Old 03-16-2007, 03:46 AM   #3301
Originally Posted by Jerseyboy
Seeing that we are discussing setup, I would like to know what droop setting you guys run. Have any of you experienced with droop on the X1.
Also I noticed on the X1 lower suspension arm I have alot of forward and backward play. Is this common or do you guys replace the sqaut plates?
Your droop setup depends on your track conditions. On a smooth track, you can run less droop. If the jumps on your track are not that big, you should still be ok with less droop. If your track has good traction, less droop will allow you to corner faster, because your springs will have more tension, which makes it harder to roll over. If you traction roll more than other racers at your track, you might have too much droop, or you may be trying to hit the turns too fast. I found this out by letting one of the fast guys at my track run a race with my buggy. He noticed right away I had too much droop, because he kept rolling over in a turn where he normally gets through pretty quick. That one little thing helped me drive better because I started taking the turns faster not worrying about rolling over. Your springs and shock oil play a big part too, but I'm sure you already know that.
Your lower arms shouldn't have an excessive amount of play. Take your front and rear assembly off the chassis and check the bolts that screw into your diff housing. (The ones that hold your plates) Release your shocks from the lower arms, and release the upper arm from your hubs/uprights. Tighten the two screws that hold each plate. Raise the arms and let them fall on thier own to make sure the screws are not too tight! You don't want your arms to bind at all moving up and down. You can even release the roll bar from the arms for a better adjustment. If this doesn't stop the excessive movement, forward and backwards, you might need new arms. That shouldn't be the case, unless you cut or shaved material from the arms.
Good luck, and don't forget to let a faster driver at your track, wheel your buggy for a few. They don't even have to have the same buggy you do.
Check out the Jammin' site, Plenty of setup sheets you can download, or just look at.
8ightScale/CJP is offline   Reply With Quote
Old 03-16-2007, 05:28 AM   #3302
Crocket's Avatar
Hiya Jerseyboy,
I find that the hinge pin holes in the rear anti squat plate wear fast on the X1CR allowing the hinge pins to move around. This in turn allows the rear wheels to move forward and back. It does not appear to effect the performance of the buggy but if it gets any worst I might look at replacing the antisquat plate as it is just a bad look
When I do I will probably go for the King Headz type as it has set screws added at the hinge pin holes to keep pins from wearing out the holes.
http://www.amainhobbies.com/product_...oducts_id/9908
Crocket is offline   Reply With Quote
Old 03-16-2007, 05:34 AM   #3303
Jerseyboy's Avatar
Originally Posted by Crocket
Hiya Jerseyboy,
Eightscale thanks for the info, I havent played much with droop but I will to find optimum setting for me.
Crocket yes I see its the anti sqaut plates front and rear that is worn. The holes are big causing forward backward movement.
Jammin X1 FTE
Upgraded to Warp Drive
KO Mars Ex-1 Spectrum Telemetry
Jammin JPX 21/OS Speed
Jammin X1 CRT
Go tech 21 5p
Upraded to Stelar Galactic
Jammin X1 CRT.5
Power by SH12
Either your Jammin or losing"Catch me if you can"
Team Dramatic
Jerseyboy is offline   Reply With Quote
Old 03-16-2007, 09:22 AM   #3304
Paradoxmaker's Avatar
i have had the exact oppisite, I have had to slightly file the ends of my lower arms to get them to fit between the anti squat plates.
Paradoxmaker is offline   Reply With Quote
Old 03-18-2007, 06:52 PM   #3305
arghh's Avatar
i just use shim there and the problem gone.. no need bought new plate
arghh is offline   Reply With Quote
Old 03-18-2007, 08:16 PM   #3306
jfc_tech's Avatar
Send a message via Yahoo to jfc_tech
as always... good tips from u arghh..
If you are in front of me, That's because I let you!
jfc_tech is offline   Reply With Quote
Old 03-19-2007, 02:31 AM   #3307
Crocket's Avatar
Hiya Arghh, A shim between the arm and the antisquat plate would remove slop from your arms wearing but would not overcome the issue we are taking about where the hinge pin hole in the antisquat plate wears and becomes an oval hole.
when this happens the inner hinge pins can move side to side which in turn allows the arms to pivot causing the wheels to go back and forth. The only way to shim this would be to drill out the Antisquat plate and press in an insert. Sound like a lot of effort when you can buy the King Headz ones for around $15 - which is cheaper that the original
The good thing about these ones is the set screws that lock the hinge pin preventing it from turning. It is the rotating of the Hinge pin that wears out the original.
Old 03-19-2007, 02:49 AM   #3308
Jerseyboy's Avatar
Thats what I thought Crocket , arghh is way off base on this one.
I had my first race meeting with the PBS. I must say that even though I felt I have more steering I dont think the more steering is necessarily a good thing. For me looking at my laptimes , I am definitely off my previous pace.
