Jammin X1 - so close yet so far
#2881
anyone know if the new servo saver with the ajustment nut on top is availble yet and what the part # is also has anyone seen a new rear shock tower from hong nor that has an extra row of camberlink holes like the ones the team guys drill and if so is it availble anywhere thanks in advance
#2882
1st place to go is obviously, www.jamminproducts.com or www.hongnor.com.tw
#2883
i check jammins site but they dont have any info on either one of those parts
the servo saver i found on hong nors site but i cant find it anywhere not even at the hong kong web stores
as for the shock tower it was showen to me by a jammin driver and he said it was a hong nor part and was not availbe in the states
im from san diego california
if any one can get or knows where to get these parts it would be appriceated
#2884
u can try contact rcracing.com.au... he's a frequent here.. click previous page or just pm this nick rcracing.com.au. he's from australia. i think u can get from him. If in malaysia, u can try www.awhobby.com.
if all those fail... PM me again.. i will get those things for u.
[i believe there's a LHS from USA available for you to try 1st. ]
#2885
thanks jfc_tech i checked the link but could not find anything i also pm'ed rcracing.com.au so i will see if i can hunt these parts down thanks for the help
#2886
In the states www.nitrohouse.com is your best bet for finding anything OFNA/Jammin. Your best bet is to call though because not everything is shown on their web site.
#2888
Like SKOT said, WWW.NITROHOUSE.COM. I think they are in the same wharehouse or business park as Jammin so they usually have it first. Jammin doesn't always adopt all of Hong Nor's upgrades though, ex: Metal front hub carrier and pillow ball front suspension, so you'll have to get it direct from Hong Hor. Good Luck!!
#2889
if ur driving style can bend the 5mm shock tower, so there u go.. 6mm shock tower..
#2891
6mm !? ... anyone knows why is this ? ... i've beat very hard on my 5mm FTE towers and no bending signs till now ... so i think 5mm its enough. How much extra weight this towers are ?, and ... have the same layout as 5mm ones or present new options ?
thanks,
#2893
Wow that must look cool. The only problem I have is I tend to snap the bolt of the shock standoffs ie front upper shock mount. I have bent my 5mm shock tower before. Never broke one.
I could do with a 6mm ST.
#2895
IF you think it's because of locktite try putting a heat gun to it and warming it up a little.That should make it able to break the locktite loose.
