Old 02-20-2005, 10:10 PM   #361
arghh's Avatar
i wonder why all hongnor product (speed 9.5 / x1cr) stick with the standard 17 degree c-hub and no option 20 or 22 degree like the kyosho or hyper 7 have, so we can't play with caster.. i think the 20 / 22' hub got more advantage over the 3 position upper arm hinge pin hole system
arghh is offline   Reply With Quote
Old 02-21-2005, 09:11 AM   #362
lmslms's Avatar
Though, I've only had my kit running for about 4 weeks, I will say that I have used the B caster block, nearly exclusively. I put the A block on, and I did notice a difference, since I changed nothing else.
Caster measured at the hub vs caster measured at the hinge pin are two different things. If you increase (from 0 degrees) the caster at the hingepin you change how effective the whole front suspension is. A low caster maeasured by hingepin makes shocks appear stiffer, and reduces their effectiveness, good on fast smooth tracks. On rough tracks, helping to keep the shocks inline with bumps (sort of anlged into the bumps) will allow the shocks to more easily absorb bumps.
Basically, how a manufacturer develops their suspension is key, and if they go with C hub or hingepin style, the rest of the suspension is key, too.
If I were to guess, I would assume everyone would be running the B block, since it's easy to mimic the effects of the A block by moving shocks around and changing the servo from the transmitter.
lmslms is offline   Reply With Quote
Old 02-21-2005, 11:06 AM   #363
Send a message via AIM to MMor101
I think my tank is leaking my whole car is covered in fuel after a race. My pitman isnt that sloppy. I've heard theres an updated tank, is this true Aaron?
MMor101 is offline   Reply With Quote
Old 02-21-2005, 11:26 AM   #364
Sofast-NT's Avatar
My tank leaked around lid also. Contact Ofna, they will send you a new tank.
Sofast-NT is offline   Reply With Quote
Old 02-21-2005, 02:07 PM   #365
the buggyman's Avatar
Default tank
there is a new tank and it is almost white in color and not clear. also I got the tank from Ofna and it leaked around the adjustable top of the cap. If that is were it is leaking then some shoe goo will take care of it. My Jammin is down at the moment. Both servo saver mounts in the front snapped. I sent them back to Ofna and they said they would replace but I have none in the mean time.
AAron I was thinking of getting another x1-cr pro so I have two to avoid down time and to have the old for practice. If I get a new kit are they coming with the updated tank, motor mounts, and servo saver mounts?
the buggyman is offline   Reply With Quote
Old 02-21-2005, 03:04 PM   #366
Aaron Waldron's Avatar
buggyman - They should..at least, the very newest ones will. If there are any kits left over at the distributor or LHS they might have the old parts.
There is a new tank, and it's pretty tough.
Aaron Waldron - LiveRC
www.liverc.com
Aaron Waldron is offline   Reply With Quote
Old 02-21-2005, 03:14 PM   #367
Default Re: tank
Are you saying the new tank still leaks too? I havent had a problem with the servo saver mounts yet. Aaron do you use those little springs inbetween the calipers?
Old 02-21-2005, 03:35 PM   #368
my new tank didn't seal right so I shoe gooed it. I have another still in the package, havn't tried it yet. The springs inbetween the calipers work great. I wish other cars would use them.
Old 02-21-2005, 03:58 PM   #369
I'm not using the springs in between the calipers. I have the new discs but haven't put them on yet..the stock brakes have been great.
www.liverc.com
Old 02-21-2005, 08:37 PM   #370
lmslms's Avatar
Since it's been raining here so much, I took apart my CR for no real good reason except I couldn't run it with al the rain.
Anyway, I noticed my air filter is rubbing against the throttle servo linkage. Has anyone had this? I put the throttle link on the underside of the servo horn (vs the top) and it is really close to the rear brake disc. Has anyone run with the throttle linkage under the servo arm?
Last question, no springs on the brakes? I thought about chucking those springs during assembly, but I noticed there was a slight sticking of the brakes when I applied full brake and release to neutral. The sticking release as long as I rotated the spur with my finger. So I am sure the motor wouldn't have any problems. Has anyone seen sticking calipers?
I am really happy with the brake setup. For now I have the B type linkage. I started with the A, switched to B. The only modification I have done is add washers between the fuel tubing and the brake lever - I found my fuel tubing was too narrow and was getting jammed in the brake lever. I also added the 2mm adjust nuts from the A brake linkage to make sure the brakes were fully release at WOT.
Old 02-21-2005, 09:17 PM   #371
arghh's Avatar
Default Re: tank
day after day, there is plenty of weak and worse part are found in this car. so.. what do you think about this car's durability. thinking that my 9.5 pro are far more durable, after 2 years only front upper arm and front graphite shock stand broke
Old 02-21-2005, 10:13 PM   #372
argh - Everything has teething problems, especially in the first couple runs of production. The guys at OFNA are doing their best to change things as we go to make them better for the consumer.
Personally, my car has proven to be tougher than nails..
www.liverc.com
Old 02-21-2005, 11:04 PM   #373
arghh's Avatar
i think it is because of the two stage air filter, it is really too big and the bodyshell will push it down and hit the throttle linkage.. is it a must using this two stage air filter..??
Old 02-22-2005, 05:26 AM   #374
arghh, I have one of the early production cars. I know it has had minor problems, but Ofna has sent new parts for every problem for free. I have also read alot on the TTR S3 and it too is haveing minor issues and they are being worked out. All in All I am very pleased with the Jammin, and everytime I have raced it people come to me and comment how planted it looks. Also in regards to the filter, both my Mugen and Jammin do that.
Old 02-22-2005, 10:29 AM   #375
Sgt_Morrow's Avatar
What clutch springs and shoes are everybody using and where can i get them. Do you have part numbers for them.
Sgt_Morrow is offline   Reply With Quote
Jammin/Hongnor X1 - so close yet so far jono mad racer Nitro Off-Road 5 05-08-2011 06:40 AM
anybody close ????? slowpokeRRR Minnesota and North/South Dakota Racing 0 08-24-2007 10:21 PM
close please pwnzor R/C Items: For Sale/Trade 0 06-29-2007 12:40 PM
close Big B R/C Items: For Sale/Trade 0 02-02-2007 10:29 PM
please close racenut123 R/C Items: For Sale/Trade 1 04-30-2003 05:08 PM
