Jammin X1 - so close yet so far
#2297
arghh, here is what i got. click ont the diagram in the window.
http://carolinasrc.com/Webstore/Scri...?idproduct=478
maybe, i have never tried something like this before.
i don't quite understand what you are saying. i always thought that if there is more weight over one side of the car, that side with the more weight would yield more traction. and with a stiffer car all around, there is less weight trasfer, which would yield more even traction distrubution.
I think it would feel soggy when the weight transfers from the centre to the side as the compression is soft which will make the car lose cornering stability and in turn losing steering.
You will probably find the rear of the car is too loose and it won't accelerate as hard through the loss of rear traction.
#2298
I think what he is getting at is you are going to have less weight transfer to the rear so yes you are going to have less traction over all. In other words you are probably just going to lite up all four tires rather easy. It should be a good learing experiance none the less, let us know what happens.
#2299
Thats basically what I was saying. Just concerned that the rear end will be too hard. It will be interesting though. If it doens't feel great to start with maybe try a lighter centre diff oil to compensate for the additional front traction.
#2300
#2301
Just run it with the 40 wt to see how it feels then change to 45wt. Even if it makes it worse then at least you'll know for future reference.
#2303
new to off road.
having been racing 1/8 on road for years, off road is relatively new to me.
i've encountered problems for my new x1-cr. i drive on a tight dusty track.
how do i get more on-power steering? current diff is 5-5-1.heavier rear??
the track at my town is very bumpy,extremely in fact.and each time i try to power through it, the rear jumps up.seen car go through bumps with ease before,but just can't get mine right.any help?? hard damping soft springs or??need real help here. thanks.
#2304
#2305
well guys, i have good race news to report on my front with the home-grown setup. the track was in perfect shape, perfectly smooth (that's how the owner likes it), hard packed and wet, very tacky with lots'o'traction. out of 17 heat races, i won 8 (that's just how we race). after i got my engine issues sorted out (very humid) i started to really push the buggy to see what it would do. i started off with crime fighters all around, but they switched to some mini-pins all around to see what happened. i noticed a little loss of lateral grip, so i put the crime fighters in the rear and that solved my problem.
i think i certainly solved the problem of the nose shooting up when i accelerate, partly because i used more droop than i usually do. the car didn't feel as if it carved into the turn initially very well, but mid to exit turning was very good. i could almost pivot right around the pipe! however, this comes with a loss of corner speed too.
for the 3 jumps we have on the track, the buggy really handled them well. very smooth, level flight, and controllable. what i really noticed is that when the buggy landed and i hit the throttle again, it shot off into the corner like a rocket.
to my regret, i didn't get a chance (let's say i didn't want to) to change my spring combo at all. i wanted to put some harder springs on the front to see if it would carve into the turn better, but the 2nd place guy was really on my toes the whole time and i didn't want to chance it. next time i'll try some softer springs in the rear and harder springs in the front.
also, i noticed that my engine really needed to spool up before it would start moving. i almost had to pull back 1/4 on the throttle before it would even budge. i run the blue shoes with gold springs on an RB S5, what should i change to get snappier acceleration?
#2307
Go with the Mugen carbon shoes and the 1.1 springs, it will be really snappy!!! THat's the combo I run and really like it.
#2309
What thickness are the gold springs?
