Old 03-28-2005, 04:43 PM   #481
Sgt_Morrow's Avatar
The only thing that i hate about this car is the foams the tires come with and the Eclip hinge pins. I bought some Panther foams and captured hinge pins and never looked back.
Sgt_Morrow is offline   Reply With Quote
Old 03-28-2005, 04:48 PM   #482
arghh's Avatar
very bad weather, heavy rain with thunderstorm every day, long time cannot play, the track full of muddy... so what do you do with this car on this time period
arghh is offline   Reply With Quote
Old 03-28-2005, 07:32 PM   #483
Sgt_Morrow's Avatar
Where the heck is Aaron Waldron?
Old 03-29-2005, 06:24 AM   #484
the buggyman's Avatar
I also like the captured hinge pin, but the rear hub pin bent. So when I built my second jammin I kinda made my own captured hinge pins by dremeling the pins to be flush on the a-arm. I then drilled a small hole in the a-arm next to the pin and put in a small screw, so the head off the screw was against the pin, this was done on each side. Its like the Xray hinge pins and it works real well, and it cost nothing to do.
Waldron has been at the Silver State race which ended Sunday.
the buggyman is offline   Reply With Quote
Old 03-29-2005, 10:04 AM   #485
Trader Rating: 15 (94%+)
Send a message via AIM to W.E.D.Jim
Sgt, i'm gonna guess he is either racing, or wrenching...rather then posting about racing and wrenching, LOL..............Jim
www.wedjim.com ...Closed down due to heavy work load I couldn't keep up with and maintain my primary job. But I'm still painting, just not with 40+ bodies waiting. :)
www.prolineracing.com
www.HarleyDavidson.com
"Nothing but the best!"
W.E.D.Jim is offline   Reply With Quote
Old 03-29-2005, 10:39 AM   #486
Sgt_Morrow's Avatar
Jim do you make a body for the Jammin yet?
Old 03-29-2005, 11:40 AM   #487
Send a message via Yahoo to nitro_tacklebox
Default My X1
Here you go...
nitro_tacklebox is offline   Reply With Quote
Old 03-29-2005, 11:42 AM   #488
Default Another look
with the body on this time.
Old 03-29-2005, 06:06 PM   #489
j
gmcstep2003 is offline   Reply With Quote
Old 03-30-2005, 08:41 AM   #490
Trader Rating: 15 (100%+)
Send a message via AIM to stebog
I have a TOP P5 and had/have problems with the engine mounts that came in my kit. Once snugged to the engine they flair out. I put a shim between the mounting flange and the mount which helped. No problems with gear mesh but it's still in the back of mind.
I was getting ready to order the one piece engine mount when I spotted that 2 page ad in one of the more recent issues of Xtreme, I believe. There is a picture of 'stock' engine mounts without a groove to capture a locknut. The design is similar to the type used on a NT Drake kit. Is this a running change to the part? Does anyone know if it's the same part #? Sure sounds a lot cheaper than the 1 piece mount.
stebog is offline   Reply With Quote
Old 03-30-2005, 11:29 AM   #491
are you referring to the Hyper 7 2 page ad? Part # 19717? (page 38 in Xtreme Apr 05 issue)
They look interesting, however I purchased the one piece mount and I can honestly say what a breeze it is to set mesh and that thing looks much more sturdy and less prone to tweak then the 2 piece mounts.
Just my .02 cents.
Old 03-30-2005, 11:54 AM   #492
Sgt_Morrow's Avatar
[QUOTE]Originally posted by stebog
[B]I have a TOP P5 and had/have problems with the engine mounts that came in my kit.
I Have a Rex P5 and have the same Problem I talked to Ofna yesterday and they said that the Novarossi crankcase is square and the jammin mounts were not made to fit the P5's or the 421 Novarossi motors. They told me i would have to get the One piece Motor mount to fix this problem, Hope this helps.
Old 03-30-2005, 12:56 PM   #493
Thank you Sarge. Off to the LHS to place an order.
Old 03-30-2005, 12:58 PM   #494
nitro_tacklebox - The ad I was referring to was on pages 32-33 in May Xtreme, top right has the new design two piece mounts.
Old 03-30-2005, 01:01 PM   #495
the stock motor mounts are garbage!!
I have the one piece motor mount and it works awsome. I run it on my new Jammin. I have two Jammins and I practice with the old one. I thought at first the problem was with the Nova case being bigger but it is not, the stock mounts just suck.
I was running today with the stock mounts and a sports work motor and the mounts loosened. Now the clutch bell is gone and so is the spur gear. I called Ofna and they said the updated ones will be out in a couple weeks and they would post it on there site. In the mean time I have to spend around $50 for a new bell and spur. Then buy the new mounts.
Jammin/Hongnor X1 - so close yet so far jono mad racer Nitro Off-Road 5 05-08-2011 06:40 AM
anybody close ????? slowpokeRRR Minnesota and North/South Dakota Racing 0 08-24-2007 10:21 PM
close please pwnzor R/C Items: For Sale/Trade 0 06-29-2007 12:40 PM
close Big B R/C Items: For Sale/Trade 0 02-02-2007 10:29 PM
please close racenut123 R/C Items: For Sale/Trade 1 04-30-2003 05:08 PM
