005, 10:57 PM   #923
Regional Moderator
daniz24's Avatar
lazarus, thanks
Old 08-11-2005, 12:18 AM   #924
arghh's Avatar
i think this is far more better than the standard rubberboots dust cover. it can protect from dust and clean the shock shaft at once. the rubberboots only cover the shock but cannot clean it..
arghh is offline   Reply With Quote
Old 08-11-2005, 08:26 AM   #925
Regional Moderator
daniz24's Avatar
Anyone having problem using other manufacturer's wheel such as GRP, Mugen, etc other than Hong Nor Dish Wheels?
Old 08-11-2005, 05:55 PM   #926
Send a message via Yahoo to z4cky
daniz24, I already try GRP, Proline, Kyosho Wheels with No problem but I haven't try Mugen's yet
z4cky is offline   Reply With Quote
Old 08-11-2005, 06:27 PM   #927
Regional Moderator
daniz24's Avatar
Thanks. Glad because Hong Nor Wheels is more expensive than others...
Old 08-11-2005, 07:51 PM   #928
arghh's Avatar
anti roll bar, stableliser bar, anti dive bar, sway bar...??? what are the real name of this part..
what does the 2 set screw on the gear case do with this bar.. how to set the bar, tight or loose..??
and what will the position of the adjustable stand on the end of the bar will do..
Old 08-12-2005, 02:42 AM   #929
windnclouds is offline   Reply With Quote
Old 08-12-2005, 04:39 AM   #930
ntc3freak's Avatar
hey guys.how do u like this buggy???how does it handle out of the box???pros/cons???parts that need to stock up???durability???parts fit/finish???is there a new version coming out???
ntc3freak is offline   Reply With Quote
Jammin/Hongnor X1 - so close yet so far jono mad racer Nitro Off-Road 5 05-08-2011 06:40 AM
anybody close ????? slowpokeRRR Minnesota and North/South Dakota Racing 0 08-24-2007 10:21 PM
close please pwnzor R/C Items: For Sale/Trade 0 06-29-2007 12:40 PM
close Big B R/C Items: For Sale/Trade 0 02-02-2007 10:29 PM
please close racenut123 R/C Items: For Sale/Trade 1 04-30-2003 05:08 PM
