Old 08-07-2007, 02:24 PM   #3811
rregl0612's Avatar
Trader Rating: 33 (100%+)
a higher number of teeth on your spur equals a lower overall gearing wich gives you more bottom end....
a higer number on your bell gives you more top end.. .
End of story..
the larger gears turns less times to the bells single rotation.. equalling more torque...
example.... 1 turn on the 13 bell.. would equall.. 1/4 turn on a 48 tooth spur..
1 turn on a 13 bell would equal.. 1/16 of a turn on a 62 spur..
hope this helps...
rregl0612 is offline   Reply With Quote
Old 08-07-2007, 02:42 PM   #3812
Scottmisfits's Avatar
Isn't that exactly what I said?
Scottmisfits is offline   Reply With Quote
Old 08-07-2007, 02:51 PM   #3813
Panther's Avatar
Send a message via AIM to Panther
Yes, in layman's terms.
Panther is offline   Reply With Quote
Old 08-07-2007, 04:17 PM   #3814
prphze's Avatar
Thanks for every body's input. I guess what I am trying to achieve is more bottom coming out of the corners. My local lhs has a new track, that looks like a on road track with no straightaway. And the one straightaway isn't long enough to do anything.
Jammin X1 CR FTE
Novarossi Plus 21-7BT
King Headz
Kolor Koncepts
TARDO= Keyboard Commando
My Toy Car is Faster than Your Toy Car! Trust Me!
prphze is offline   Reply With Quote
Old 08-07-2007, 04:46 PM   #3815
rregl0612's Avatar
if you want more bottom.. and your running that plus 21 7 you have listed in your sig.....
You may want to look at a motor that doesnt rev so.... like a B3 (werks or collari) awesome botom end smooth but revs quickly .. I mean it spools up fast..
otherwise you could try to do some clutch mods.. if on a 3 shoe clutch..
Run 1.1 springs and cut about 1-2 mm off the ends that hold on the shoe.. ( I would try 1mm first...)... make sure all shoes are equall.. and be prepared for more clutch maintenance than with stock clutch...
You could also try to drill the aluminum shoes to lighten them...
just some thoughts..
BTW.. how do you like the Plus 7?
Old 08-07-2007, 04:49 PM   #3816
rregl0612's Avatar
possibly im not always the best at decifering what I read!!!
Old 08-07-2007, 05:06 PM   #3817
prphze's Avatar
Plus 7 is great. Thats not the motor I am running though. I have been running my v spec.
Jammin X1 CR FTE
King Headz
Kolor Koncepts
Old 08-07-2007, 07:12 PM   #3818
Jason Halvorson's Avatar
Trader Rating: 22 (100%+)
Send a message via AIM to Jason Halvorson Send a message via MSN to Jason Halvorson
Originally Posted by Frost99999 View Post
Any suggestions for decent priced servos?
i know some guys have had some problems with hitch servos, but im running them in my buggy and truggy and never have had a problem....5996 T/B, 5997 steering...
Jason Halvorson is offline   Reply With Quote
Old 08-07-2007, 07:16 PM   #3819
What would you guys consider the minimum torque and transit speed for steering and throttle servos?
I plan on racing at a few different tracks, but they are all pretty tight and dont have long straights. One track is like a 20 second lap or so, not sure about the other.
Im pretty sold on the Werks B3 as a motor, sounds inexpensive and good for tight tracks, which is pretty much 2/2 in my book
Frost99999 is offline   Reply With Quote
Old 08-07-2007, 07:20 PM   #3820
i like my T/B servos to be around 140oz in. at .10 speed...
as for the B3PRO thats a great choice for the short tracks...team it up with a JP1 pipe and its a killer low end combo...
Old 08-07-2007, 07:32 PM   #3821
Panther's Avatar
I use the JR 8800T on steering and the JR 8800S on throttle. Or just use the 8800T on both. If you don't plan on running on anything larger than the track described, then I would consider getting the Novarossi N21B 2001 BF It's one of those engines that will stay tuned all day long and be just as reliable. I know that the Werks engines have had some hiccups with the carburetors. I think that they have been corrected on the new Team Line edition engines.
-Seann
Old 08-07-2007, 07:36 PM   #3822
panther, yes the carb problem with the werks engines has been addressed, and werks has an all new 2 needle carb instead of the old collari 3 needle carb....
Old 08-07-2007, 07:43 PM   #3823
Will digital servos work with a standard FM radio? I have a JR radio, its an older XR3 FM.
Old 08-07-2007, 07:47 PM   #3824
yes they will....
Old 08-08-2007, 07:13 AM   #3825
jchas26's Avatar
I have just gotten into nitro RC offroad in the past 4 months. I am a long time electric RC plane guy so I know the value of not overdoing it out of the gate and asking for sage advice. I have really become interested in racing and I have a Jammin X1 RTR. I got this before the racing bug bit so I was wondering what would be the first things I should concentrate on upgrading should be? It has the stock .28 in it now and I don't want to break the bank on just an engine just yet, I would rather focus on better handling, durability, weight and such till I got better with the controls and actually started racing. Unless it would be wise to start with the engine.
Thanks,
J
jchas26 is offline   Reply With Quote
Jammin/Hongnor X1 - so close yet so far jono mad racer Nitro Off-Road 5 05-08-2011 06:40 AM
anybody close ????? slowpokeRRR Minnesota and North/South Dakota Racing 0 08-24-2007 10:21 PM
close please pwnzor R/C Items: For Sale/Trade 0 06-29-2007 12:40 PM
close Big B R/C Items: For Sale/Trade 0 02-02-2007 10:29 PM
please close racenut123 R/C Items: For Sale/Trade 1 04-30-2003 05:08 PM
