Old 05-03-2006, 11:53 AM   #1906
Drake and Waldron for sure, and anyone else who is currently sponsored by losi I would imagine will have to start running the losi car.
Mike Elam is offline   Reply With Quote
Old 05-03-2006, 01:41 PM   #1907
xlgraphicspro's Avatar
Originally Posted by Mike Elam
the main big driver that will be going losi is drake, but you look Chad Bradley and Taylor James both are big hitters in the gas world and will do very well this year and next. I agree top drivers can win with any top car (mugen, kyosho, ofna, losi. whichever car they run they will be fast. here is something to think about that could also affect drivers in many camps not just jammin, I have heard from a sponsored ae guy that team associated is working on a 1/8th scale buggy. Now I was like why would they do that beings them and thundertiger are together. but this guy says that is what he has heard from ae. now whether this is all true or not we will all have to wait and see.
It makes sense that Associated would make their own car aside from thundertiger.
Losi is owned by horizon, who also owns sportwerks. But the losi has nothing in common with the mayhem, or even with sportwerks new 1/8th buggy!
Just because Thunder tiger owns Associated, doesn't mean they will eventually meld as one.
Now, if in the process of selling out, if all of associateds designers were kicked to the curb, and thunder tigers designers were put in their place, yeah, they would be similar. Then it wouldn't make sense!
TeamXray RCAmerica Hudy Xlgraphicspro Paint/ Impulse-Rc Clutch shoes.
Xray XB 808 O.S. Speed Or Ninja JX
xlgraphicspro is offline   Reply With Quote
Old 05-03-2006, 09:15 PM   #1908
ryan6682's Avatar
well guys tomorrow will be my first race with the jammin. and my first race that I have ever driven in. Hope all goes well. thanks micros for the buggy this should be allot of fun. I went with a 14t cb with a fioroni 4 shoe adj clutch with an STS .21B motor and STS pipe . The suspension is the same as micros had it . I figured I would try that before making any changes .
wish me luck
ryan6682 is offline   Reply With Quote
Old 05-04-2006, 05:01 AM   #1909
macnkitty2002's Avatar
14t seems a little high t me, but you might have a big track.
Team Associated RC10B4.2
Losi Rock Rey
macnkitty2002 is offline   Reply With Quote
Old 05-04-2006, 05:05 AM   #1910
Trader Rating: 50 (98%+)
Send a message via AIM to micrors4guy
ryan- if you can change the oil in the rear shocks. last time i went too soft and it was bottoming out on the jump faced making the rear end kick over the front. try putting 40 or 45 in the rear.
Rob Jensen
Thanks to the following companies for their support in 2017: Team Associated, Maclan, Fierce R/C Solutions
micrors4guy is offline   Reply With Quote
Old 05-04-2006, 05:20 AM   #1911
ryan6682's Avatar
I might have some time to change out the oil, thanks for the tip.
about the 14tcb I cannot get a smaller bell to work, I dont know if its the brand or what but the 14t pushed over as hard as I can doesnt give me all that good of mesh with the spur. any smaller would be to loose. I am using a racers edge cb and the one peice ofna motor mount. I even used a screwdriver up thru the starter wheel slot to to pry and hold the engine over.
Micros said he used a 13t and the wear pattern on the spur looks good but I dont know how I can get it any closer than it is. I am taking it to work with me today I work in an auto shop and I may make the slots a little longer to get it where I want it. the track is actually kinda small so I really was hoping to run a 13t or even a 12t
Old 05-04-2006, 05:38 AM   #1912
use the jammin clutch bells, i'll bet they will fit. but dremel the slots in the chassis where the engine mount screws go through to give you a tighter spur mesh.
Losi Rock Rey
Old 05-04-2006, 02:39 PM   #1913
dido41's Avatar
does the jammin buggy use the hump pack or stick pack for the receiver. if both what is the better one to use?
dido41 is offline   Reply With Quote
Old 05-04-2006, 02:48 PM   #1914
SavageSYNTH25's Avatar
Send a message via AIM to SavageSYNTH25
Hump pack.
If you're not using Li-Po's, I would suggest a high capacity pack especially if you are using digital servos. Carolina's R/C has one manufactured by Team Helotes, a nice 2600mah.
Here's a link:
Carolinas RC.com- 2600mah pack
SavageSYNTH25 is offline   Reply With Quote
Old 05-04-2006, 03:36 PM   #1915
dido41's Avatar
thanks savage. my receiver has a voltage range from 4.8 to 6v do they make a lipo battery for the receiver in that range
Old 05-04-2006, 05:33 PM   #1916
no, you'll have to get a converter or something.
Losi Rock Rey
Old 05-04-2006, 05:46 PM   #1917
dido41's Avatar
thanks i will stick with th hump pack. just ordered the 2600mah
Old 05-04-2006, 05:52 PM   #1918
Good choice.
The "Converter" macnkitty was referring to is actually a voltage regulator. Some Li-Po packs provide around 7.4 volts of power, and this can easily fry most servos. The regulator safely drops the voltage down to 6.0. The great thing about Li-Po's are that they provide CONSISTENT voltage until they start to dump off. Instead of bouncing from 5 to 6 volts like a standard receiver pack, the Li-Po (in conjunction with the regulator) will sit at a constant 6.0 volts. This means less voltage spike in the electrical system and more consistent servo movement.
Whew......Hope I explained all that right!
Old 05-05-2006, 04:30 AM   #1919
sounds right to me. how long does the 2600mah pack last?
Losi Rock Rey
Old 05-05-2006, 05:16 AM   #1920
RCRacing.com.au's Avatar
Cradock Brakes on X1 CR
Has anyone got any pointers on how to set up the Cradock Anti Lock Brakes on the X1 CR?
I've put mine on with bear metal pads but the screws are too long and hits the spur gear on one side and the sit off ongle on both sides when the brakes are pulled on.
If you can send me some pics that would be cool as i really want to get these brakes working as i've heard they are the bomb!
Cheers
Steve P
LCORCCC - Life Member
100 Cubic Inch Thumping V-Twin Victory Hammer 8-Ball!
-Stuff for sale-
CRT.5 - OS .12TZ (P) All reasonable offers Considered!
RCRacing.com.au is offline   Reply With Quote
Jammin/Hongnor X1 - so close yet so far jono mad racer Nitro Off-Road 5 05-08-2011 06:40 AM
anybody close ????? slowpokeRRR Minnesota and North/South Dakota Racing 0 08-24-2007 10:21 PM
close please pwnzor R/C Items: For Sale/Trade 0 06-29-2007 12:40 PM
close Big B R/C Items: For Sale/Trade 0 02-02-2007 10:29 PM
please close racenut123 R/C Items: For Sale/Trade 1 04-30-2003 05:08 PM
