Old 02-19-2007, 10:13 AM   #3121
jfc_tech's Avatar
Send a message via Yahoo to jfc_tech
geezzz... sorry to hear that my friend. hope u've got another engine to race with... damn i feel for you, man.
If you are in front of me, That's because I let you!
jfc_tech is offline   Reply With Quote
Old 02-19-2007, 11:29 AM   #3122
ngo8's Avatar
Send a message via ICQ to ngo8
you can replace that bearing i recomend with a ceramic rear bearing from what i hear T.K.O bearings are the best .
Xray|ORCA|Sanwa|Trinity|KoPropo
ngo8 is online now   Reply With Quote
Old 02-19-2007, 12:06 PM   #3123
SKOT's Avatar
I would, but metal went into the sleeve and gouged it as well. Basically all that was not harmed was the case and the crank, so it's not woth rebuilding.
I have a backup engine in it now and I'm going to order something new next week. I'll probably get the Go Tech 5-port. They are fairly new in this country and so far have been getting really good reviews. Have any of you guys outside the U.S. had any experience with them?
SKOT is offline   Reply With Quote
Old 02-19-2007, 09:04 PM   #3124
ngo8's Avatar
i hear those motors are really good also the new jammin motors as really good as well and there cheap. and dont forget werks motors as well there awesome power for a good price
you can go here and check them out he has go tech and werks and he ships internationally really god place for 1/8 scale stuff .
Old 02-19-2007, 10:19 PM   #3125
Paradoxmaker's Avatar
Go where?
Paradoxmaker is offline   Reply With Quote
Old 02-19-2007, 10:42 PM   #3126
ngo8's Avatar
Originally Posted by Paradoxmaker
Go where?
ahhhhhh ooppss http://www.amainhobbies.com/ sorry
Old 02-20-2007, 12:02 AM   #3127
Jerseyboy's Avatar
SKOT Bummer hope you have a backup. What engine were you using?
Jammin X1 FTE
Upgraded to Warp Drive
KO Mars Ex-1 Spectrum Telemetry
Jammin JPX 21/OS Speed
Jammin X1 CRT
Go tech 21 5p
Upraded to Stelar Galactic
Jammin X1 CRT.5
Power by SH12
Either your Jammin or losing"Catch me if you can"
Team Dramatic
Jerseyboy is offline   Reply With Quote
Old 02-20-2007, 06:22 AM   #3128
I have a Jammin question, I asked at the local track and no one seem to of even heard of this problem.
When I tighten up the 2 screws that attach the front top plate to the steering posts, it locks the servo saver down. The steering will no longer turn, unless i back off the screws some.
I have new posts and have had this problem with the bearings installed and with the plastic bushings although it is far worse with the bearings installed. Also I have tried 2 different top plates. the CF one and an aluminum one. Just starting to wonder if there is a trick i'm missing or if I should be shimming something that i'm currently not.
Old 02-20-2007, 12:04 PM   #3129
ngo8's Avatar
what i did is put thread lock on the screw and tighen half way walked away for like 10 minutes came back it was all stiff now you cane tighten to the tension where it doesnt bind anymore and the screw wont fly away from the vibration .
Old 02-20-2007, 01:44 PM   #3130
SKOT's Avatar
Jerseyboy, luckilly I do have a back up. The engine I was running was just an OS RG that I sent out and had modded. I'm glad it wasn't a high dollar engine. I was kind of bummed that the sleeve got trashed though.
Paradoxmaker - I've never heard of that problem either. Is it possible that you are using center diff posts rather than servo saver posts in that location? They look very similar. I don't know if that's possible, but it's the only thing I can think of.
Old 02-20-2007, 02:03 PM   #3131
Your right they look similar, but No i'm sure i don't have them mixed because the diff posts take 3mm screws and the steering posts have 4mm screws.
Old 02-20-2007, 02:43 PM   #3132
SKOT's Avatar
That's true - good point. If I think of anything else I'll let you know.
Old 02-20-2007, 04:01 PM   #3133
Crocket's Avatar
Hi Paradoxmaker,
If you have the servo saver adjusted too loose the adjustment wheel locks up the steering. I would suggest that you tighten up the spring tension on the servo saver and recheck, this should free up you steering allowing you to correctly tighten your steering post screws.
Good luck mate..........Crocket
Crocket is offline   Reply With Quote
Old 02-20-2007, 04:34 PM   #3134
Originally Posted by Crocket
Hi Paradoxmaker,
Well I just installed the updated servo saver and have it adjusted to the recommended tension on the screw (approx 1mm of threads showing above the collar).
For now i have the plastic bushings installed since they cause the least amount of binding. I''ll replace the bushings and try again after I order some new bearings.
Old 02-20-2007, 07:14 PM   #3135
1armed1's Avatar
Trader Rating: 79 (100%+)
Send a message via AIM to 1armed1
There is a shim that goes under the front of the steering brace, do you have that installed?
If not that can cause enough of a angle to cause a bind on the steering post.
later
Dayton
Serpent,Sanwa,Fantom Racing
92zero.com,Lunsford Racing,AKA Racing
TXD Snake Skin Graphix
1armed1 is offline   Reply With Quote
Jammin/Hongnor X1 - so close yet so far jono mad racer Nitro Off-Road 5 05-08-2011 06:40 AM
anybody close ????? slowpokeRRR Minnesota and North/South Dakota Racing 0 08-24-2007 10:21 PM
close please pwnzor R/C Items: For Sale/Trade 0 06-29-2007 12:40 PM
close Big B R/C Items: For Sale/Trade 0 02-02-2007 10:29 PM
please close racenut123 R/C Items: For Sale/Trade 1 04-30-2003 05:08 PM
