Old 07-30-2006, 11:07 PM   #2386
arghh's Avatar
Originally Posted by macnkitty2002
make a copy from plywood then get a slate of aluminum and take it to the machine shop.
aiyaa.. just very easy job to do this.. use hand saw, drill.. i have use this for quite a long time.. no worried rearend chassis wore out.. when the plate wore out, just throw away and make another new plate.. hehe..
Jammin X1 - so close yet so far-dsci0004.jpg   Jammin X1 - so close yet so far-dsci0003.jpg
arghh is offline   Reply With Quote
Old 07-30-2006, 11:14 PM   #2387
arghh's Avatar
Originally Posted by jfc_tech
just check the worldwide result. do the X1 better or the other buggies? Even your Ian Haley,ok he's an australian. he's driving the HongNor X1 CR buggy GET the X1, FORGET THE REST!
so.. what are u waiting for heheheheh...
Old 07-30-2006, 11:50 PM   #2388
jfc_tech's Avatar
Send a message via Yahoo to jfc_tech
cilaka... makan cakap sendiri
oklah... i check with david aw...see if any special price for his special customer
If you are in front of me, That's because I let you!
jfc_tech is offline   Reply With Quote
Old 07-31-2006, 08:32 AM   #2389
been racing on a extremely bumpy track. using big bore shocks , stock shock pistons, 50 wt in front and 40wt in rear. yellow springs. but noticed the rear keeps hopping up. should i actually changed to s slightly smaller piston, even softer springs (from mugen) or what should i do???
knight is offline   Reply With Quote
Old 07-31-2006, 09:48 AM   #2390
Thor23's Avatar
What are your rear shock angles set at, you could angle them in more; Bring the tops inward and the bottoms outward and that should help remove the bounce in the rear...
Thor23 is offline   Reply With Quote
Old 07-31-2006, 09:56 AM   #2391
the top is already inward but will try bottoms outward..what about my my mention idea about smaller pistons ..etc..is it a bad idea?
Old 07-31-2006, 01:16 PM   #2392
macnkitty2002's Avatar
JFC, i noticed in your sig that you have a dilemma about what buggy to get. give your CRT a friend with an X1-CR.
Team Associated RC10B4.2
Losi Rock Rey
macnkitty2002 is offline   Reply With Quote
Old 07-31-2006, 05:47 PM   #2393
arghh's Avatar
perfect combination.. GET the X1, FORGET THE REST!
Old 07-31-2006, 06:26 PM   #2394
plus, some parts are interchangeable.
Losi Rock Rey
Old 07-31-2006, 06:56 PM   #2395
jfc_tech's Avatar
yea... everyone been buggy'ing me on that issue after i put my signature like that.
i just wish someone in the hobbyshop would offer me somthing.
definitely my CRT need a company. of coz 1st choice the X1CR, but im open to sponsorship
im serious.
Old 08-01-2006, 01:45 AM   #2396
dazyz's Avatar
Are you saying you are running your rear shocks on the inside holes at the top and the inside on the arm?
If you are at the inside on the top you could go to the middle on the top and stay in the inside hole on the arm. Raising your ride height may make a difference too. Is the yellow spring the softest for you guys? I would be changing to the medium spring which I believe is the red (the colours may be different for different countries). Dont play with the piston hole size until you've tried all other alternatives as far as springs, oil, ride height and shock angle.
dazyz is offline   Reply With Quote
Old 08-02-2006, 04:36 PM   #2397
dido41's Avatar
i am setting up a new clutch for the first time and need to know how much end play i sould have. i am installing a fioroni turbo slide clutch. at this time with out any shims there is about .005" just enough to see some end play. is this good enough or do i need to try and have more? and if i need more how can i do that?
thanks
dido41 is offline   Reply With Quote
Old 08-03-2006, 10:15 AM   #2398
tried many different ways..not too good still.anyway, got the 1.4 pistons.wonder if it'll work. any ideas? and does anyone know the purpose of the 2 bottom holes of the rear hub(lower and higher hole difference)?
Old 08-03-2006, 10:40 AM   #2399
Tabushi's Avatar
Send a message via AIM to Tabushi Send a message via Yahoo to Tabushi
Anyone knows if the DACE rear CRT chassis plate can be used on the CR FTE buggy ? :
http://www.dacemfg.com/Store_Detail....30&InfoID=2293
My chassis its getting high wear on the rear and im not planning on changing chassis till the end of the year ...
thanks,
Patricio "PATO" Concha
E-Mail : pato_concha@yahoo.com
Facebook : http://www.facebook.com/patoconcha
Whatsapp : +56 9 66165085
Tabushi is offline   Reply With Quote
Old 08-03-2006, 12:38 PM   #2400
why not, just use longer screws.
Losi Rock Rey
Jammin/Hongnor X1 - so close yet so far jono mad racer Nitro Off-Road 5 05-08-2011 06:40 AM
anybody close ????? slowpokeRRR Minnesota and North/South Dakota Racing 0 08-24-2007 10:21 PM
close please pwnzor R/C Items: For Sale/Trade 0 06-29-2007 12:40 PM
close Big B R/C Items: For Sale/Trade 0 02-02-2007 10:29 PM
please close racenut123 R/C Items: For Sale/Trade 1 04-30-2003 05:08 PM
