Old 08-03-2006, 12:54 PM   #2401
Send a message via Yahoo to windellmc
I think it will protect the chassis. One thing to keep in mind is that the CRT has more ground clearance than the CR and so the skid plate probably has less effect on the handling of the CRT compared to the CR. I guess you can always try it and see what happens.
windellmc is offline   Reply With Quote
Old 08-03-2006, 12:58 PM   #2402
As to the hoppy rear end it may benefit you to try a different antisquat plate. They are saying to use the 1 degree for bumps with round edges and more antisquat (stock is 2.5) for bumps with sharper edges.
To the guy building a new kit: get shock booties from the X1 CR (non FTE) kit or Kyosho SP2 booties instead of the red wipers.
Old 08-03-2006, 05:50 PM   #2403
Thumbs up
Originally Posted by Tabushi
Anyone knows if the DACE rear CRT chassis plate can be used on the CR FTE buggy ? :
http://www.dacemfg.com/Store_Detail....30&InfoID=2293
My chassis its getting high wear on the rear and im not planning on changing chassis till the end of the year ...
thanks,
yes the rear skid plate works on the cr1 buggy.
teamatlas is offline   Reply With Quote
Old 08-03-2006, 08:16 PM   #2404
arghh's Avatar
jammin buggy/truggy use same diff case.. definately their screw hole position is same.. so i didnt see any problem to use that chassis brace.. maybe the problem is the plate is too thick maybe 4mm..very easy bottom out.. my custom made one only 2.5mm thick
arghh is offline   Reply With Quote
Old 08-05-2006, 02:37 PM   #2405
Tabushi's Avatar
Send a message via AIM to Tabushi Send a message via Yahoo to Tabushi
Hi guys, i have a question ...
Wich difference in behaviour/performance i will have changing the position of the steering link to the front or to the rear on the ackerman plate ?, right now the position its stock on the middle hole ...
thanks,
Patricio "PATO" Concha
E-Mail : pato_concha@yahoo.com
Facebook : http://www.facebook.com/patoconcha
Whatsapp : +56 9 66165085
Tabushi is offline   Reply With Quote
Old 08-05-2006, 03:46 PM   #2406
RCRacing.com.au's Avatar
Wink Acerman positions
Tabushi,
Although i don't know much this one i do know
If you move your tie rods to the back it will make your steering more responsive at slower speeds in tighter turns which is better for a tighter track and to the front will make it more responsive at higher speeds and in bigger turns but less responsive in tighter turns which will be better for a big open track.
If you are still racing on the track i saw of you in the video then the middle will be the best as it gives you medium resposive steering right through all turning ranges.
Hope this helps .
Steve P
LCORCCC - Life Member
100 Cubic Inch Thumping V-Twin Victory Hammer 8-Ball!
-Stuff for sale-
CRT.5 - OS .12TZ (P) All reasonable offers Considered!
RCRacing.com.au is offline   Reply With Quote
Old 08-05-2006, 07:08 PM   #2407
SpeedBump57's Avatar
+ 1 ^
Couldn't have answered that any better!!
SpeedBump57 is offline   Reply With Quote
Old 08-06-2006, 06:59 PM   #2408
jfc_tech's Avatar
Send a message via Yahoo to jfc_tech
Originally Posted by RCRacing.com.au
Tabushi,
Hope this helps .
yes... i can feel it when i use chad bradley setting. i mean CRT setup. the steering is more responsive. especially on tighter small track. man u explain it better.
If you are in front of me, That's because I let you!
jfc_tech is offline   Reply With Quote
Old 08-06-2006, 08:47 PM   #2409
Tabushi's Avatar
Thanks for your answers guys ! ...
Old 08-07-2006, 04:26 PM   #2410
Default Throttle Linkage
So I just got my electronics and linkage done on my FTE and noticed that the end of the throttle linkage rubs on the body and pushes it up(wears on the paint also).Everything seems like it should as far as servo mounting and linkage goes but not sure why it is rubbing.Anyone ran into this before?The body is bubbled to give the linkage room it seems????
Jammin"145 is offline   Reply With Quote
Old 08-07-2006, 05:14 PM   #2411
145 can you post a picture of you gear?
Old 08-07-2006, 05:22 PM   #2412
Tabushi's Avatar
I have the same problem, so on the stock Jammin body, on a Proline one and on a Hyper 7 one i ended making a hole for the linkage (UGLY !!!) ... right now i have to paint a JConcepts body, and i love that body but i think i will end cuting it to clear the linkage ... here is a pic of mine :
But on the Hyper7 body the holes ended being 2 and very big ... (one for the gas linkage and another for the break linkage ...
Old 08-07-2006, 06:53 PM   #2413
jfc_tech's Avatar
hmmm yummy green head.
Old 08-07-2006, 07:59 PM   #2414
macnkitty2002's Avatar
i prefer grape.
Team Associated RC10B4.2
Losi Rock Rey
macnkitty2002 is offline   Reply With Quote
Old 08-08-2006, 08:26 AM   #2415
I used the "A" linkage set up as per manuel (same as i did on my CRT).I might flip the throttle link holder to the bottom of the servo horn and try it.
Tabushi- I didn't think about putting hole thru,might do that.I like the Green on your ride.
Jammin/Hongnor X1 - so close yet so far jono mad racer Nitro Off-Road 5 05-08-2011 06:40 AM
anybody close ????? slowpokeRRR Minnesota and North/South Dakota Racing 0 08-24-2007 10:21 PM
close please pwnzor R/C Items: For Sale/Trade 0 06-29-2007 12:40 PM
close Big B R/C Items: For Sale/Trade 0 02-02-2007 10:29 PM
please close racenut123 R/C Items: For Sale/Trade 1 04-30-2003 05:08 PM
