Old 02-25-2005, 05:34 PM   #391
Send a message via AIM to MMor101
Are the front Universals the same as the rear universals?
MMor101 is offline   Reply With Quote
Old 03-01-2005, 11:56 AM   #392
Aaron Waldron's Avatar
barnracer - The best way to think about it..longer or higher rear link is stiffer, shorter or lower link is softer.
MMor - No, they're different lengths.
Congratulations to Jammin' team driver Adam Drake for qualifying third at this year's The Dirt Nitro Challenge, the biggest gas race EVER!
Aaron Waldron - LiveRC
www.liverc.com
Aaron Waldron is offline   Reply With Quote
Old 03-01-2005, 02:02 PM   #393
Default Center torsion diff
Where would this be an advantage?
slrguy is offline   Reply With Quote
Old 03-01-2005, 04:46 PM   #394
lmslms's Avatar
Default ride height
Do you set ride height by shock collor or with ride height screws in the a-arms?
lmslms is offline   Reply With Quote
Old 03-01-2005, 04:58 PM   #395
the buggyman's Avatar
the shock collars.
the buggyman is offline   Reply With Quote
Old 03-01-2005, 05:02 PM   #396
arghh's Avatar
so this a very good set-up..??
- longer / higher link (stiffer) is for front, to get more steering
- shorter / lower link (softer) is best on the rear can get more traction
arghh is offline   Reply With Quote
Old 03-01-2005, 05:26 PM   #397
A softer link in the front will give it more steering, but a longer link will smooth out steering for blue groove type tracks.
A stiffer link in the rear will help stop the rear from dumping in high speed corners and help the car rotate with corner speed. A softer rear link will go through bumps better and make the car square up exiting corners.
I went to a stiffer link in the rear (raised the inside of the rear camber link one hole) at the Nitro Challenge to help the car stay flat while exiting corners.
When I said higher, I meant higher only on the inside. Low on the outside or high in the inside = stiff High on the ouside or low on the inside = soft.
lmslms - The screws in the arms change your total downtravel, which is a completely different adjustment. Downtravel is often referred to as "droop"; those are droop screws.
slrguy - Did that clear up your question?
arghh - There's no magic setup..it's all about the track, your driving style, and the rest of your car setup.
www.liverc.com
Old 03-01-2005, 05:29 PM   #398
Trader Rating: 38 (100%+)
Aaron - how'd you do at the Dirt this weekend? Also, what happend to Drake in the main? I hear he got hacked a bit.
Breakin2 is offline   Reply With Quote
Old 03-01-2005, 08:18 PM   #399
lmslms's Avatar
AW / buggyman, I'm familiar with droop screws and the like. Some folks I've bumped into have a differing opinion, and I was looking for second opinions.
Old 03-01-2005, 11:44 PM   #400
arghh's Avatar
i know that X1CR caster is control by the arm holder A or B and can get a lot of steering with that.. anyway what do you think of using the 20 or 22 degree hub (convert using kyosho or hyper's c-hub). what would be happen with steering / handling
Old 03-02-2005, 12:06 AM   #401
Breakin - I was in the C-main..and had my share of bad luck. This was my first big race in 1/8th scale and my lack of experience showed..
..that said, such a performance at the Nationals in April would have qualified me for the Worlds, so I'm not too sad about it.
Drake ran well at the Nitro Challenge. His qualifying efforts were AWESOME, and he didn't do too bad in the main either. There was some paint-swapping, but it's all good.
arghh - Caster has its biggest effect on how the car enters and exits the corner. More caster makes the car turn in harder and have less steering coming out of the corner, and the opposite is true as well. I have been running the B block on my car and love it.
www.liverc.com
Old 03-02-2005, 04:54 AM   #402
Aaron - yeah, making the C was pretty good considering the competition. I found a list of the mains after I posted my question and I saw some pretty big names below you.
Old 03-02-2005, 06:41 AM   #403
No. I was asking about the new torsion diffs released for the Jammin, specifically the center diff and how well it works. I understand that the torsion diff almost locks up tight on full power and no lock off power. How well does this work using a center torsion diff with the front and back as regular diffs? Any advantage?
Old 03-02-2005, 10:19 AM   #404
Breakin - There were too many above me for my liking..haha. I'm working on that.
slrguy - Ooooh..haha.
I'm still relatively new to 1/8th scale but I'll give this one a shot; a center diff that locks up under power should help give the car more drive out of the corner, but it's going to hurt the car over bumps. When you're not on power and the diff "loosens" up, it should help the car go over bumps...I just don't know what that's going to do to off-power steering.
No one really runs Torsions anymore. Some of the Kyosho guys were running LSD's in the front to get steering, but that's about it.
www.liverc.com
Old 03-02-2005, 05:22 PM   #405
arghh's Avatar
what do you think of the standard downtravel.. is it enough or better to dremel the chassis droop screw tab and get more droop
Jammin/Hongnor X1 - so close yet so far jono mad racer Nitro Off-Road 5 05-08-2011 06:40 AM
anybody close ????? slowpokeRRR Minnesota and North/South Dakota Racing 0 08-24-2007 10:21 PM
close please pwnzor R/C Items: For Sale/Trade 0 06-29-2007 12:40 PM
close Big B R/C Items: For Sale/Trade 0 02-02-2007 10:29 PM
please close racenut123 R/C Items: For Sale/Trade 1 04-30-2003 05:08 PM
