Old 04-30-2007, 12:36 PM   #3496
Trader Rating: 44 (100%+)
oh ok lol
T5M 7.5
22 3.0 7.5
SickWitiTRacing(Jayson)
NitroLuver is offline   Reply With Quote
Old 05-01-2007, 06:25 AM   #3497
where is the best place to purchase cheap rubber sealed bearings from? i'd like a kit for the jammin but i don't want to spend a fortune. i'd rather just buy 2 sets and replace the bearings as needed.
also, last time i replaced bearigns i purchased metal sheilded bearings and took the metal sheilds out and used my old rubber seals anyone ever done this before? just wondering how many times i can do this before the rubber seal kicks the bucket ...yeah i know, its the "el cheapo" method.
TomB is offline   Reply With Quote
Old 05-01-2007, 06:44 AM   #3498
macnkitty2002's Avatar
if the back of the rubber seals are still intact and not torn (metal exposed), then you can still use them. try www.carolinasrc.com for bearings. go to accessories i think.
Team Associated RC10B4.2
Losi Rock Rey
macnkitty2002 is offline   Reply With Quote
Old 05-01-2007, 12:50 PM   #3499
AZRCaddict's Avatar
Boca Bearings has some great bearings and has a 99 cent store now too. The econo (cheapest) bearing kit for the X1CR http://bocabearings.com/main1.aspx?p...885&n=*46A-110
Team EMB
AZRCaddict is offline   Reply With Quote
Old 05-01-2007, 01:57 PM   #3500
Noah R.'s Avatar
Just a question but what tires will work well on a track that has high grip
Noah R. is offline   Reply With Quote
Old 05-01-2007, 03:00 PM   #3501
Scottmisfits's Avatar
Try an M2 Crimefighter or Bowtie.
Scottmisfits is offline   Reply With Quote
Old 05-02-2007, 10:03 AM   #3502
blanks596's Avatar
Trader Rating: 14 (100%+)
anyone know the weight difference between stock tie rods and the titanium ones. Also weight difference between stock fte chassis and upgrade?
Serpent/Desoto Racing
Max S
blanks596 is offline   Reply With Quote
Old 05-02-2007, 09:17 PM   #3503
don't bother dude, the stock team edition tie rods are just as good. i started of with a jammin x1cr team kit as a totally buggy beginner and i haven't bent any.
the weight saving would be minimal, you'd be better off going with a full lightweight screw kit, and ceramic bearings as opposed to just the turnbuckles. the turnbuckles also cost a arm and a leg man!
Old 05-03-2007, 07:23 AM   #3504
Jerseyboy's Avatar
Originally Posted by Crocket
Hi Scuba Steve
I am currently using the Big Bore Mugen grey springs and have found them to be softer than the Jammin Red.
The Jammin Red spring rates are
Front - 0.77 N/mm
Rear - 0.61 N/mm
The Mugen Grey BB springs are
Front - 0.71 N/mm
Rear - 0.58 N/mm
The lower the number the softer the spring.
Here is a link to a web site that you may be interested in.
http://www.nitrohouse.com/tip_spring_chart.htm
Going by the website the Mugen Grey BB springs are rated identically to the Jammin Soft Yellow springs.
Cheers.........Dave
Hi Crocket
What was the main differences you found with the Mugen grey versus BB red springs. ie handling wise.
Jammin X1 FTE
Upgraded to Warp Drive
KO Mars Ex-1 Spectrum Telemetry
Jammin JPX 21/OS Speed
Jammin X1 CRT
Go tech 21 5p
Upraded to Stelar Galactic
Jammin X1 CRT.5
Power by SH12
Either your Jammin or losing"Catch me if you can"
Team Dramatic
Jerseyboy is offline   Reply With Quote
Old 05-03-2007, 12:06 PM   #3505
Crocket's Avatar
Smile
Originally Posted by Jerseyboy
Hi Crocket
Hi Jeseyboy,
The track I race on needs a bit of maintenance and has been getting quite cut up and rutted so I was looking for a softer spring that would ride the bumps better, the HongNor red springs made the car jump around too much. I found the Mugen Grey spring to be softer which absorb the ruts better, making the car a lot more predictable.
Crocket is offline   Reply With Quote
Old 05-03-2007, 10:56 PM   #3506
Jerseyboy's Avatar
Hi Jeseyboy,
Yes Crocket I have the same problem. Our track is also deteriating badly and the reds makes the buggy jump around alot. The yellow seems to become compressed later in the race ie the ride height changes as the day progresses. Its like the springs lose its tension.
Jammin X1 FTE
Jammin X1 CRT
Go tech 21 5p
Jammin X1 CRT.5
Power by SH12
Team Dramatic
Old 05-04-2007, 01:28 AM   #3507
Crocket's Avatar
I dont think it is the Springs loosing tension. Do you run on a dry dusty track?
I have found that the rear suspension tends to bind up over the day and causes the handling to change. I dont think this is an X1CR issue as most cars are effected by dusty tracks.
I think the guys that are fitting the Pivot Ball front suspension will have even worse issues on dusty tracks because as the suspension binds it not only effects the handling but simply by design it is going to also bind the steering response.
Old 05-04-2007, 02:01 AM   #3508
jfc_tech's Avatar
Send a message via Yahoo to jfc_tech
long time didn't come here... so whats your guy been doing?
Crocket, any video to share with the RC Nitro Blog ?
If you are in front of me, That's because I let you!
jfc_tech is offline   Reply With Quote
Old 05-04-2007, 05:09 AM   #3509
Jerseyboy's Avatar
Guys check what the cat dragged out the bag.
Joneh! whazup. Where you been. Making babies I presume lol
Jammin X1 FTE
Jammin X1 CRT
Go tech 21 5p
Jammin X1 CRT.5
Power by SH12
Team Dramatic
Old 05-04-2007, 07:53 AM   #3510
dido41's Avatar
I have a question on filter oil. I have 2 different oils and was wondering what oil would be better to use. First is the Fluidz spay-on filter oil that seems a little thin. Second is the
Associated foam treatment that is thicker and stickier. The tracks I run on are dusty, some sand and some clay.
from what i here i should use the Fluidz thin oil on the pre filter and the ae oil on the main filter. is this the best way?
dido41 is offline   Reply With Quote
Jammin/Hongnor X1 - so close yet so far jono mad racer Nitro Off-Road 5 05-08-2011 06:40 AM
anybody close ????? slowpokeRRR Minnesota and North/South Dakota Racing 0 08-24-2007 10:21 PM
close please pwnzor R/C Items: For Sale/Trade 0 06-29-2007 12:40 PM
close Big B R/C Items: For Sale/Trade 0 02-02-2007 10:29 PM
please close racenut123 R/C Items: For Sale/Trade 1 04-30-2003 05:08 PM
