Old 04-15-2007, 09:38 PM   #3421
nitroveins's Avatar
Originally Posted by arghh
why losi like to eat throttle servo..?? my jammin didnt like to eat servo..hehe
don know the first one was 359z that wasnt even mine, dang it, and the other wasnt high dollar servos but they worked fine, might of got a maximum of four tanks without burning one up
nitroveins is offline   Reply With Quote
Old 04-15-2007, 10:06 PM   #3422
Trader Rating: 44 (100%+)
the losi has to be set correctly both with the linkage and the epa...lol i blew up a servo in my buggy it was the 357 from airtronics and re adjusted and am running a cheapo airtronics servo and haven't had problems at all lol...
on the other hand went to the track today and set up some hot laps and now i need to go through and fill with thread lock and sucH
T5M 7.5
22 3.0 7.5
SickWitiTRacing(Jayson)
NitroLuver is offline   Reply With Quote
Old 04-16-2007, 06:02 AM   #3423
blanks596's Avatar
Trader Rating: 14 (100%+)
Can anyone help? I'm running the x1cr pro and not the FTE. I've upgraded most parts, except the 5mm shock towers. After attaching the big bore shocks, I noticed that they rub the front upper A-arms if I set them too vertical. can anyone explain this or have had similar experiences?
Serpent/Desoto Racing
Max S
blanks596 is offline   Reply With Quote
Old 04-16-2007, 06:33 AM   #3424
The Big Bore shocks have the bigger springs, so the 5mm thick towers give you a little xtra space between the spring and the arm. I run the Pro also and with the stock shocks and towers, the springs are right next to the upper arms. If you're not getting the 5mm towers, try puttings spacers or thin washers at the upper shock mount to move them forward away from the upper arms. I'm sure a few mm's will give you're springs enough clearance. That might solve the problem, maybe not.
BTW...if you try the washers or spacers, just use enough to equal a total thickness of 5mm. If your springs still hit, you'll know it's not because you don't have the 5mm towers. Don't forget to put the washers on the front side of your towers.
8ightScale/CJP is offline   Reply With Quote
Old 04-16-2007, 07:34 PM   #3425
macnkitty2002's Avatar
i tested my P&P today. it was cold and windy, and my baby was topless, so i can't make any real conclusive results. however, i did notice a slight gain in mid-range "pick-up", and the powerband appeared to be a little smoother. i can't say that it did a lot, but it was my first time grinding. i am rather proud of what i can do, now i just need some better bits to get into those tight areas to do some better grinding.
Team Associated RC10B4.2
Losi Rock Rey
macnkitty2002 is offline   Reply With Quote
Old 04-16-2007, 07:39 PM   #3426
how did you like the s5 before hand?
T5M 7.5
22 3.0 7.5
Old 04-17-2007, 05:19 AM   #3427
i thought it was a great engine before and now it's even better. before the P&P, I was getting amazing run times because it's only 5 port and i run the JP-1, so I knew I could tap into that reserve in order to make room for better mid or top range power. Polishing the whole lot certainly smoothes out the powerband, and that is something anybody can do. however, i still did not notice much increase on the top end, but that is most likely because of the JP-1 I have hooked on her. I run a short track anyways, so top end doesn't really come into play.
Losi Rock Rey
Old 04-17-2007, 08:50 PM   #3428
Trader Rating: 18 (100%+)
Send a message via Yahoo to infanterene
Hey macknkitty2002- How would you compare your jammin and the Kyosho? I have a Losi and an SP2wc. I wish I could take the steering, jumping from the losi and the durability, stability of the kyosho and put them together.
I have heard that the jammin is basically a Kyosho with 17 degree caster.
