Old 07-09-2008, 09:56 AM   #4441
ALG
Can any find out the setup used by Richi Gomez for the EUROS??? on his HN x1x?
thanks for your help
ALG is offline   Reply With Quote
Old 07-10-2008, 04:44 AM   #4442
Bigkev's Avatar
From my observations from all the photo’s seen on the web of Richi Gomez’s buggy these are the following setup features I did notice.
- 10mm preload on rear sway bar
- 4mm preload on the front sway bar
- Looks to be the largest silver rear sway bar 2.8mm
- Front sway bar looks to be 2.5mm
- He looks as though he uses fuel hose either side of the sway bars where they are mounted to help keep the sway bar centralized, both front and back. He must run the sway bars pretty loose in the clamps.
- Uses centre steering Ackerman hole
- The photo’s of his car when it is clean shows silver springs and the action shots show white springs on his buggy, I believe he ran the final with the white springs
- RB C6 Motor
- Wing mounts are level, upper holes
- Alloy steering top brace (replaced the carbon fibre)
- Shock mount settings
o Rear shocks bottom outer hole on arms (pos 1)
o Rear shocks most inner top hole (pos 3)
o Front shocks bottom outer hole on arms (pos 1)
o Front shocks most inner top hole (pos 3)
And that’s about all I can help you with. Obviously love to know the diff and shock oils he used. I don’t speak Spanish so I wouldn’t know who to ring in Hong Nor Europe. If anyone finds out what diff oils let us all know, the Euro track is very simular to the track surface I race on in Australia.
Cheers Kev
Jammin X1 - so close yet so far-day2-gomez.jpg   Jammin X1 - so close yet so far-f-car8.jpg   Jammin X1 - so close yet so far-f-action8.jpg   Jammin X1 - so close yet so far-s-jump1.jpg
AKD Prototypes (Koln)
Bigkev is offline   Reply With Quote
Old 07-16-2008, 04:47 PM   #4443
DR ZAIRUS's Avatar
I got a blurry image of his setup sheet from this web:
http://hongnor.oxatis.com/PBHotNews.asp?PBMInit=1
It seems in addition to what has already been said, he used 1'5 anti-squat and 2.5 rear toe in. A front arm supports. I can't make out the diff settings, but knowing his agressive driving stile, I bet it was something like 10.000-30.000-5.000 or something similar!!! heh heh!!
Hong Nor/Jammin' X2
Picco P7 Evo3+JP3
Futaba+KO Propo.
TEAM www.fisio-sport.com
(Valencia, Spain)
DR ZAIRUS is offline   Reply With Quote
Old 07-27-2008, 09:58 AM   #4444
ALG
Default SPRING RATE 16mm
Can some one help me out to find what are the color code for the spring tension?
from soft to hard?
yellow, white, silver (Original X1X),blue, grey ????? is this correct?
thanks for the help!!!!
and have fun!
Old 07-27-2008, 10:01 AM   #4445
imaxx21's Avatar
Send a message via AIM to imaxx21
this might help
http://www.nitrohouse.com/tip_spring_chart.htm
-Crash
Upgrade RC www.upgrade-rc.com
imaxx21 is offline   Reply With Quote
Old 07-29-2008, 06:37 PM   #4446
ALG
Thanks IMAXX21, but that chart dosent include the the 16mm BB springs, thanks for the help anyway.
Hope some one can helps us ith the spring issue.
Old 07-29-2008, 08:08 PM   #4447
NV_RATTLER's Avatar
This is off the Jammin site
Here's some buggy and truggy shock setups for the new Super Big Bore 16mm shocks. The oil used in the new shocks is alot more critical to outside air temperature so that should be taken into consideration.
Buggy shock setups...
Spring...........silver/chrome front and rear
Shock end.....short front, long rear (screwed all the way in, but adjusted so left and right sides are equal)
Piston........1.4mm 6 hole
Losi Oil.... Outside temp 95+ ( 45 front, 35 rear) Temp 80-90 (40 front, 30 rear) Temp 60-70 (37.5 or 35 front, 27.5 or 25 rear)
Truggy (CRT) shock setups...
