Old 06-21-2006, 12:46 AM   #2206
RCRacing.com.au's Avatar
Talking
I can't find the specs on that engine mate but i'm sure it won't have nearly 3hp and pull 44,000 rpm.
Though it is a bit cheaper.
What are they like for tuning?
Can't beat the OS for ease of tuning that i can vouch for as i also have a P5 and an LSK.
Where can i find some specs on the Nova BF21.
Might be interested in one if they are good.
Steve P
LCORCCC - Life Member
100 Cubic Inch Thumping V-Twin Victory Hammer 8-Ball!
-Stuff for sale-
CRT.5 - OS .12TZ (P) All reasonable offers Considered!
RCRacing.com.au is offline   Reply With Quote
Old 06-21-2006, 01:39 AM   #2207
Originally Posted by SpeedBump57
I'm going to have to disagree with the V-spec. IMO the best value for the money with a three port would have to be the Nova BF21 3 port at 179.00.
that engine can not compete with a v-spec
flysti is offline   Reply With Quote
Old 06-21-2006, 05:47 AM   #2208
ryan6682's Avatar
Originally Posted by arghh
anyboy experience STS D21E latest 3 port taiwan engine... is it 3 port engine increase fuel economy and can more long lasting
we will be running one of them in a week or so to see how they hold up and perform.
ryan6682 is offline   Reply With Quote
Old 06-21-2006, 07:00 AM   #2209
speedy2's Avatar
my friend has a STS B.21T on his mbx5 prospec
at 170 euro and it screams...
speedy2 is offline   Reply With Quote
Old 06-21-2006, 08:12 AM   #2210
SpeedBump57's Avatar
I didn't say it could compete with the V-spec engine for engine I said it was a better vlaue for the money. But having said that I would bet most would turn better lap times with the Nova 3 port. I got a chance to drive one of these things (the Nova 3 port) and I must say it was very impressive for $179 bucks.
I have run a V-Spec as well. It's a very fast engine with almost too much power. It always felt like it was either on or off, not very smooth at all. It's a good engine just not for me.
SpeedBump57 is offline   Reply With Quote
Old 06-21-2006, 08:53 AM   #2211
macnkitty2002's Avatar
i was about to get one of those Novarossi N1BF engines, but couldn't decide whether to spend the extra $80 rather than just get an OS RG (this would be for my backup buggy). i know that the OS RG can perform, hold a tune like no other, and last forever, but since the BF was a Novarossi, i didn't know if maybe it would perform better than the OS RG. does anybody know?
Team Associated RC10B4.2
Losi Rock Rey
macnkitty2002 is offline   Reply With Quote
Old 06-21-2006, 05:16 PM   #2212
macnkitty: i don't think you will be disappointed with the nova rossi 3 port. i've got one in my jammin and i'm still getting the pipe/header sorted out. even without the perfect combo, it's been a very nice engine so far. i bought it used with almost 2 gallons on it and everything is in good shape still. the rod is tight on the crank, the bearings are good, basically all the pinch is gone but it's TONS of compression which means it's fully broken in (from what i read). i'm going to do some pipe testing and then i'll let you know what i come up with if you like.
savageSYNTH25: ygpm!
adam lancia is offline   Reply With Quote
Old 06-21-2006, 05:55 PM   #2213
arghh's Avatar
this is 5 port factory modified engine, no wonder if it screaming..but nowdays seem every factory built 3 port engine.. what i want to know is the latest STS D21E new economy 3 port engine..
New Economy Series
Cylinder Contents : 3.48cc
Bore: 16.20mm / Stroke:16.80mm
Crankshaft : 14mm SG type
Carburetor : 2 Needles Slide 8 mm
Piston / Sleeve : ABC 3P
Glow-plug : Standard
arghh is offline   Reply With Quote
Old 06-22-2006, 09:08 AM   #2214
SavageSYNTH25's Avatar
Send a message via AIM to SavageSYNTH25
On a smaller track, the Novarossi T21BF is more than capable with hanging with a V-Spec or similar. It's a very underrated engine. The V-Spec is a great engine, if you don't want to get more than two or three gallons through it.
I had a HotMod T21BF a while back, and I loved it on a small track.
SavageSYNTH25 is offline   Reply With Quote
Old 06-22-2006, 09:11 AM   #2215
I know that feeling all too well!
The JP Modified and OSRocket versions take some of that "hit" away. In stock form, it's like flipping a switch; there's no linear feel to the throttle like you'd have with, say a WS7II.
Old 06-23-2006, 09:06 AM   #2216
DRKWNG's Avatar
The kyosho unis don't fit the rear of the jammin. They are a little long and bind when the rear shocks are extended. You can make them work by taking all the droop out but I wouldn't suggest it.
DRKWNG is offline   Reply With Quote
Old 06-23-2006, 09:56 AM   #2217
New Economy Series
Well......Considering this is an "Economy" engine, you'll more than likely get "Economy" preformance. Most economy engines are manufactured with a low cost in mind, not top performance. I'm not saying it's not a good engine, just don't expect it to run like a scalded cat.
Old 06-23-2006, 12:54 PM   #2218
Talking Engines
I don't know much about the STS Engines but I've just ordered my self a Novarossi Plus21-5T and it's definately not an "Economy Engine" and it should go like a scalded cat with a fire cracker up it's arse...
I'll let you know how it goes when i crank it over.
Has anyone tried the new alloy rear uprights yet?
What about the alloy centre diff mount?
Pics below...
There is some other groovey bits coming too for the X1 Cr & CRT.
Jammin X1 - so close yet so far-x1s-51.jpg   Jammin X1 - so close yet so far-hnalloydiffmount.jpg
Steve P
-Stuff for sale-
Old 06-23-2006, 01:37 PM   #2219
I've heard the Novarossi 21 Plus 5 and is a very impressive motor, but in every one I've seen or tuned the rear bearing hasn't lasted a gallon. From what I understand, lots of people are having this issue. No issue with the engines that are running the TKO Ceramic rear bearings though!
Old 06-23-2006, 03:19 PM   #2220
tlxxx4driver's Avatar
Ok guys and gals one question I have to ask about the x1cr.
I have the x1cr fte and I was wondering if anyone has tried the 1 degree anti-squat in the rear and if so what effects did you see in the buggy..
Plus I want to post some pics of my buggy and I don't know how to..
Team Losi 8ight
Rb
Airtronics
Byrons Race
Team Glitch
When in doubt blame your roll center
"Damm radio it is glitching again"
tlxxx4driver is offline   Reply With Quote
Jammin/Hongnor X1 - so close yet so far jono mad racer Nitro Off-Road 5 05-08-2011 06:40 AM
anybody close ????? slowpokeRRR Minnesota and North/South Dakota Racing 0 08-24-2007 10:21 PM
close please pwnzor R/C Items: For Sale/Trade 0 06-29-2007 12:40 PM
close Big B R/C Items: For Sale/Trade 0 02-02-2007 10:29 PM
please close racenut123 R/C Items: For Sale/Trade 1 04-30-2003 05:08 PM
