Old 05-12-2006, 07:30 PM   #1996
SavageSYNTH25's Avatar
Send a message via AIM to SavageSYNTH25
Yep, sure did.
YGPM
SavageSYNTH25 is offline   Reply With Quote
Old 05-13-2006, 06:56 PM   #1997
ryan6682's Avatar
I havent read thru this entire thread, but has anyone had any tank pressure problems with the fuel tank , I cant find any leaks and all seems well but if I am not constantly on the throttle like if I decide to roll a couple jumps cause I am a crappy driver I stall out or motor starts to blubber and sometimes can be saved by feathering the throttle. I have tried several things and cleaned and sealed the carb and all that, it just seems like the tank doesnt hold enough pressure when I am not on the throttle.
ryan6682 is offline   Reply With Quote
Old 05-13-2006, 06:58 PM   #1998
have you checked to see that the idle isn't too low? is the clutch in good working order? no broken springs, worn out clutch shoes etc...?
adam lancia is offline   Reply With Quote
Old 05-13-2006, 07:33 PM   #1999
Tabushi's Avatar
Send a message via AIM to Tabushi Send a message via Yahoo to Tabushi
Take a look on the offroad forum, just posted with the title " Im ready for the 2006 offroad season (pics) "
cya !, and thanks for your help guys !
Patricio "PATO" Concha
E-Mail : pato_concha@yahoo.com
Facebook : http://www.facebook.com/patoconcha
Whatsapp : +56 9 66165085
Tabushi is offline   Reply With Quote
Old 05-13-2006, 07:57 PM   #2000
SpeedBump57's Avatar
Ryan I believe that if you were lossing pressure in you fuel tank you would be going lean on the bottom and not fat. Sounds to me like you are off a little on your tune and a little fat on the bottom and have you idle set a little to low. Other things to check would be bad clutch bell bearings or broken springs like Adam sugested.
SpeedBump57 is offline   Reply With Quote
Old 05-13-2006, 07:59 PM   #2001
ryan6682's Avatar
clutch is a new fioroni 4 shoe adj clutch. I have it set pretty stiff for good take off so I dont think it is the clutch.
I went out in the street and just ran the dogcrap out of it doing a mix of high rev and allot of mid throttle stuff. I may have fixed it as it didnt stumble or die once but I guess i wont know for sure till I try it on the track. I think I may of had something blocking the nipple on the pipe.
Old 05-13-2006, 08:02 PM   #2002
I hate when something blocks the nipple.
come back if it's not fixed...............
Old 05-13-2006, 08:03 PM   #2003
By the way good choice on the clutch.
Old 05-13-2006, 08:18 PM   #2004
ryan6682's Avatar
are you running this clutch??? what spring and shoes are you using if you are??
I am running the med spring turned in about 4 turns and 2 black and 2 white shoes
Old 05-13-2006, 08:29 PM   #2005
Nope can't say I have, yet! I have been running the turbo slider for about two years now and love it. I just had one fail last week but it had more than six gallons on it with the same shoes, got a set of new shoes comin'.
Old 05-14-2006, 04:54 AM   #2006
Montrealer's Avatar
So does Janet Jackson...
By the way, I received the 2600mah packs and they fit just right in the Jammin's radio box. I just had to cut the cross member that separates de radio from the battery enclosure and Voila !
Montrealer is offline   Reply With Quote
Old 05-14-2006, 06:12 AM   #2007
Lol....
The 2600 pack would've fit without cutting the crossmember. All you had to do was remove the entire top of the radio box.
Old 05-14-2006, 06:25 AM   #2008
Montrealer's Avatar
Originally Posted by SavageSYNTH25
Lol....
I see, but I will swap packs from time to time and I don'T want to unscrew the to every time. Thanks for the tip though.
Old 05-14-2006, 06:31 AM   #2009
Old 05-15-2006, 05:02 PM   #2010
I have a Jammin X1CR pro kit and I would like to know what do I need to make it a FTE version?
Thanks Cody
Desert Racer is offline   Reply With Quote
Jammin/Hongnor X1 - so close yet so far jono mad racer Nitro Off-Road 5 05-08-2011 06:40 AM
anybody close ????? slowpokeRRR Minnesota and North/South Dakota Racing 0 08-24-2007 10:21 PM
close please pwnzor R/C Items: For Sale/Trade 0 06-29-2007 12:40 PM
close Big B R/C Items: For Sale/Trade 0 02-02-2007 10:29 PM
please close racenut123 R/C Items: For Sale/Trade 1 04-30-2003 05:08 PM
