Old 05-10-2005, 07:01 PM   #691
the buggyman's Avatar
Default Jammin
CHim CHim this has also happened to one of my Jammins. It still works fine and won' t fall out but it gives a lot of movement to the wheel.
the buggyman is offline   Reply With Quote
Old 05-10-2005, 10:20 PM   #692
Chim-Chim's Avatar
I may have a fix for the broken kingpin problem. I have found two reasons that support
the cracking on these pins. The first one is that there is some play on the wheel hub
adapter.(pull your wheel forward and back while holding the lower arm). This play allows
the wheel to move lateraly putting excess stress on the lower kingpin(try this and look
at the lower kingpin while you move the wheel, it rocks back and forth on the hub, cracking the pins.)
A narrow shim between the bearing and hub adapter should help remedy the problem. Another thing you can try
is grinding out the narrow bridge that the pin rides on, increasing the surface area inside the hub. What do you guys
think, let me know.
Chim-Chim is offline   Reply With Quote
Old 05-10-2005, 10:41 PM   #693
arghh's Avatar
instead of the T-shape kingpin screw, can we use any other screw because there is a big gap between top of the kingpin screw and the cva wheel shaft
arghh is offline   Reply With Quote
Old 05-11-2005, 11:20 AM   #694
speedy2's Avatar
2d round
A-Main Results:Pos Name Car Engine Tyres Fuel
1 Chad Bradley Mugen JP Pro-Line Mugen
2 Adam Drake Jammin Sirio Pro-Line Trinity
3 Mark Pavidis Kyosho OS Pro-Line Sidewinder
4 Bobby Tillman Mugen JP Pro-Line O'Donnell
5 Aaron Waldron Jammin Sirio Pro-Line Trinity
6 Greg Degani OFNA Picco Pro-Line Sidewinder
7 Kris Moore Mugen OS Pro-Line Mugen
8 Greg Waller XRAY RB Panther ?
9 Daniel Adams CEN OPS ? ?
10 Dean Sexton Jammin Novarossi Pro-Line ?
11 Mike Kendall Jammin SH ? ?
12 Andrew Smolnik CEN OPS Pro-Line ?
13 Jeff Guest XTM SH ?
speedy2 is offline   Reply With Quote
Old 05-12-2005, 09:35 PM   #695
arghh's Avatar
Originally posted by speedy2
[B]2d round
congrats guy... first time see many ofna/jammin on race result
Old 05-13-2005, 04:34 PM   #696
L.Fairtrace's Avatar
Trader Rating: 23 (100%+)
Send a message via AIM to L.Fairtrace
Just got my buggy today, any tips on building besides the hingepins and motormount?
T.O.P Racing - Awesomatix USA - EaMotorsports - BSR Racing Tires - Orca - TQ Wire - Solaris Racing Tires - Side Piece Racing
Horsham RC. Where champions practice Failing. I'm your everything.....
L.Fairtrace is offline   Reply With Quote
Old 05-13-2005, 09:35 PM   #697
arghh's Avatar
correct me if i'm wrong. using the front lower arm A block will make the caster something like 20 or 22 degree and B block will make it 17 or 19 degree. thats why B block it got a lot of steering
Old 05-15-2005, 05:04 AM   #698
Default finally ran the Jammin'!
Well, I finally ran the Jammin'! We had an informal (no transponders) race night and we all brought buggies. The Jammin' is the first buggy I've ever had that I just slapped on the track and it ripped! I built it right to the manual but I put 35wt shock oil in the front and 30wt in the back. I set 1 degree of negative camer everywhere and set the front toe-in to 0 degrees. The car is pretty dialed just like it is! I can see making some minor adjustments to it but I don't want it to change much - I love it! The car turns awesome on and off power, it's stable and it jumps well. I put 1/2 gallon through it and had a blast. The new motor is still super tight even after 1/2 gallon and I'm having a little trouble with tuning... but I find that's not unusual until they loosen up.
I'm excited about the car! I'd like to go HERE next weekend... they're having a trophy race and the track is huge! The pic doesn't really do it justice... it wasn't complete when that was taken.
x-GTer is offline   Reply With Quote
Old 05-15-2005, 12:24 PM   #699
speedy2's Avatar
14 may ARCR series Little Rock
A Main Results 1/8th Scale Buggy
1st Place….Brad Shackleford (5)…..Mayhem Pro....
2nd Place…Steve Strickland ( 8 )……...
3rd Place…Tony Larosa (4)…………...XRAY....
4th Place…Mike Shackleford (6)…….XRAY....
5th Place…Dino Walls (3)……………....XRAY....
6th Place…JD Crow (10)…………….....XRAY....
7th Place…Garrett Winningham (9)…TTR S3....
8th Place…Drew Spurgeon (2)……….Jammin....
9th Place…Tom Colclasure (7)..……..OFNA....
10th Place..Shane McCall (TQ)……….XRAY
Old 05-15-2005, 10:10 PM   #700
wild gopher's Avatar
Trader Rating: 39 (100%+)
i just got my Jammin and will be building it to Adam Drakes "the dirt" setup. I notice he is using 5,10,5 for his diff oils. Can someone explain what the thicker oils will do for me. I used to run an MBX-5 with the standard 5,7,1 oils. I also noticed in the manual it says to fill the diff case up 100%, I normally fill my MBX5's cases up to the top of the cross shaft. Someone fill me in on the right way to do this
RCtech - Filling me with adult drama since 2003
wild gopher is offline   Reply With Quote
Old 05-16-2005, 05:14 AM   #701
Sgt_Morrow's Avatar
I didint get to go to the ARCR Race my parts didnt arrive on time or thier would be another Jammin in the top 10 of the Amain But a buddy of mine got 2nd down thier Steve Strickland
Sgt_Morrow is offline   Reply With Quote
Old 05-16-2005, 05:18 AM   #702
Sgt_Morrow's Avatar
I tried a new setup this weekend and it was unreal how well it worked i tired 3-7-1 in the diffs and Mugen black clutch shoes and mugen 1.0 springs. and a ofna 13 tooth vennted clutch bell it was unreal how fast it was. I might try 5-7-1 though. Does any body know where i can get some 2000wt diff oil at?
Old 05-16-2005, 06:31 AM   #703
I got 2000wt diff oil at Nitrohouse
Old 05-16-2005, 06:41 AM   #704
kevink2's Avatar
wild gopher, I just started with one too. I think the thicker stuff will make the car punchier but a less forgiving over bumpy stuff.
As for building the diffs, check out this tutorial:
http://www.twf8.ws/new/tech/car/hong...1cr-index.html
kevink2 is offline   Reply With Quote
Old 05-16-2005, 12:32 PM   #705
Sgt_Morrow's Avatar
Thanks ill try nitrohouse.
Jammin/Hongnor X1 - so close yet so far jono mad racer Nitro Off-Road 5 05-08-2011 06:40 AM
anybody close ????? slowpokeRRR Minnesota and North/South Dakota Racing 0 08-24-2007 10:21 PM
close please pwnzor R/C Items: For Sale/Trade 0 06-29-2007 12:40 PM
close Big B R/C Items: For Sale/Trade 0 02-02-2007 10:29 PM
please close racenut123 R/C Items: For Sale/Trade 1 04-30-2003 05:08 PM
