Old 06-18-2007, 02:47 AM   #3631
RCRacing.com.au's Avatar
New Shocks
Originally Posted by Jerseyboy View Post
The factory sent out a few prototypes a few months ago. We recieved one set but only one set of springs.
The shafts are the 3mm and pistons sizes 15mm. The shocks are different from the Losi's.
Weve tried it on the buggy and the truck. The springs suppied were the hard ones which suites the Truggy better. The shock definitely improves the handling over the rough stuff and jumping is better. Its too earlier to make any definite claims but I am confident its going to be an overall improvement in handling.
Our team rider will be racing his truck with these shocks at the SA Pro series in Newcastle this weekend.
I will let you know the results.
Why would they go from 3.5mm shafts to 3mm shafts?
They went to 3.5mm in the Big Bore's cause people were bending the 3mm ones on the X1-CR Pro.
I like the idea of bigger pistons and shock bodies though!
That's all i meant about the Losi 8ight shocks as they have 4mm shafts and i think the pistons are around 15mm too.
Let us know how they go please.
Steve P
LCORCCC - Life Member
100 Cubic Inch Thumping V-Twin Victory Hammer 8-Ball!
-Stuff for sale-
CRT.5 - OS .12TZ (P) All reasonable offers Considered!
RCRacing.com.au is offline   Reply With Quote
Old 06-18-2007, 04:32 AM   #3632
Jerseyboy's Avatar
Sorry typo. Its the standard shafts with bigger pistons and bodies.
Well the team ended up 3rd in the truggy finals of the RC Pro series. Truck stripped a diff so we lost some time. Shocks performed very well.
Jerseyboy is offline   Reply With Quote
Old 06-19-2007, 09:18 AM   #3633
Originally Posted by CRFXXXT View Post
Hey guy's, got a quick question.. or two.
I rebuilt my clutch (just took everything apart and gave it a good cleaning) and when I reassembled everything I noticed some play in the clutch bell.
Also, guy's that are running carbon shoes, are you running the little shim under each shoe/flywheel pin?
Dave
I have been running Mugen White shoes with 1.0's and use a small shim between the shoe and flywheel.
Also i like a small amount of end play in the CB.
I dont know if this clutch set up is the best but it works for me and has been very reliable.
Jammin"145 is offline   Reply With Quote
Old 06-22-2007, 11:50 AM   #3634
Mister-E's Avatar
Jammin and JP engine
Hi guys,
I'm a very content X1CR racer and running it in the hot environment of Dubai.
Since 1 year, the car has proven it's quality in the sandy track.
On the car, I'm running JP engine B5 which is using turbo glow plug and has runned 2 gallon of fuel now (25% nitro).
The plug I'm using is SH nr 8.
Somehow, after approx 6 tanks, the glow plug dies.
Any idea what to do?
Thanks a lot in advance with your feedback and keep up the informative thread!!!
Mister-E is offline   Reply With Quote
Old 06-22-2007, 03:24 PM   #3635
Smile
Originally Posted by Mister-E View Post
Hi guys,
Change the plug!!!
You need to 'Read' your plug.
If it goes black quickly then the motor is too rich.
If it makes the element go grey and distorted after one tank it is too lean.
The element should stay chrome for at least 2-4 tanks then it will start going grey.
I usually change mine every 6-10 tanks anyway.
The last thing you want it a broken element to go into yout motor.
Cheaper to change the plug than the piston & liner
The other thing is you shouldn't run a "SH" plug in a JP motor.
Do you know what SH stands for?
Anyway try running the equivelent in either a JP plug or Novarossi plug.
I run only Novarossi plugs in my Plus 21-5T and they have never failed me yet!
I can get 2-3 litres out of a plug if i kept using it.
They are way better quality than SH plugs, just like the engines are way better quality.
Steve P
-Stuff for sale-
Old 06-22-2007, 10:27 PM   #3636
Mister-E's Avatar
Thanks a lot for the advice Steve!!!
The engine is producing a "healthy trail of smoke" when I hit the throttle and also the "sound" of the engine is OK when screaming.
So I don't think that glow plug dies caused by to rich or lean although I'm trying to run it rich to protect the engine (Man, it's hot here!! Last time it rained was in February).
