Old 03-08-2005, 12:55 PM   #436
Trader Rating: 15 (94%+)
Send a message via AIM to W.E.D.Jim
I haven't had any problems with the shock mounts, but I did tweak a front shock tower......To be expected the way I was driving last race with the car....>sigh<..........Jim
www.wedjim.com ...Closed down due to heavy work load I couldn't keep up with and maintain my primary job. But I'm still painting, just not with 40+ bodies waiting. :)
www.prolineracing.com
www.HarleyDavidson.com
"Nothing but the best!"
W.E.D.Jim is offline   Reply With Quote
Old 03-09-2005, 01:50 AM   #437
Aaron Waldron's Avatar
Qlder - Use fuel filters without the elements to hold more fuel instead of lots of fuel line.
I haven't heard of anyone running the car on grass yet..you can be the first! haha
CAR - The edges of either the body or the cap have been known to be sharp and therefore tear the bladder. They are changing to molds to get rid of the sharp edges and recommend you file down any burrs on the ones you may have now.
Aaron Waldron - LiveRC
www.liverc.com
Aaron Waldron is offline   Reply With Quote
Old 03-09-2005, 01:03 PM   #438
Aaron, I think he means the tank is oversize a bit, needing 2 feet of fuel line to get down to 125cc?
I don't think it's a problem unless you racing at nats or worlds..........Even the equipment used to tech tanks at those races is subject to discrepencies, but at least everyone gets checked on the same equipment at a particular race.................Jim
Old 03-09-2005, 01:07 PM   #439
I don't think it's over-sized? I don't remember stuffing tanks at the Worlds to get them down to legal size.
www.liverc.com
Old 03-09-2005, 05:15 PM   #440
arghh's Avatar
how often you clean the fuel filter, can the filter re-used again, how to know that the filter is no good anymore and how long can used the filter
arghh is offline   Reply With Quote
Old 03-09-2005, 05:18 PM   #441
Send a message via AIM to MMor101
I dont think fuel filters really wear out. your tank already has a filter anyways. The reasons fuel filters are use are for that extra capicity. I clean mine out with some compressed air.
MMor101 is offline   Reply With Quote
Old 03-09-2005, 09:42 PM   #442
Yeah, what he said!
You can take the filter apart and flush it clean with fuel or WD-40.
www.liverc.com
Old 03-09-2005, 10:21 PM   #443
arghh's Avatar
how often... once per each gallon or...???
about the fuel line, how do you put it.. shorter before the fuel filter and long after, or long before fuel filter and shorter after, or just same long both before and after the fuel filter
Old 03-09-2005, 11:22 PM   #444
It doesn't matter which way you mount your fuel line..just personal preference.
Your fuel filter shouldn't really get clogged up, so whenever you feel like giving your buggy a good cleaning, you can clean out the filter as well.
www.liverc.com
Old 03-10-2005, 01:21 AM   #445
arghh's Avatar
someone condemn about the 9.5 rear wing that x1cr use but i cant find where the post are. so what do you think about it, what is the best shape / design. what brand of buggy have the very good rear wing shape / design. are the position of the wing make sense whether it is right back enough or is it enough height
Old 03-10-2005, 01:26 AM   #446
I think the stock wing works very well. I've only broken one up until this point and have no complaints.
www.liverc.com
Old 03-10-2005, 11:33 AM   #447
Send a message via Yahoo to nitro_tacklebox
I am in the process of building the X1CR and found my steering linkage to be not as free as I would hope. Anyone have any suggestions on what to check for aside from the usual? I followed the instructions and checked for any parts binding but just cant seem to find any fault in the build or the parts themselves.
any help would be appreciated.
nitro_tacklebox is offline   Reply With Quote
Old 03-10-2005, 01:45 PM   #448
Nitro, the only thing I found that you'll want to look for, is if you run too much front droop, the steering tie rods will bind on thier pivot balls and make the steering feel tight. If you lift up on the suspneion arms a little and the steering frees up that is your problem.........I basically set my droop right to the maximum when the steering starts to get tight...............Jim
Old 03-10-2005, 04:36 PM   #449
arghh's Avatar
too much droop also make the knuckle stuck on the lower arm and feel the steering very tight. you can't get your steering to it maximum unless you lift up a little. you also have to look the screw tightening the linkage, it must use the v shape screw/washer. others maybe the c-hub very fit with the knuckle, it will take a little time to loose
Old 03-10-2005, 08:10 PM   #450
CAR
CAR's Avatar
How will does the harden anodized hinge pin mounts hold up as far as wear? My second car is a MBX5 when that gets sloppy it cost about $5 to$6 to tighten it back with bushings. With no bushings this car can cost big bucks buying all the aluminum pieces .What can I expect for wear? Thanks
CAR is offline   Reply With Quote
Jammin/Hongnor X1 - so close yet so far jono mad racer Nitro Off-Road 5 05-08-2011 06:40 AM
anybody close ????? slowpokeRRR Minnesota and North/South Dakota Racing 0 08-24-2007 10:21 PM
close please pwnzor R/C Items: For Sale/Trade 0 06-29-2007 12:40 PM
close Big B R/C Items: For Sale/Trade 0 02-02-2007 10:29 PM
please close racenut123 R/C Items: For Sale/Trade 1 04-30-2003 05:08 PM