Spring...............Blue front and rear
Shock end.........short front, long rear (screwed all the way in, but adjusted so left and right shocks are equal lengths)
Piston...............1.4mm 6 hole
Losi Oil 50wt front, 40 rear during the day 45wt front, 35 rear if its cooler
Chad
NV_RATTLER is offline   Reply With Quote
Old 07-31-2008, 02:02 AM   #4448
Trader Rating: 44 (100%+)
i've gotta get you guys some pics of my new buggy up..it's sick the setup works great for me so far...pics tommorow
T5M 7.5
22 3.0 7.5
SickWitiTRacing(Jayson)
NitroLuver is offline   Reply With Quote
Old 08-06-2008, 05:55 PM   #4449
NZDriver's Avatar
Guys, need some help.
Ive upgraded (?) to the Piviot Ball Suspension and need a couple of things.
Firstly, the instructions only came with steps 4-6, the first sheet was missing so ive had to guess on the assembly for the most part. Can someone upload / email me a copy of the instructions for the PBS ?
Second, i seem to have a lot of play in the wheels. When i hold each front wheel and rock them top to bottom, the pivot balls are moving considerably. This only happens when at "rest". When the suspension is compressed or at full lock, there is no slop.. but when the wheels are straight on.. lots of play. I dont know whether this is normal or my assembly.
Any ideas ?
Losi 8ight 2.0/OS Speed
Xray T2'008/Tekin RS
Kyosho SC-R/LRP
NZDriver is offline   Reply With Quote
Old 08-07-2008, 03:51 PM   #4450
JPMSRacing's Avatar
Location: Lost in the Dead Space between my Ears Somewhere around Wamego, KS (OZ Land)
I ran those pivot ball suspension, I would have to look and see how it is set up but the big alum. nuts go in very very hard, you have to screw them in and really hold the knuckle, you think you are going to break it hard. tighten them down till you can move the ball in the knuckle and then loosen just enough for movement but no sloop.
The knuckle breaks at the tie rod end during racing, I installed the MBX5R knuckles and used the MBX5R tie rod ends with HPI balls in them. It is a hot set up, and never have broken a knuckle since.
My son (he is 9) is racing that car this year or crashing it, LOL and I still think it handles better than my new X1X. You can really drive it into a corner and still pull out of it, but the set up is freaky and nothing like the normal setup with the C on the front.
Let me know if you want some more information.
I'm around still!!!
JPMSRacing is offline   Reply With Quote
Old 08-07-2008, 03:59 PM   #4451
NZDriver's Avatar
Thanks, yes the big alloy nuts are tight, but ive not had to swing on them, maybe thats where my problem is. I'll let you know whether it fixes it, or i break them !
I still have the C Hub setup as a backup of course..
Does anyone have the instructions they could scan and upload / email to me ??
Cheers
Kyosho SC-R/LRP
Old 08-07-2008, 04:58 PM   #4452
JPMSRacing's Avatar
The paper with the parts is like half of them, and online they suck, so small you cant see anything and the quailty is so poor that when you blow them up you cant read them at all.
Look close, this is my boy a couple weeks ago. You can see the PBS on it.
I'm around still!!!
Old 08-07-2008, 05:06 PM   #4453
JPMSRacing's Avatar
One more.
I'm around still!!!
Old 08-08-2008, 01:44 AM   #4454
NZDriver's Avatar
Thanks for the advice it looks like i needed to get more brutal with the allen key and tighten the alloy nuts more ! You were right and ive tightened them to what i suspect would be too tight, but there is no more slop and everything still moves like it should... bring on the fine weather and i will start putting the PBS through its paces !
Kyosho SC-R/LRP
Old 08-09-2008, 08:19 PM   #4455
JPMSRacing's Avatar
Let us know how it works.
I'm around still!!!
Jammin/Hongnor X1 - so close yet so far jono mad racer Nitro Off-Road 5 05-08-2011 06:40 AM
anybody close ????? slowpokeRRR Minnesota and North/South Dakota Racing 0 08-24-2007 10:21 PM
close please pwnzor R/C Items: For Sale/Trade 0 06-29-2007 12:40 PM
close Big B R/C Items: For Sale/Trade 0 02-02-2007 10:29 PM
please close racenut123 R/C Items: For Sale/Trade 1 04-30-2003 05:08 PM
