Old 04-23-2007, 01:39 PM   #3451
I couldn't get on their (Jammin)site either today.
You will see most of the set ups on there run 5-7-2 diff oils in the buggy.
I am no genius to this either but that is what I have been running and it seems fine. stock is 3-5-1.
I just got my CRT .5w/ O.S .12 TG today!! Cant wait to get home and put it together.
Jammin"145 is offline   Reply With Quote
Old 04-23-2007, 02:32 PM   #3452
Takt's Avatar
Trader Rating: 15 (100%+)
Its back up and working.
Thanks!
Takt is offline   Reply With Quote
Old 04-23-2007, 02:59 PM   #3453
wd40prerunner's Avatar
Trader Rating: 8 (79%+)
Originally Posted by SKOT
Hey wd40prerunner - where do you usually run at? I'm in Vegas too. I usually race at Finishline on Saturdays.
hey i just raced there on sat. i just got this that was my first gas race ever.
wd40prerunner is offline   Reply With Quote
Old 04-23-2007, 03:01 PM   #3454
[QUOTE=RCRacing.com.au]How's the Jammin Motor go for power and reliability?
the jammin motor is fast as crap and has not gave me any problems.
Old 04-23-2007, 03:27 PM   #3455
SKOT's Avatar
Is that Greg Antill's old truggy? If so I'm the guy who you let drive it after the race was over.
SKOT is offline   Reply With Quote
Old 04-23-2007, 04:34 PM   #3456
AZRCaddict's Avatar
The .21 also
Team EMB
AZRCaddict is offline   Reply With Quote
Old 04-23-2007, 07:06 PM   #3457
Paradoxmaker's Avatar
Originally Posted by Takt
Hey all --
I searched this thread to find a good setup, and I see quite a few links to:
http://www.jamminproducts.com/setups.htm
However, when I try to go to the site, I get an error (including when I go to jamminproducts.com). Is anyone else having this problem?
I just bought the X1 and pretty new to nitro. I don't understand the different diff fluid combinations, and need something to start with.
No problems for me going to that site....
Paradoxmaker is offline   Reply With Quote
Old 04-24-2007, 01:01 AM   #3458
ya thats me that funny. are you racing this weekend
Old 04-24-2007, 01:12 AM   #3459
Jerseyboy's Avatar
I am still playing around looking for the ideal shock oil setup.
I tried red springs 60F 40R work well but not so good on very rutted and loose tracks.
Now using 50F 40 rear. Red springs.
Any of you guys tried other setups?
Jammin X1 FTE
Upgraded to Warp Drive
KO Mars Ex-1 Spectrum Telemetry
Jammin JPX 21/OS Speed
Jammin X1 CRT
Go tech 21 5p
Upraded to Stelar Galactic
Jammin X1 CRT.5
Power by SH12
Either your Jammin or losing"Catch me if you can"
Team Dramatic
Jerseyboy is offline   Reply With Quote
Old 04-24-2007, 01:51 AM   #3460
45fr/35rr works well on rutted tracks. The lighter oil also improves traction. The red springs should be fine with this oil combination. This is also one of the combinations that Taylor James likes.
Check out the setup sheets on the Jammin' site
8ightScale/CJP is offline   Reply With Quote
Old 04-24-2007, 01:57 AM   #3461
Crocket's Avatar
Hi Jerseyboy,
I am racing on a rutty, loose track and have found that this setup works rather well.
Big bore shocks
45W Front - 35W Rear
With Mugen Grey springs (I think they are identical to the HN Yellow springs)
Cheers...........Dave
Crocket is offline   Reply With Quote
Old 04-24-2007, 03:08 AM   #3462
Jerseyboy's Avatar
Originally Posted by Crocket
Hi Jerseyboy,
Big bore shocks
Thanks Guys
I am using 50F red spring and 40R yellow spring. Still just not getting it down like I want.
I'll try 45-35 with red and then yellow.
The Mugen greys according to Chad is in between Jammin red and yellow. He also specifies that the Mugen grey has a more constant spring rate than the red.
Jammin X1 FTE
Jammin X1 CRT
Go tech 21 5p
Jammin X1 CRT.5
Power by SH12
Team Dramatic
Old 04-24-2007, 06:13 AM   #3463
Takt's Avatar
So being new to all this, what is suggested to purchase as tuning parts?
What spring rates (or what manufacturer / color)?
Diff Oils?
Camber blocks or toe plates?
Etc.
I'm not going to buy everything, so the top suggestions would be appreciated.
I'm going to probably race on one track mainly, but travel to a couple others for a series race.
Old 04-24-2007, 07:15 AM   #3464
Jerseyboy's Avatar
Diff Oils?
Etc.
My setup:
Front
B-block
Shock length 102mm
50wt Ofna oil
#54 pistons.
Inside on the arm, middle on the tower.
Upper arm middle, ackerman middle hole.
2 degrees negative camber, slight toe-out.
Stock sway-bar
Rear
3.5 degree toe block, 1 degree anti-squat
Shock length 125 mm
40wt ofna
#54 pistons
Shocks middle on the tower, inside on the arm
Camber link outside hole on hub, drilled in the tower (more on this later)
Stock sway-bar
Diff oils f/c/r 5K/7K/2K
First off, you need to get your diffs right. Keep 5K in the front, put 7K Center, and 2K in the rear. If you go higher in the rear, you'll get more on-power steering but a "looser" car when giving throttle.. Also, try to go with the 2.5 rear toe-in to get more steering in general.
Jammin X1 FTE
Jammin X1 CRT
Go tech 21 5p
Jammin X1 CRT.5
Power by SH12
Team Dramatic
Old 04-24-2007, 08:04 AM   #3465
Bulldawg RC's Avatar
Trader Rating: 65 (99%+)
anyone ever try using this set up with the ofna aluminum clutch shoes. i used 1 black and 2 gold springs. will i have issues with this? thanks
Bulldawg RC is offline   Reply With Quote
Jammin/Hongnor X1 - so close yet so far jono mad racer Nitro Off-Road 5 05-08-2011 06:40 AM
anybody close ????? slowpokeRRR Minnesota and North/South Dakota Racing 0 08-24-2007 10:21 PM
close please pwnzor R/C Items: For Sale/Trade 0 06-29-2007 12:40 PM
close Big B R/C Items: For Sale/Trade 0 02-02-2007 10:29 PM
please close racenut123 R/C Items: For Sale/Trade 1 04-30-2003 05:08 PM
