Old 02-10-2008, 04:03 PM   #4261
Trader Rating: 26 (100%+)
Send a message via AIM to cheesecake
well i ran the 16mm shocks today started off the oils 40 in the front 27.5 in the rear with silver springs. i ended up switching to the white springs and im going to be going down to 35 in the front 27.5 in the back for the next race as the front was too stiff and i lost alot of steering but it handled the jumps great i cant wait to get a good setup the buggy stays flat over the rough sections
cheesecake is offline   Reply With Quote
Old 02-10-2008, 04:08 PM   #4262
macnkitty2002's Avatar
yes they did have a set of 12 mm shocks those were stock on the x1 cr pro kits before the factory team was out.
which i still use with great success!
Team Associated RC10B4.2
Losi Rock Rey
macnkitty2002 is offline   Reply With Quote
Old 02-10-2008, 04:12 PM   #4263
do you ant to bnuy a set i have s set of 12mm shocks and a pro shocktower
Old 02-19-2008, 09:41 PM   #4264
rallyebmx's Avatar
Trader Rating: 21 (100%+)
Default Aluminum Shock Ball End Posts
Anybody have a part # for the 6061 aluminum Shock Ball End Posts for the 16mm shocks?
rallyebmx is offline   Reply With Quote
Old 02-19-2008, 10:12 PM   #4265
http://www.amainhobbies.com/product_...ducts_id/16935
Old 02-20-2008, 05:27 AM   #4266
rallyebmx's Avatar
Default Light 6061 aluminum Shock Ball End Posts
Thanks cheescake, but those are not the ones. I am looking for the light weight 6061 aluminum versions of those. Anybody have an OFNA part #?
Old 02-24-2008, 11:43 AM   #4267
Next question:
Anyone know if the Losi LiPo receiver pack will fit in the X1 CR tray? I measued and it seems like it would be a wrong fit. Not positive though.
Also, anyone know what decent LiPo batteries will fit into the CR tray?
Thanks,
Mike
MikeInCtown is offline   Reply With Quote
Old 02-24-2008, 02:57 PM   #4268
pink_sleeve's Avatar
Trader Rating: 163 (99%+)
How is the steering and durability of the X1X-CR? Can the car be drivin aggressively
pink_sleeve is offline   Reply With Quote
Old 02-24-2008, 03:12 PM   #4269
I have experience exceptional value from my CR. For the 3 years I have had it, I have only broken a single lower B block, which at the time was plastic and now all the kits come with aluminum units, and a shock body (it was really cold and the metal was rather brittle). It is tough as nails, and other buggies have broken when they collide with mine!
It does not steer quite as aggressively as other buggies that I have driven, but at the same time it is easy to tune it to steer well. Those other buggies take a lot of time to tune in, and most of them have a very narrow sweet spot in the handling department.
You can drive it very aggressively because it is very stable at all speeds. It will not throw a fit when you land poorly or enter a whoops section bad.
Losi Rock Rey
Old 02-24-2008, 03:17 PM   #4270
rallyebmx's Avatar
For a lipo reciever pack, HT batteries is great. Anybody have the part # for the 6061 ALUMINUM shock stand offs for the 16mm shocks???????
Old 02-24-2008, 05:13 PM   #4271
So I'm assuming the #41010 standoffs are not aluminum? The picture looks like plastic, but you sometimes can't tell in pictures. FWIW it looks like the pictures on eBay auctions are all the same as far as parts go. Do they make the aluminum ones yet?
Old 02-24-2008, 06:54 PM   #4272
has anybody on here actually bought the X1X-CR kit???
Old 02-24-2008, 07:54 PM   #4273
rallyebmx's Avatar
I think the 41010 are just the normal steel ones. This is what I am talking about:
Hong Nor is proud to release Light-Weight Shock Ball End Posts available for Big Bore Shocks.
The light-weight shock posts are CNC machined 6061-T6 aluminium with Hard-Coating.
The light-weight shock posts not only reduce the weight but also provide durability.
We are accepting orders for this new item now and the products can be shipped immediately
www.hongnor.com.tw
Old 02-24-2008, 08:10 PM   #4274
Copy and pasted into a translator and this is what it came up with for Chinese. (other languages didn't translate well)
The great wild goose company insisted that takes to you the best RC product.
Promotes the #391 aluminum alloy to shock proof the support newly, uses the high quality 6061-T6 aluminum alloy, to presents perfectly again by the CNC lathe processing. This section of new featherweight aluminum alloy shocks proof the support to be possible to reduce your 16mm large capacity shock absorber the weight, simultaneously increases the shock absorber the service life.
the #391 aluminum alloy shocks proof the support (4/packages) right now to go on the market!
Old 02-24-2008, 08:26 PM   #4275
rallyebmx's Avatar
Cool. Well, we'll see. I posted on the OFNA forum for a part #
Jammin/Hongnor X1 - so close yet so far jono mad racer Nitro Off-Road 5 05-08-2011 06:40 AM
anybody close ????? slowpokeRRR Minnesota and North/South Dakota Racing 0 08-24-2007 10:21 PM
close please pwnzor R/C Items: For Sale/Trade 0 06-29-2007 12:40 PM
close Big B R/C Items: For Sale/Trade 0 02-02-2007 10:29 PM
please close racenut123 R/C Items: For Sale/Trade 1 04-30-2003 05:08 PM
