Old 04-24-2007, 08:29 AM   #3466
Takt's Avatar
Trader Rating: 15 (100%+)
Originally Posted by Jerseyboy
My setup:
Front
B-block
Shock length 102mm
50wt Ofna oil
#54 pistons.
Inside on the arm, middle on the tower.
Upper arm middle, ackerman middle hole.
2 degrees negative camber, slight toe-out.
Stock sway-bar
Rear
3.5 degree toe block, 1 degree anti-squat
Shock length 125 mm
40wt ofna
#54 pistons
Shocks middle on the tower, inside on the arm
Camber link outside hole on hub, drilled in the tower (more on this later)
Stock sway-bar
Diff oils f/c/r 5K/7K/2K
First off, you need to get your diffs right. Keep 5K in the front, put 7K Center, and 2K in the rear. If you go higher in the rear, you'll get more on-power steering but a "looser" car when giving throttle.. Also, try to go with the 2.5 rear toe-in to get more steering in general.
Thank you very much! I'll set it up tonight. I appreciate the help!
Takt is offline   Reply With Quote
Old 04-24-2007, 09:01 AM   #3467
SKOT's Avatar
Originally Posted by wd40prerunner
ya thats me that funny. are you racing this weekend
No racing for me this weekend because of this...
Jammin X1 CR FTE Roller $285 Shipped
I'll be down for a couple of weeks until I get my new kit and get it all built. I can't wait!
SKOT is offline   Reply With Quote
Old 04-24-2007, 11:31 AM   #3468
blanks596's Avatar
Trader Rating: 14 (100%+)
Default diff question
Lets say my diff looks like this: 5front, 7middle, 2 rear. What would increasing the middle to 10k do to the car.
Serpent/Desoto Racing
Max S
blanks596 is offline   Reply With Quote
Old 04-24-2007, 04:38 PM   #3469
AZRCaddict's Avatar
More all-wheel drive effect
Better acceleration
Increases on power steering (reduces understeer)
Better suited on high-bite, smooth tracks
Car can be nervous to drive especially if a high power engine is used - you might need to be smooth on the throttle
Team EMB
AZRCaddict is offline   Reply With Quote
Old 04-24-2007, 05:04 PM   #3470
Crocket's Avatar
It would make it harder to drive on most tracks - more of a chance of oversteering exiting corners.
The lighter you go with the middle diff oil the more power that gets transfered forward under acceleration. This is because the as cars weight is transfered to the rear under acceleration the middle diff finds it easier to transfer the engines power to the front wheels as there is less resistance. - This can be good for loose tracks as the front wheels tend to pull you out of the corners reducing the chance of a spin.
The thicker the middle diff oil the less effect weight transfer under accelleration effects the power transfer making the car more 4WD. - This will increase aceleration on a high bite track (where spining out is less of an issue) as all 4 wheels are driving.
Having your middle diff set too light may also cause your front tyres to wear faster and possibly balloon up on the straights (more of an issue with Truggies)
Just my $0.02
Crocket is offline   Reply With Quote
Old 04-24-2007, 05:21 PM   #3471
AZRCaddict's Avatar
Sleeve of my Jammin .21 after being modded by RJ Mods.net Going to ripppp!
Team EMB
Old 04-24-2007, 06:21 PM   #3472
RCRacing.com.au's Avatar
Thumbs up CRT.5
Originally Posted by Jammin&quot View Post
I just got my CRT .5w/ O.S .12 TG today!! Cant wait to get home and put it together.
Mate let me know how you go with it please.
I've got an OS TZ.12 (P) for mine so it should be balistic!
Just wondering what would be the best servos to use for it as the ones recomended in the manual are only around 1kg torque?
What are you going to use for servos?
Steve P
LCORCCC - Life Member
100 Cubic Inch Thumping V-Twin Victory Hammer 8-Ball!
-Stuff for sale-
CRT.5 - OS .12TZ (P) All reasonable offers Considered!
