Old 07-27-2006, 04:47 PM   #2356
SpeedBump57's Avatar
Ah.......now that's better, one of my favorites
SpeedBump57 is offline   Reply With Quote
Old 07-27-2006, 06:11 PM   #2357
Anyone here used the Dace Mfg Super Chassis plate? I have the CRT Pro kit. I use the Dace Zbrace and Engine Mount. I love them, they are nice and well designed.
I saw one of there Super Chassis plates on another rig, and i went ahead and orderd one. But i cant seem to find any information on it. I checked there site, its not listed. The online shop i buy from said they should have some images and product info shortly. Anyone else have any info on this?
Thanks in advance
Wicked
wickedklown is offline   Reply With Quote
Old 07-27-2006, 06:54 PM   #2358
Dace has a thread on the Gird. Here a pic of the plate.
This is the rear skid plate for the Jammin X1-CRT from Dace Manufacturing. This skid plate will save the rear of your chassis and make it last a lot longer than it would without this protective skid plate!
Here it is on the Dace web site!
http://www.dacemfg.com/Store_Detail....30&InfoID=2293
Old 07-27-2006, 07:16 PM   #2359
macnkitty2002's Avatar
no offense, but this is the buggy thread, not the CRT thread.
Team Associated RC10B4.2
Losi Rock Rey
macnkitty2002 is offline   Reply With Quote
Old 07-27-2006, 08:14 PM   #2360
Hum..........maybe you should re-read the title of this thread!
"Jammin X1- so close yet so far"
Jammin X1-CR
Jammin X1-CRT
All the dude asked was a question...............
Old 07-27-2006, 11:13 PM   #2361
Trader Rating: 14 (100%+)
Hey guys, I have the x1 rtr. I changed the pipe for the jp-1, and wanted to know about an engine choice. This is my first nitro, but it seems to me that the force .28 that came with the car is pretty fast. Forgive my ignorance, but what I want to know is if a good .21 will have as much power and be as fast as the force .28, and if so what would be a good choice for a small track (100 x 60). With the .28 I have no problems lapping the electric 4x4's.
trilerian is offline   Reply With Quote
Old 07-27-2006, 11:41 PM   #2362
yamrace's Avatar
Yes, a good .21 will have as much power as your .28, in most cases, a good .21 will have alot more power. With the track size you listed, your .28 is more than enough power and you might even go slower with a .21 because they make their power at a higher rpm where your motor makes it at a lower rpm which is good for small tracks.
yamrace is offline   Reply With Quote
Old 07-27-2006, 11:46 PM   #2363
dazyz's Avatar
The AXE Rossi LSK or Cobra both have buckets loads of bottom end power and they rev well too. Either of these motors would have as much power if not more than your .28.
dazyz is offline   Reply With Quote
Old 07-28-2006, 08:38 AM   #2364
the RTR .28s have no powerband whatsoever, and pretty much any .21 has actual variations in RPM. most RTR big block engines i see have to modes, idle and open throttle. the RPM never seems to change, it's very much the same no matter whether you go full throttle or 1/4 throttle. hey, even an OS RG has a useable powerband to work with. and buggies were always meant to have .21s, big blocks are reserved for MTs.
Losi Rock Rey
Old 07-28-2006, 02:43 PM   #2365
RCRacing.com.au's Avatar
trilerian,
I'd spend your money on setting the car up first and then learning to drive it fast before you worry about the motor.
Get your moneys worth out of the motor first and get to the point where you can out drive the motor then get yourself a faster engine.
If you put in a fast engine now you may go slower because you cannot handle the power.
There are lots of hop ups for your X1 which will help make it handle alot better.
Tires should be your first choice as they are 90% of the handling.
Then get the Alloy upper and lower B Blocks, heavier sway bars, alloy chassis braces f&r, different shock springs and some different weight shock oils.
That will help your buggy handle better along with a good set of tires.
I just put an AXE Rossi LSK in my buggy and it's got more balls than anything i've owned before (P5 & VZB)
Steve P
LCORCCC - Life Member
100 Cubic Inch Thumping V-Twin Victory Hammer 8-Ball!
-Stuff for sale-
CRT.5 - OS .12TZ (P) All reasonable offers Considered!
RCRacing.com.au is offline   Reply With Quote
Old 07-28-2006, 03:12 PM   #2366
how heavy are the stock sway bars? if i run on a very smooth track, should i invest in heavier sway bars?
Losi Rock Rey
Old 07-28-2006, 06:52 PM   #2367
jfc_tech's Avatar
Send a message via Yahoo to jfc_tech
i want this! i want this! wish that easy. our lhs not getting it. ordering online is too risky for us here.
If you are in front of me, That's because I let you!
jfc_tech is offline   Reply With Quote
Old 07-28-2006, 08:17 PM   #2368
why?
Losi Rock Rey
Old 07-28-2006, 08:18 PM   #2369
jfc_tech's Avatar
no credit card protection. im willing to TT the money 2 u mac then u send me here than using my card to order. it probably cost more.
Old 07-28-2006, 08:24 PM   #2370
ya, or you could just say "screw dace" and make your own chassis plate. just like your Savvy TVPs, make a copy from plywood then get a slate of aluminum and take it to the machine shop.
Losi Rock Rey
Jammin/Hongnor X1 - so close yet so far jono mad racer Nitro Off-Road 5 05-08-2011 06:40 AM
anybody close ????? slowpokeRRR Minnesota and North/South Dakota Racing 0 08-24-2007 10:21 PM
close please pwnzor R/C Items: For Sale/Trade 0 06-29-2007 12:40 PM
close Big B R/C Items: For Sale/Trade 0 02-02-2007 10:29 PM
please close racenut123 R/C Items: For Sale/Trade 1 04-30-2003 05:08 PM