Anybody else run both a jammin and a Kyosho or Losi.
infanterene is offline   Reply With Quote
Old 04-18-2007, 05:20 AM   #3429
honestly, my 777 has not been run that much because the Jammin is the main race car, the 777 is merely a back up. it does not have nearly the amount of hop-ups as my X1 has, and the gear on it is a step lower than the Jammin's.
the 777 does jump like a champ, never seems to get out of shape, and takes a ton of abuse. however, it can be squirrely at times, and it's a little frustrating to tune the chassis to just how you want it. from my experience, the 777 never feels right until you hit that exact spot-on setup for the day, they it drives like a dream. but getting to that sweet spot can be a real pain, like tuning a Novarossi engine. moreover, just when you've found that sweet-spot, the track either changes or the race day concludes and the next time you go out racing you have to start all over again to try to find that sweet-spot.
my Jammin, on the other hand, feels a little more "numb" to tuning changes. basically, it does not respond as well to inputs, but it also it not very finicky in how it's tuned. seems to run the way you want it too, you just may have to change your driving style a bit. also, from day to day, the setup does not get all out of whack like the 777.
and perhaps the most important aspect of it all, the parts and support for the Jammin is unparalleled, and Kyosho parts are hard to come by sometimes and they are expensive at that.
these are just my 2 cents, and do not represent the opinions of anybody but myself.
Losi Rock Rey
Old 04-18-2007, 06:25 AM   #3430
blanks596's Avatar
Thanks for your help. Also, what is the benefits of the torsen diff and how does it work?
Max S
Old 04-18-2007, 07:29 AM   #3431
Jerseyboy's Avatar
Originally Posted by DUB_Ben
Hey guys, I was just wondering if this was the place to post about the CRT. I run mine with a RB 928. Im racing it for the first time tomorrow.
From what Ive heard the 928 is a monster of an engine. I dont think I have the fingers for that beast
Jammin X1 FTE
Upgraded to Warp Drive
KO Mars Ex-1 Spectrum Telemetry
Jammin JPX 21/OS Speed
Jammin X1 CRT
Go tech 21 5p
Upraded to Stelar Galactic
Jammin X1 CRT.5
Power by SH12
Either your Jammin or losing"Catch me if you can"
Team Dramatic
Jerseyboy is offline   Reply With Quote
Old 04-18-2007, 11:38 PM   #3432
Jerseyboy's Avatar
Latest X1 upgrades. Available now.
Jammin X1 - so close yet so far-x1s-57.jpg   Jammin X1 - so close yet so far-x1s-58.jpg
Jammin X1 FTE
Jammin X1 CRT
Go tech 21 5p
Jammin X1 CRT.5
Power by SH12
Team Dramatic
Old 04-19-2007, 06:01 AM   #3433
what are those, 6mm?
Losi Rock Rey
Old 04-19-2007, 06:19 AM   #3434
Jerseyboy's Avatar
The new shock towers are CNC machined from a thicker 5mm aircraft
grade 7075 plate and hardened to T6.
The towers are then Hard-Coated with our special material for wear and durability.
The front tower now has multiple half holes at the top and 3 mounting holes at the bottom.
The rear towers have half holes at the top and an extra row on the bottom inside.
The multiple choice of shock mounting positions now gives more flexibility for different track conditions
Jammin X1 FTE
Jammin X1 CRT
Go tech 21 5p
Jammin X1 CRT.5
Power by SH12
Team Dramatic
Old 04-19-2007, 06:35 AM   #3435
jfc_tech's Avatar
Send a message via Yahoo to jfc_tech
miss u all. everyone seems to be busy.
yea, the tower looks delicious. If only they have for the truggy. But mine still holding up.
here's from my recent race.
no action shot. really busy with pitting arghh and video camera is not working at that time.
If you are in front of me, That's because I let you!
jfc_tech is offline   Reply With Quote
Jammin/Hongnor X1 - so close yet so far jono mad racer Nitro Off-Road 5 05-08-2011 06:40 AM
anybody close ????? slowpokeRRR Minnesota and North/South Dakota Racing 0 08-24-2007 10:21 PM
close please pwnzor R/C Items: For Sale/Trade 0 06-29-2007 12:40 PM
close Big B R/C Items: For Sale/Trade 0 02-02-2007 10:29 PM
please close racenut123 R/C Items: For Sale/Trade 1 04-30-2003 05:08 PM