RCRacing.com.au is offline   Reply With Quote
Old 04-24-2007, 07:11 PM   #3473
macnkitty2002's Avatar
http://www.rcuniverse.com/forum/m_34...owhatan/tm.htm
scroll through the pictures if you want to see the first race of the tournament that i TQed at and won! scroll down a bit in the thread to see them. i am the one in the turquois shirt and sunglasses, and my car has the big #2 on the front as in my avatar. i will get a podium shot soon.
Team Associated RC10B4.2
Losi Rock Rey
macnkitty2002 is offline   Reply With Quote
Old 04-24-2007, 09:49 PM   #3474
Default CRT .5 Servos
Well I went with the Hitec's.
HS-5245MG for steering and
HS-225MG for throttle
I got to run 1.25 tanks for break in tonight(in the driveway,not track use)
I had my end points dialed and the brakes backed way off and the 225MG died on me : not even 1-1/2 tanks of run time.Not impressed.I have read the JR's are better but are alot more$$.Maybe worth it.We will have to see how the 5245MG holds up for steering.Probably will get another 5245 to start.
The TG seemed decent just the little i ran mine,it was still way fat.My buddies(TG also) which is more broken in looks plenty fast.Track time will tell.I like so far,except for the 225MG servo.
Jammin"145 is offline   Reply With Quote
Old 04-25-2007, 12:58 AM   #3475
Jerseyboy's Avatar
Mankitty
You have a SP2 and a Jammin. Can you Please check if the drivesahfts of the Kyosho will work on the Jammin X1.
What is the lengths of the
Centre driveshafts, rear and front shaft. If you can the total length end to end. Thanks man
Jammin X1 FTE
Upgraded to Warp Drive
KO Mars Ex-1 Spectrum Telemetry
Jammin JPX 21/OS Speed
Jammin X1 CRT
Go tech 21 5p
Upraded to Stelar Galactic
Jammin X1 CRT.5
Power by SH12
Either your Jammin or losing"Catch me if you can"
Team Dramatic
Jerseyboy is offline   Reply With Quote
Old 04-25-2007, 06:13 AM   #3476
hey jerseyboy,
i do not have the SP2 777, only the standard chassis, so the driveshafts are not the same length. however i will still check and see if the driveshafts fit. i believe that Kyosho driveshafts are better than the Jammin ones.
Losi Rock Rey
Old 04-25-2007, 06:16 AM   #3477
Jerseyboy's Avatar
hey jerseyboy,
Thanks Mate. I believe the outdrives of the Kyosho are the same. If the driveshafts work I will replace mine with the K's. They last forever.
Jammin X1 FTE
Jammin X1 CRT
Go tech 21 5p
Jammin X1 CRT.5
Power by SH12
Team Dramatic
Old 04-25-2007, 08:37 AM   #3478
well that's for sure, ensuring that you are using dogbones. however, i am not sure if the 777 unis and the Jammin unis are the same length.
Losi Rock Rey
Old 04-25-2007, 06:17 PM   #3479
pictures from my TQ and 1st place finish.
Jammin X1 - so close yet so far-az86220.jpg   Jammin X1 - so close yet so far-eq78813.jpg   Jammin X1 - so close yet so far-ey70605.jpg   Jammin X1 - so close yet so far-hb80993.jpg
Losi Rock Rey
Old 04-25-2007, 06:18 PM   #3480
more.
Jammin X1 - so close yet so far-hc94174.jpg   Jammin X1 - so close yet so far-hf99875.jpg   Jammin X1 - so close yet so far-qc38774.jpg   Jammin X1 - so close yet so far-us53947.jpg
Losi Rock Rey
Jammin/Hongnor X1 - so close yet so far jono mad racer Nitro Off-Road 5 05-08-2011 06:40 AM
anybody close ????? slowpokeRRR Minnesota and North/South Dakota Racing 0 08-24-2007 10:21 PM
close please pwnzor R/C Items: For Sale/Trade 0 06-29-2007 12:40 PM
close Big B R/C Items: For Sale/Trade 0 02-02-2007 10:29 PM
please close racenut123 R/C Items: For Sale/Trade 1 04-30-2003 05:08 PM
