Old 08-16-2007, 06:55 AM   #3856
BH
What all did you have to do to make em work?
BH is offline   Reply With Quote
Old 08-16-2007, 06:58 AM   #3857
they pretty much go in without any problems. you just need the drive cups that go onto the pinion. check the lengths tho cause hobao may have different dogbone lengths
Genius is offline   Reply With Quote
Old 08-16-2007, 08:30 AM   #3858
CRASH's Avatar
Trader Rating: 26 (100%+)
New Servo Saver Question?
Ok, I have misplaced my directions for this and I am not sure wear the thin shim goes and wear the thick shim goes. Does anybody know?
Thanks,
CRASH is offline   Reply With Quote
Old 08-16-2007, 08:31 AM   #3859
BH
Genius, only part # that I've been able to find for them is OFN28070 97MM AND 104MM
How does the dog bone stay center in the drive cups?
Old 08-16-2007, 02:13 PM   #3860
Panther's Avatar
Send a message via AIM to Panther
OFN19021 Center Drive Cup: Hyper 8
Thanks,
Silver shims are placed on top of the ackerman and the black ones are on the bottom.
Panther is offline   Reply With Quote
Old 08-16-2007, 05:25 PM   #3861
CRASH's Avatar
Thanks, I appreciate it.
Later,
Old 08-16-2007, 07:18 PM   #3862
thats the one.
you can put a little peice of fuel tube to keep the dogbone centered in the drive cups. I only put fuel tube towards the rear of the dogbone since thats the direction acceleration forces it towards. Leave enough play for the dogbones, you have to consider the amount of chassis flex.
Old 08-17-2007, 09:17 AM   #3863
BH
You the man Genius, Just how much lighter did they seem then the universal setup? I'm placing the order for the parts today.
Old 08-17-2007, 01:42 PM   #3864
Panther's Avatar
Hey guys,
I just recently installed a set of Losi 8ight shocks on my FTE car with some very encouraging results.
Shock Build: Since the pistons of the car is the same all the way around with the Jammin' Big Bores, I used 55 pistons in the Losi shocks since they are the middle piston choice. Fine tuning them will come later. I used 45wt Losi oil in the front and 35wt Losi oil in the rear. I had to use the Jammin long rod ends on both the front and rear of the car. Without them they won't work properly.
Springs: The stock springs you get with the kit won't work. You have to use the harder truggy spring to achieve proper ride height. I used the black springs in the front, which I had to screw the collar down quite a bit to acheive ride height. I used the Gray springs in the back which seemed to be perfect as I only had to screw the collar down in the back about 8mm to achieve proper ride height. I am going to have my LHS get me a set of the gray springs for the front and see how that works. I think that the Losi black springs will be a good choice for a blown out very rough track.
Overall: I was very pleased with the car. I noticed zero problems with the shocks. You do have to grind some of the shock tower material (both F&R) off to allow for clearance. Other than that, you can use all of the other jammin hardware when mounting the shocks on the car. The car definetly jumped and flew more consistant, as it was planted better on the track. I tested on a red-clay dry as a popcorn fart dusty/BUMPY surface. It absorbed the bumps alot better and made for a smoother more consistant run. Over all, until we find something out about the Jammin' BIG Bores these will fill the void if not work as a permanant fix for those of you who want the BIG Bore on the car without having to wait.
Once I clean the car, I will take some photos.
-Seann
Old 08-17-2007, 04:40 PM   #3865
Crocket's Avatar
sounds interesting Panther...can't wait for pictures
Crocket is offline   Reply With Quote
Old 08-18-2007, 10:18 PM   #3866
gguest's Avatar
the new Jammin big bore 16mm shocks should be available within a month or so. Already in production stage.
gguest is offline   Reply With Quote
Old 08-19-2007, 05:39 AM   #3867
Panther's Avatar
Sweet!
Old 08-19-2007, 10:16 AM   #3868
macnkitty2002's Avatar
is it really necessary to produce even bigger shocks? soon we'll all be using LST shocks!
Team Associated RC10B4.2
Losi Rock Rey
macnkitty2002 is offline   Reply With Quote
Old 08-19-2007, 10:20 AM   #3869
Panther's Avatar
Yes it is, I noticed an immediate difference on the car with them. It's a vast improvement over the stock ones. Don't dog something you haven't tried.
Old 08-19-2007, 12:50 PM   #3870
how do you already have access to them? and what i was trying to say is how can they improve on the 13mm when they are already so good? a bigger bore shock only provides more damping for larger jumps. but i guess that's what we need for our motocross style american tracks.
Losi Rock Rey
Jammin/Hongnor X1 - so close yet so far jono mad racer Nitro Off-Road 5 05-08-2011 06:40 AM
anybody close ????? slowpokeRRR Minnesota and North/South Dakota Racing 0 08-24-2007 10:21 PM
close please pwnzor R/C Items: For Sale/Trade 0 06-29-2007 12:40 PM
close Big B R/C Items: For Sale/Trade 0 02-02-2007 10:29 PM
please close racenut123 R/C Items: For Sale/Trade 1 04-30-2003 05:08 PM
