Old 03-07-2005, 08:46 AM   #421
Sgt_Morrow's Avatar
Aaron what clutch and springs do you use in your jammin?
Sgt_Morrow is offline   Reply With Quote
Old 03-07-2005, 10:48 AM   #422
Sofast-NT's Avatar
In front for sway bar
Sofast-NT is offline   Reply With Quote
Old 03-07-2005, 11:28 AM   #423
Sgt_Morrow's Avatar
So the Big Swaybar goes in the Front?
Old 03-07-2005, 11:43 AM   #424
The small swaybar goes in the front and the big in the back.
slrguy is offline   Reply With Quote
Old 03-07-2005, 01:36 PM   #425
Sgt_Morrow's Avatar
Ok guys make up yalls mind.
Old 03-07-2005, 02:19 PM   #426
Aaron Waldron's Avatar
Big one in the back, small one in the front.
I am running the stock shoes and LST 1.1 clutch springs. STUPID bottom end. Make sure the shoes rotate on the pins freely...you may have to drill or ream them out very slightly.
Aaron Waldron - LiveRC
www.liverc.com
Aaron Waldron is offline   Reply With Quote
Old 03-07-2005, 03:16 PM   #427
CAR
CAR's Avatar
Hi, I just picked up a Jammin pro buggy.The question I have will the optional one piece engine mount fit a O.S V-SPEC or a Collari? Thanks
CAR is offline   Reply With Quote
Old 03-07-2005, 03:27 PM   #428
bigl's Avatar
Trader Rating: 31 (100%+)
yes the one piece mount will fit any .21
bigl is offline   Reply With Quote
Old 03-07-2005, 06:08 PM   #429
Trader Rating: 15 (94%+)
Send a message via AIM to W.E.D.Jim
Aaron, have you or Adam tried other sway bars and tested them against each other? I picked up the optional ones, so I have all three and i'm wondering about a good combination to try for dry slightly sandy, tight, Florida tracks.....8), Jim
www.wedjim.com ...Closed down due to heavy work load I couldn't keep up with and maintain my primary job. But I'm still painting, just not with 40+ bodies waiting. :)
www.prolineracing.com
www.HarleyDavidson.com
"Nothing but the best!"
W.E.D.Jim is offline   Reply With Quote
Old 03-07-2005, 06:19 PM   #430
the buggyman's Avatar
Jim I have tried all three and have ended back up with the stock ones. I have asked this on the Grid before about the sway bars and I believe a lot of guys were running 2.6 in the back and around 2.0-2.3 in the front. I felt like I lost traction around corners (which may be good in tight corners, but I like to go off power a lot in the corner) in the rear with the bigger ones .
the buggyman is offline   Reply With Quote
Old 03-07-2005, 06:33 PM   #431
ultranewb's Avatar
Aaron, do you mean the stock shoes from the x1cr pro kit (alum.) or the black shoes? Also, am I getting it right when you say LST? Like the team losi lst? I'm just asking because you said you have stupid bottom end using that set up and I'd like to try it. Just want to make sure I get it right, Thanks.
Back Pocket Racing
Team Associated RC8
Team Associated SC10
ultranewb is offline   Reply With Quote
Old 03-07-2005, 07:31 PM   #432
Jeff, buggyman, ya I suspected that would be the case, but more input never hurts!
Usually, thicker means less roll, more consitency, but less traction............I was thinking about going to a thicker bar up front and leaving the back one, or even going thinner(if there is one?)......hmmmmm, I guess nothing is as good as trying it myself...but i'm usually not too good at begging for practice time at the races, LOL..........Jim
Old 03-08-2005, 01:36 AM   #433
Jim - I haven't tried any other bars. I'm sure Adam has tried more than a few, and the ones we're running are what he feels most comfortable with. I'm running the swaybar in the rear very loose, so it helps to weaken the effect a bit.
ultranewb - The stock aluminum clutch shoes, and yes, clutch springs from the Losi LST.
When I say stupid bottom end, I seriously mean nearly undriveable..haha. My car is nutty fast!
www.liverc.com
Old 03-08-2005, 02:55 AM   #434
Qlder's Avatar
Hello everyone , I am from Australia and we have our National Titles next week. It is on a grass track (our local track is clay) and I am wondering if anyone has any setup tips for grass. Also I have measured the tank and it appears we need almost 2 feet of fuel line to get to 125ml. Where do you put all that fuel line?
I have to say that this is the best 8th Buggy I have ever driven.
Regards Brad.
Qlder is offline   Reply With Quote
Old 03-08-2005, 09:48 AM   #435
CAR
CAR's Avatar
What's up with the shock mounts? I heard their is a replacement.
Jammin/Hongnor X1 - so close yet so far jono mad racer Nitro Off-Road 5 05-08-2011 06:40 AM
anybody close ????? slowpokeRRR Minnesota and North/South Dakota Racing 0 08-24-2007 10:21 PM
close please pwnzor R/C Items: For Sale/Trade 0 06-29-2007 12:40 PM
close Big B R/C Items: For Sale/Trade 0 02-02-2007 10:29 PM
please close racenut123 R/C Items: For Sale/Trade 1 04-30-2003 05:08 PM
