Old 10-08-2006, 06:41 PM   #2581
macnkitty2002's Avatar
well, i certainly had a great day of racing today. we had 4 inches of rain in the last three days, so the track was pretty muddy. however, my general setup was perfect. tires didn't matter since they got clogged up instantly. nevertheless, i won ALL four heat races (TQ) and i won the A main. i guess my luck from last time showed up. i've got some cleaning to do.
Team Associated RC10B4.2
Losi Rock Rey
macnkitty2002 is offline   Reply With Quote
Old 10-09-2006, 05:51 AM   #2582
Jerseyboy's Avatar
Default Diff oils
I had 571 and after reading what you guys had to say I was willing to try 572. After this weekend of practice I must say I am very happy with my setup.
572 diffs. 35wt oils front and rear. My X1 was flying. I get chills just thinking about it. The car feels so good I dont want to change anything.
Problem is I am flying but still not fast enough to beat the top notch.
I suppose its only consistency that seperates the men from the boys.
I am wanting to try the 10k rear diff oils. Maybe it'll give me the edge.
Well done macnkitty2002.
Jerseyboy is offline   Reply With Quote
Old 10-09-2006, 06:20 AM   #2583
blanks596, only set the droop while the chassis is sitting on those 2 wheels, nothing else. camber, toe in/out, ride height all have to be set with a full tank of fuel and the car fully loaded with fuel, batteries, radio gear and tires on the axles.
adam lancia is offline   Reply With Quote
Old 10-09-2006, 08:53 AM   #2584
blanks596's Avatar
Trader Rating: 14 (100%+)
Hey thanks a lot adam. As brianmuffin said regarding ride height, is 26mm in front and 20mm in the rear a good height. I'm thinking thats having the arms approximately level with the chassis. Also, have you or anyone experienced problems with the front shocks rubbing against the upper a-arms at certain positions. I have an x1 pro with big bore shocks and 4mm front shock towers.
Serpent/Desoto Racing
Max S
blanks596 is offline   Reply With Quote
Old 10-09-2006, 09:06 AM   #2585
that's how i felt yesterday!! i use the same diff setup too!
Losi Rock Rey
Old 10-09-2006, 12:22 PM   #2586
Sorry i ment 26mm and 20mm as in Droop not ride height...
BrainMuffin is offline   Reply With Quote
Old 10-09-2006, 01:26 PM   #2587
blanks596's Avatar
ok, that sounds better but as far as 26mm ride height, that sounds about right. 1/10 scale front tires are 26mm wide and when place under the buggy the a-arms are aligned with the chassis. If figure 26mm to 30mm may be ok.
Max S
Old 10-09-2006, 01:51 PM   #2588
madbeats's Avatar
Serpent 966/720 Mugen MTX4R Xray NT1-Mugen MTX-4 Knack R conversion Hong Nor X1CR
madbeats is offline   Reply With Quote
Old 10-09-2006, 02:11 PM   #2589
the 26mm and 20mm of droop is measured from the bottom of the arm at the outer hingepin with a rim under each end of the chassis. as for ride height, i would set it up so that the arms are just above level front and rear then adjust for the track from there.
Old 10-09-2006, 07:44 PM   #2590
jfc_tech's Avatar
Send a message via Yahoo to jfc_tech
congrats mac. sure nice to hear friend winning on their racers.
If you are in front of me, That's because I let you!
jfc_tech is offline   Reply With Quote
Old 10-09-2006, 07:48 PM   #2591
jfc_tech's Avatar
Originally Posted by Tabushi
I asked him for it on the sgrid.com conferences ...
As you see, you can download it from : http://www.jamminproducts.com/CRsetups/x1supCBv2.pdf
Its basically a "hoped up and slightly modified" version of his standard setup ...
cya !!
thanks tabushi!
Old 10-10-2006, 05:02 AM   #2592
should i replace my uni's if they have flat spots on the dogbone end? i mean my middle driveshafts are flattened nearly halfway through the pin!
Losi Rock Rey
Old 10-10-2006, 05:59 AM   #2593
SpeedBump57's Avatar
Mankitty it is not going to hurt anything if you keep running them but they will most likely break when you are leading the A-main some where and not during practice.
SpeedBump57 is offline   Reply With Quote
Old 10-10-2006, 08:25 AM   #2594
ya, i bet that would actually happen too!
Losi Rock Rey
Old 10-10-2006, 06:52 PM   #2595
arghh's Avatar
woww what a great news.. what race.. where..can u post the full result..and some picture probably..
arghh is offline   Reply With Quote
Jammin/Hongnor X1 - so close yet so far jono mad racer Nitro Off-Road 5 05-08-2011 06:40 AM
anybody close ????? slowpokeRRR Minnesota and North/South Dakota Racing 0 08-24-2007 10:21 PM
close please pwnzor R/C Items: For Sale/Trade 0 06-29-2007 12:40 PM
close Big B R/C Items: For Sale/Trade 0 02-02-2007 10:29 PM
please close racenut123 R/C Items: For Sale/Trade 1 04-30-2003 05:08 PM
