Old 07-07-2007, 12:12 PM   #3661
Jason Halvorson's Avatar
Trader Rating: 22 (100%+)
Send a message via AIM to Jason Halvorson Send a message via MSN to Jason Halvorson
i rather have alil rubbing than have a bunch of holes in my body...
Jason Halvorson is offline   Reply With Quote
Old 07-07-2007, 11:45 PM   #3662
RCRacing.com.au's Avatar
Lightbulb Holes in the body
I've never had to make any extra holes in any of my bodies and i've had about 4-5 now.
What type of linkage set-up you running?
Do you ahve the adjustable bias for the brakes?
I had some extra length on my rod (sounds like i'm bragging ) for the throttle so i cut it off instead of cutting the body.
Steve P
LCORCCC - Life Member
100 Cubic Inch Thumping V-Twin Victory Hammer 8-Ball!
-Stuff for sale-
CRT.5 - OS .12TZ (P) All reasonable offers Considered!
RCRacing.com.au is offline   Reply With Quote
Old 07-08-2007, 05:21 AM   #3663
SCUBA STEVE's Avatar
Trader Rating: 85 (99%+)
Same here, I've never had any problems like that... I think the Pl body fits perfect and I run a JP3 pipe.
SCUBA STEVE is offline   Reply With Quote
Old 07-08-2007, 01:57 PM   #3664
Lightbulb Body Shells
How low do you guys mount your Pipes?
I mount mine solid agains the plastic guard to make it lower cg.
I also put a piece of fine wire inside fuel tubing and tie it around the pipe so it doesn't fully bottom out on the guard.
It also stops the body from melting from the heat if it sits on the end of the pipe.
I got this trick from my CRT so the body doesn't melt on the pipe and i've since done it on my buggy.
Steve P
-Stuff for sale-
Old 07-08-2007, 02:23 PM   #3665
Panther's Avatar
Send a message via AIM to Panther
I had to do the fuel tubing trick to my PL body as well. I really didn't have any problems except for where the header bends around. It melted the body pretty good right there. I ran some tubing around the header and it fixed that.
On another note, I ran my first club race yesterday with my FTE car since trying the 8ight for six months. The 8ight is a great car in the right hands, but I could only get it right just a handful of times in that time period. So, it was time to switch back to the Jammin' car I had before the 8ight.
I put the new servo saver and the aluminum center diff mount on the car. I was skeptical on the center diff mount and it's price, but I was very impressed after I put it on the car. The brakes will only engage in one direction, that means there is no chance of them engaging at all when it's full throttle. Not only that, but it only takes 3mm of movement by the brake cams to fully engage the brakes. That means very little stress on the throttle/brake servo. The new servo saver gives the car mad steering, I actually had to turn down the EPA.
I couldn't of been happier with the car, for the first time in a long time I was comfortable with a RC Car and do with it what I wanted. I just need to get some of my driving habits I've gotten from 8ight and I'll be good to go
Panther is offline   Reply With Quote
Old 07-08-2007, 05:55 PM   #3666
AZRCaddict's Avatar
I hear the new servo saver makes the steering more consistent and prevents you from breaking your ackerman bearings. With the old one it actually raises the ackermen when the servo saver spring is on the bottom and puts stress on the flanged bearings. The new one doesnt put that stress on it.
Team EMB
AZRCaddict is offline   Reply With Quote
Old 07-08-2007, 05:58 PM   #3667
Panther's Avatar
That is good to know. I remember on my first car I went through bearing quite often. The steering on this car is butter smooth with the new ackerman unit.
Old 07-08-2007, 06:23 PM   #3668
Guys, What new part??
Old 07-08-2007, 06:31 PM   #3669
Panther's Avatar
http://www.amainhobbies.com/product_...ducts_id/11839
Old 07-08-2007, 06:40 PM   #3670
Panther, Thank you!...... does that just make it easier to adjust the servo saver ....... is there any performance gain out of it?
Old 07-08-2007, 06:48 PM   #3671
Panther's Avatar
No problem dude. IMO, I felt that the steering was a little more responsive with the new servo saver setup compared to the older setup. In our 20 min. main last night, the steering was the same all race long. I took apart the front end to inspect the ackerman bearings were in great shape. To me, it's worth the $13.00 to do it.
-Seann
Old 07-08-2007, 06:53 PM   #3672
Panther. I appreciate the help, I will order one tommorow!
Old 07-08-2007, 07:25 PM   #3673
Hi Guys,
Are there plastic chassis braces available for the X1CR?
Cheers
Andrew
Lycan is offline   Reply With Quote
Old 07-08-2007, 07:36 PM   #3674
Originally Posted by Lycan View Post
Hi Guys,
Cheers
Andrew
im sure they are....but why would you want them????i would upgrade to the cnc ones will stop the chassis from flexing, ive been running the ones from king headz....
http://www.amainhobbies.com/product_...oducts_id/7392
http://www.amainhobbies.com/product_...oducts_id/7390
Old 07-08-2007, 07:45 PM   #3675
Panther's Avatar
Hi Guys,
Cheers
Andrew
Here's the part #: OFN40539
It's on a plastic tree.
Jammin/Hongnor X1 - so close yet so far jono mad racer Nitro Off-Road 5 05-08-2011 06:40 AM
anybody close ????? slowpokeRRR Minnesota and North/South Dakota Racing 0 08-24-2007 10:21 PM
close please pwnzor R/C Items: For Sale/Trade 0 06-29-2007 12:40 PM
close Big B R/C Items: For Sale/Trade 0 02-02-2007 10:29 PM
please close racenut123 R/C Items: For Sale/Trade 1 04-30-2003 05:08 PM
