Old 05-22-2008, 06:29 AM   #4381
Originally Posted by Seven1Four View Post
Whats up peeps....on the rear hubs on the jammin x1cr fte, im getting some wheel wobble, I checked and cleaned the bearings, the unis are new, what might work to fix the wobble? Thanks.
It's probably wearing between the outer race of the bearing and the corresponding surface of the hub.
adam lancia is offline   Reply With Quote
Old 05-22-2008, 08:21 AM   #4382
macnkitty2002's Avatar
It's probably the plastic hub that has gotten some play in it. Try replacing that. It is a high-wear part anyways, so don't be suprised. That's why a lot of guys replace them with aluminum units.
Team Associated RC10B4.2
Losi Rock Rey
macnkitty2002 is offline   Reply With Quote
Old 05-24-2008, 03:37 PM   #4383
Panther's Avatar
Send a message via AIM to Panther
Wheel wobble isn't a bad thing. I keep my car as loose as possible. Worst case scenario is that it might be the rear uprights. Just replace them with the stock plastic ones to keep weight down.
Panther is offline   Reply With Quote
Old 05-24-2008, 04:23 PM   #4384
Trader Rating: 26 (100%+)
Send a message via AIM to cheesecake
well i ordered all the bce conversion pieces 2 bce pjx chassis and 2 sets of super big bores one for me and one for my dad. hopefully i can get him out and when he isnt racing its my backup truggy
cheesecake is offline   Reply With Quote
Old 05-25-2008, 08:22 PM   #4385
Seven1Four's Avatar
Trader Rating: 41 (100%+)
adam, macnkitty, panther.....thanks for the info, I swapped out the bearings with new ones and new uprights......booya......problem solved! Thanks again.
Allen
STICKY⭐️KICKS | OC_RC RACEWAY
Seven1Four is offline   Reply With Quote
Old 05-26-2008, 03:43 AM   #4386
Panther's Avatar
Originally Posted by huskerfreak View Post
Can you tell me why you need all that lighten stuff?? Most all off road engines sold now have more power than a car track or driver can handle so why would you need all the lighten drive line stuff it just wear out that much quicker. As for a lighten chassis don't understand that either why would you lighten the item of the car that sits the lowest of any thing. The car is already fairly light to begin with. And again most motors supply more than enough power.
The only viable option you said would be the rear alminum up rights and center diff mount. The rest is crap for poeple like you that think that you need it to go fast but it doesn't make you any faster.
Whats the price difference between the Mugen and the Jammin that makes a bit of a difference and what does it matter if the Jammin handles better.
The Jammin car is one of the heaviest buggies that competes on the national scene. That is the need for the light stuff on it. I dremeled off unnecessary plastic and put every lightweight item on my car. I NEVER put the aluminum items on my car other than the alum center diff mount. It all adds up and helps.
This car hands down is one of the best and most consistant from track to track on the market,for the beginner and the pro.
Old 05-26-2008, 10:24 AM   #4387
rallyebmx's Avatar
Trader Rating: 21 (100%+)
I weighed my x1-cr buggy and a Losi 8ight yesterday. I have lipo and the Losi did not(3/4oz difference). Mine came in at 1 ounce lighter after an extensive diet this winter. siiick
rallyebmx is offline   Reply With Quote
Old 05-26-2008, 12:38 PM   #4388
How do you guys tame the rear end down
just taken delivery of mine massive thanks to hong nor (uk name for jammin) and ive used it once
brand new and straight to the a main fuel issues cost me though not a fan of gen 2
but to my issue the rear end keeps spinning out when i grab the throttle which was fun for about 2 mins,
ive got 25 20 in the shocks
5 5 2 in the diffs
i was considering laying the shocks down, other than that im open to suggestions
Megacrash is offline   Reply With Quote
Old 05-26-2008, 05:32 PM   #4389
JPMSRacing's Avatar
Location: Lost in the Dead Space between my Ears Somewhere around Wamego, KS (OZ Land)
depends on the track, in the central states, the common set up is 5-7-3 with Losi F40-Losi R30/32.5 shock oil and big holes in the pistons.
I'm around still!!!
JPMSRacing is offline   Reply With Quote
Old 05-26-2008, 07:44 PM   #4390
what are all you guys doing to lighten up your buggies beside the obvious outdrives and stuff.?
jammincrtracer is offline   Reply With Quote
Old 05-26-2008, 07:50 PM   #4391
for indoor high bite with my jammin i ran 5-7-3 for outdoors on a loose track i ran 4-6-2
Old 05-26-2008, 11:12 PM   #4392
Brilliant,
I assume those shock oil ratings are for the 16mm bb's
the track is dirt with a few jumps nothing big though
Ill play around with the diffs and see what i find ive also been advised to put the rear links on the lowest setting on the tower. Ill give that a go - just will be a pain to then have to reset all the settings for camber
Old 05-27-2008, 12:55 AM   #4393
ngo8's Avatar
Send a message via ICQ to ngo8
5 5 2 in the diffs
try 5/7/2
and maybe 37.5 front 30 rear also check the droop of your car it sounds like you dont have any as for the shocks for front top hole middle and inner hole the bottom and for the rear also the same should help also run the black clutch springs 1.0 i use this setup on black loose dirt and its pretty dialled
ngo8 is offline   Reply With Quote
Old 05-29-2008, 09:30 AM   #4394
Tabushi's Avatar
Send a message via AIM to Tabushi Send a message via Yahoo to Tabushi
Guys, do you know which othe brand of springs fit the 16mm big bore jammin shocks ?, do the Kyosho ST-RR Big Bore fit ?
Im looking for shocks that can fit the jammin shocks, but little longer specially on the front ...
thanks,
Patricio "PATO" Concha
E-Mail : [email protected]
Facebook : http://www.facebook.com/patoconcha
Whatsapp : +56 9 66165085
Tabushi is offline   Reply With Quote
Old 05-29-2008, 10:41 AM   #4395
speedy2's Avatar
I run the light yellow medium Kyosho buggy springs fr/rr
with the longer truggy HN rodends on my ocm
front HN original rod, rear ocm evo (MBXR) rods
I have just +1mm to the ajustment rings
arms below level/level fr/rr
//JQ The Car forever/ Soar //Protek-Ace-JR
speedy2 is offline   Reply With Quote
Jammin/Hongnor X1 - so close yet so far jono mad racer Nitro Off-Road 5 05-08-2011 06:40 AM
anybody close ????? slowpokeRRR Minnesota and North/South Dakota Racing 0 08-24-2007 10:21 PM
close please pwnzor R/C Items: For Sale/Trade 0 06-29-2007 12:40 PM
close Big B R/C Items: For Sale/Trade 0 02-02-2007 10:29 PM
please close racenut123 R/C Items: For Sale/Trade 1 04-30-2003 05:08 PM