Maybe I am wrong maybe not but also comments fron Chad was that even though he can turn faster laptimes, he felt that he wasnt as consistent with the PBS.
It may suit some tracks more than others. I felt faster in some areas and slower in others. Overall it does not seem to work for my drive style.
This is only my feeling now. I am putting the C-hub back and next race meeting I will check laptimes and then decide which one is faster overall.
Any other comments from you guys. What do you think.
Jammin X1 FTE
Jammin X1 CRT
Go tech 21 5p
Jammin X1 CRT.5
Power by SH12
Team Dramatic
Old 03-19-2007, 03:07 AM   #3309
Crocket's Avatar
Something I have seen with cars using PBS type suspension is that on dusty tracks the pivot balls tend to bind up changing the suspension settings. This is made worse by the fact that due to the way the PBS system works it also binds up and slows down the steering reaction.
I have never had any trouble with getting steering out of an X1CR so dont see the benefit with spending the money on the PBS.
Old 03-19-2007, 03:30 AM   #3310
jfc_tech's Avatar
arghhh... now Im in deep shit. pull back the compliment
keep us updated on the PBS vs Chub jersey...
I can't wait for my big race.. LRP MASTER RACE
I hope i do not DNF this time.
My truggy is ready. my sts 28 is ready.. Am i ready?
Old 03-19-2007, 10:44 AM   #3311
macnkitty2002's Avatar
you can't race one time with the PBS and expect to get any legitimate results. you have been driving the C Hub since you got your X1, and probably if you had a buggy before that it was a C hub as well. you need to get used to othe PBS for about 2 months of racing before you can make any serious decisions. you can't expect to drive the PBS at its best the first time out, you need time to get used to it like you did with the C Hub.
Team Associated RC10B4.2
Losi Rock Rey
macnkitty2002 is offline   Reply With Quote
Old 03-19-2007, 06:15 PM   #3312
arghh's Avatar
yeahh jerseyboy..little missunderstanding here.. i thought i regarding ur posting "Also I noticed on the X1 lower suspension arm I have alot of forward and backward play.."
thats why i suggest putting shim to solve the freeplay..
but when i go through crocket posting "Hiya Jerseyboy,I find that the hinge pin holes in the rear anti squat plate wear fast on the X1CR allowing the hinge pins to move around.."
this mean changing new plate is only the way to solve it..
wondering if jammin make latest design arm holder/anti squat plate using rubber gromet or insert.. so when it wear out, just change the rubber or insert only..
Old 03-20-2007, 01:53 AM   #3313
Jerseyboy's Avatar
The main reason for this wear is the force that the shocks exert against the squat plates.
I've made some inquiries and Ive ordered new ones. For the rear you can use 2 of the same plates as this will take longer to wear.
Jammin X1 FTE
Jammin X1 CRT
Go tech 21 5p
Jammin X1 CRT.5
Power by SH12
Team Dramatic
Old 03-20-2007, 02:41 AM   #3314
Crocket's Avatar
Hmmmmm......A little confused on your comments Jerseyboy.
I have always thought the wear was from the metal to metal contact between the the hinge pin rotating inside the anti-squat plates, using the antisquat plates that lock the hinge pins in place stops the hinge pins grinding against the antisquat plates, wearing them out.
To use 2 standard anti-squat plates you are going to need to grind the lug of the bottom of one of them where it goes through the chassis, you will also need to use longer hinge pins???
Why would you go to all this trouble buying 2 standard ones at $11.00 each and then still needing to modifying one of them when the King Headz one that has the locking set screws is only $15.49??
Old 03-20-2007, 03:40 AM   #3315
Jerseyboy's Avatar
Crocket yes you are correct. The hinge pins locate for rear in the rear sqaut plate 2 deg and rear toe plate 3 deg.
The holes are worn oval, due to the pressure that the shock exerts on the lower control arm. The hinge pins have a gap as it does not tie right up against the sqaut plate. I locate the one sqaute plat in the hole and the second one I grind off, thereby taking out the play in the hinge pins.
Jammin X1 FTE
Jammin X1 CRT
Go tech 21 5p
Jammin X1 CRT.5
Power by SH12
Team Dramatic
Jammin/Hongnor X1 - so close yet so far jono mad racer Nitro Off-Road 5 05-08-2011 06:40 AM
anybody close ????? slowpokeRRR Minnesota and North/South Dakota Racing 0 08-24-2007 10:21 PM
close please pwnzor R/C Items: For Sale/Trade 0 06-29-2007 12:40 PM
close Big B R/C Items: For Sale/Trade 0 02-02-2007 10:29 PM
please close racenut123 R/C Items: For Sale/Trade 1 04-30-2003 05:08 PM
