Jammin X1 - so close yet so far
#2986
Originally Posted by Jerseyboy
Hi SKOT
I know what you talking about. Firstly once you put in the ball, then the ball retainer and then you screw the aluminium adjuster. This is to remove any slop. You will notice that it is only threaded half way. The reason for this that you have to screw it in until the slop is gone. You'll also notice that the adjuster is now a tight fit. It is purposely done so the aluminium does not unwind itself.
#2987
I would rebuild/re-grease the car, its well over due. When your at it check the bearings after you've cleaned them out. Spin 'em up to see if you have any other bad bearings. Replace as needed, there's no need to replace a bearing just cause its old or such. If its still tight and runs well keep them in the car, after you've cleaned and re-oiled them of course.
#2988
Ok the PBS is geniune Jammin X1 qaulity. What weve found was that the steering rod screws onto the hub. The screw goes through the the streering rod and into the plastic hub. the bottom of the plastic hub has a resess in for the locknut that holds it in place. Weve found guys tighten this very tight and the it will break at that point as the resess causes the plastic to be thinner on that spot. As long as you dont overtighten it, your fine.
#2989
bad thing on the PBS stuff.. seem c-hub is still the best
#2991
Chad reckons he prefers the C-hub. I will make my own deductions after I have had a race or 2 with the PBS.
Look the Mugens are doing well with PBS so based on that it can only be better.
#2992
I think its more on your line JerseyBoy, it all depends on driver, i just received an email from a friend in USA who raced with PBS last weekend, and he LOVED it, says that the car turns a lot better and more agressively than with the C-Hub. The track where he runs its not high-jump based so he cant comment on durability, so far more than happy with it.
On sgrid.com forums Chad Bradley was saying tat after his testing the system works GREAT, but he personally prefer C-Hub system, so ... just a matter of personnal preference on track ...
cya !
#2993
As far as whether or not it is better than C-hub that's totally up to personal preference. If I could win races like Chad does I wouldn't want to change anything either. There's really no reason for him to. For me though I think I'm really going to like it. I got 2 quals in with it and it felt super smooth and really easy to drive. Next weekend will be a better test as I think I've solved my previous problem.
#2994
if or when i got the PBS.. i will try it for sure. im sure only the driver can tell which one is better.. because it all depends on how you drive.. the driving style i mean.
both have success stories. both can be broken... so for me.. which one suits to my driving style and cheap to replace..thats mine then. ignore what others said.
i take like what chad said about the grey spring of mugen. he likes it very much but also said, maybe its my driving style and the feeling of driving with one. Bcoz taylor and even tebo driving with the red spring still produce result on podium. its all in the mind of the driver. could not be denied.
ok back to the topic..
#2995
Time will tell
#2996
ok guys its the offseason here we are kneedeep in snow but here is my jammin all cleaned and new waiting for the snow to melt
#2999
that werks motor is pretty fast not as fast as my modded max 7 port but good reliable motor also i tryed those tires lst year in the end of the season when they came out and they hooked up real good so i just left them on there .
#3000
ngo8
She's a beaut! Love the Kings Heads upgrades. Must be a bummer when you cant take it out for some racing.