What I will do is try to get some Novarossi turbo nr 7&8 plugs.
BTW, what does SH means?? => please PM me on that
Old 06-23-2007, 09:32 AM   #3637
Jason Halvorson's Avatar
Trader Rating: 22 (100%+)
Send a message via AIM to Jason Halvorson Send a message via MSN to Jason Halvorson
Hi guys,
I would say to run a colder plug....the sh nr 8 is a medium temp plug....
Jason Halvorson is offline   Reply With Quote
Old 06-24-2007, 09:45 AM   #3638
Mister-E's Avatar
Hmmm, OK, SH nr 8 is a medium temp plug.
In the neighbourhood, the local HS has Novarossi and OS.
When looking to the temp characteristic of those plugs, can you please indicate what is the order of heat of those plugs.
On top is the hottest and at the bottom the coldest e.g.:
- SH 8
- Novarossi 8
- OS 8
Does the order also applies for plug nr 7??
Thanks a lot in advance for all the advices!
Old 06-24-2007, 09:49 AM   #3639
if you have access to os plugs try a os R5 or A5....
Old 06-24-2007, 05:50 PM   #3640
Smile Novarossi Plugs
- SH 8
- Novarossi 8
- OS 8
Hi again Mister E
Novarossi Plugs go like this:-
5 - Hot
6 - Medium
7 - Cold
8 - Very Cold
You can get them in a long & short body which means the fillament is either long or short.
The short fillament won't glow as hot as the long fillament so they are kind of like a half way between for example
C5TC Long fillament = hot
C5TF Short Fillament = Medium Hot
and so on...
I'd try running a C6TC or C7TC if it is really hot weather there.
I've changed to a C5TC as it's cold here now due to winter.
Hope this helps.
Steve P
-Stuff for sale-
Old 06-24-2007, 05:54 PM   #3641
X1-CR Chassis
Guys can anyone tell me what experience they have had with the Dragon Racing Chassis for the X1-CR FTE?
I've seen them selling on eBay and they look pretty well priced.
Otherwise what is the best aftermarket chassis i can buy that will wear longer & better than the original one?
Thanks guys.
Steve P
-Stuff for sale-
Old 06-24-2007, 07:08 PM   #3642
huskerfreak's Avatar
Thanks guys.
The best chassis is the original one. What do you me by longer wear?? The only thing that would wear would be the anodizing coming off the bottom from the chassis rubbing against the grown. Really if you are having any other problems like bending the chassis the best thing to keep this from happing is not to hit things.
huskerfreak is offline   Reply With Quote
Old 06-24-2007, 07:35 PM   #3643
Thanks guys.
here is what im running with great luck!!!!!! http://www.amainhobbies.com/product_...ducts_id/10108
Old 06-24-2007, 07:53 PM   #3644
Well it is time for me to post since I have had my first official rae day on my X1 FTE. I bought the car used from a local racer and I am glad I did. I managed to place fourth with it on a track that I have never ran on untill today. All my competition was against locals that had a lot of practice and racing on this track. All I have to say is that the car worked vary well. The track conditions were dry dusty rough with grooved up hard pack sections on the track. Needless to say you raced the track more than the competition.
After reading a lot of the posts here and looking at most of the different setups on the Jammin website it is nice that you can have a buggy that you didn't have to throw a bunch of after market parts at. The only thing that I ran on it was the grey Mugen springs and to tell the truth I like the jammin red springs just as well.
Old 06-24-2007, 08:37 PM   #3645
Huskerfreak, welcome to the Jammin family, we are here to help....yup the FTE is hooked up from the factory and ready to race....to tell ya the truth my X1CR started life as an rtr and after almost every King Headz part there is my X1CR is a killer ride....
Jason,
Jammin/Hongnor X1 - so close yet so far jono mad racer Nitro Off-Road 5 05-08-2011 06:40 AM
anybody close ????? slowpokeRRR Minnesota and North/South Dakota Racing 0 08-24-2007 10:21 PM
close please pwnzor R/C Items: For Sale/Trade 0 06-29-2007 12:40 PM
close Big B R/C Items: For Sale/Trade 0 02-02-2007 10:29 PM
please close racenut123 R/C Items: For Sale/Trade 1 04-30-2003 05:08 PM
