Jammin X1 - so close yet so far >
Old 05-17-2006, 05:36 PM
  #2041
Hong Nor makes all Jammin' buggies, just in the US they are distributed by OFNA....
IMPACTPLAYR is offline
Old 05-17-2006, 07:58 PM
  #2042
arghh's Avatar
Originally Posted by Desert Racer
Will the Hong Nor X1CR parts fit on a non hong nor X1CR buggy?
this is really very tough question...
arghh is offline
Old 05-17-2006, 09:50 PM
  #2043
SpeedBump57's Avatar
That's what I always thought. I was thinking maybe I was out of the loop!
SpeedBump57 is offline
Old 05-18-2006, 04:55 AM
  #2044
you're starting to show your age bump i called last night, no answer though. i measured it at work and got .023". sonny's going to ask john adams what it's supposed to be and then i can see if i'm in the ballpark with my measuring technique. i'll keep ya posted. no word on the buggy yet
adam lancia is offline
Old 05-18-2006, 11:58 AM
  #2045
dylan, you have more mail.
Old 05-18-2006, 05:17 PM
  #2046
.023 to .024 is what you should have to run 30%. I set my B7 at .026 durning breakin and ended up leaving it. The top end is just stupid!! but the power is very smooth kinda like running one of my older WS7's.
Old 05-19-2006, 08:20 AM
  #2047
macnkitty2002's Avatar
i don't change the shimming on any of my motors and i run 33%!
macnkitty2002 is offline
Old 05-19-2006, 09:46 AM
  #2048
Tabushi's Avatar
Guys,
As you may know i mounted the Jammin FTE and tomorrow i will throw it into a small local track just to test everything before the Mexican Nationals next week ... so far i have this questions :
1.- Front Sway Bar : Man this thing seems to be very weak and even with 5mm of preload it does nothing on the suspension . The rear works ok. Any tip on this ?, any aftermarket recommended sway bar set or just buy another Jammin rear sway bar and put it on the front ? (2.8mm right ?).
2.- Shocks : This big bore ones are great, but i have a question about the front shocks cause even when they feel smooth and all, i feel that it bottoms up on the rubber dust cover and im afraid that on big jumps it will destroy the rubber boot when the suspension works on full movement.
Any opinion on this issues ?,
Thanks a lot ...
Tabushi is offline
Old 05-19-2006, 10:01 AM
  #2049
when you rebuild your shocks, put a small piece of fuel tubing at the bottom of the shaft so if you bottom out, no harm will come to the seals.
Old 05-19-2006, 12:40 PM
  #2050
anyone have a pro or fte version of the buggy for sale? i'm back in the market for one, seller backed out on my previous deal. any info post here or pm/email me. thanks,
adam
Old 05-19-2006, 01:19 PM
  #2051
Davidka's Avatar
Trader Rating: 86 (100%+)
I have read that the best attribute of the Jammin's suspension is the extra up travel that makes it so forgiving in the rough. I don't think it would be a good idea to take any of that travel away.
Davidka is offline
Old 05-20-2006, 10:40 AM
  #2052
i don't mean a lot of fuel tubing, maybe just 1/8 of an inch or a little more.
Old 05-20-2006, 11:14 AM
  #2053
David- tabushi had a concern with damaging the dust condoms and Mac gave a reasonable and easy solution.....
Old 05-20-2006, 04:28 PM
  #2054
the chassis will bottom out before the shocks are fully compressed, so he won't lose any performance.
Old 05-21-2006, 05:56 PM
  #2055
Tabushi's Avatar
Default First Track Test
Well, in the city im living in México a local hobby shop just built an offroad track so i took my Jammin FTE and STS .21T for the first track test prior to the Mexican Nationals next week (man, 10 hours in Bus ).
The track its already mounted but without internal divisions so people have to run very carefully, the divisions will be made next week prior to the first race. Not water on the track neither so a lot of dust flying around + local MT guys running without any order, anyway, i had fun and tested my equipment, im very happy with the results, specially about the STS .21T engine which never went over 205ºF and was flying ... enjoy :
- Video 1 : http://images.domino.org/d/55764-1/2...oConcha_01.wmv
- Video 2 : http://images.domino.org/d/56177-1/2...oConcha_02.wmv
- Video 3 : http://images.domino.org/d/56180-1/2...oConcha_03.wmv
- Video 4 (final "oops" included) : http://images.domino.org/d/56391-1/2...oConcha_04.wmv
BTW, not bad for stock tires
thanks for your help guys, i will asking you here a lot this week prior to the nats ...
BTW : All the videos are 55mb in average (480x360 pixels), so take you time to download them ...
cya !
Tabushi is offline
