Old 04-27-2006, 05:46 AM   #1846
SpeedBump57's Avatar
yamrace,
I have seen a few different standard setups for Chad. It would be helpful if you posted your complete setup. I genreal these things will calm down the rear end.
Go to 2k or 3k in the rear
rear camber link long and in lower hole on tower
More rear toe
Less antisquat
Softer rear springs and lighter oil.
Smaller rear sway bar
Shorter wheel base
SpeedBump57 is offline   Reply With Quote
Old 04-27-2006, 08:00 AM   #1847
yamrace's Avatar
First thing, I like a ton of steering, alot more than most people and I wish that the car had more steering. My racing experience has been touring cars and 12th scales on carpet and last fall I started race electric off-road indoors, (B4,T4,BJ4) on a very high bit dirt track. So one thing I do not want to do in take steering away. It seem to me like the rear is trying to pass the front on power. I want the front end to pull the car out of the corner when I pick up the throtle.
Here in the rear setup. X1-CR Factory Team Kit
Red Springs with losi 40 Oil, stock pistons, mounted middle top on tower and inside on arm.
Long wheel base, 3 degrees of toe, 2.5mm sway bar, antisquat ? what is the stock plate, I can't find a listing for it.
camber link is outside on hub and middle inside on tower.
Diff fluid is 3K front, 5K middle and 1K Rear
Thanks Guys
yamrace is offline   Reply With Quote
Old 04-27-2006, 08:47 AM   #1848
macnkitty2002's Avatar
three isn't too thin?
Team Associated RC10B4.2
Losi Rock Rey
macnkitty2002 is offline   Reply With Quote
Old 04-27-2006, 08:55 AM   #1849
Trader Rating: 50 (98%+)
Send a message via AIM to micrors4guy
if you want the front end of the car to pull harder and the rear to stay planted try 4/4/3 diff oils. this should put more power to the front of the car giving it that pull and the 3 in the rear will keep it planted threw the corner.
Rob Jensen
Thanks to the following companies for their support in 2017: Team Associated, Maclan, Fierce R/C Solutions
micrors4guy is offline   Reply With Quote
Old 04-27-2006, 09:52 AM   #1850
DRKWNG's Avatar
I would put 3 in the rear diff, I would also go a little heavier in the middle like 5 or 6, lighter springs, and go to a lighter sway bar. You can also drill the new camber position in the rear shock tower and move the link to the inside hole on the hub.
Then again, if you just started racing off-road all I would do is change the rear diff fluid and race the car for a couple weeks before I toughed anything else.
Good tires can make all the difference in the world in the traction department.
DRKWNG is offline   Reply With Quote
Old 04-27-2006, 10:17 AM   #1851
that's right, tires are 90%, the car does the rest.
Losi Rock Rey
Old 04-27-2006, 06:29 PM   #1852
arghh's Avatar
Originally Posted by macnkitty2002
we are talking about the steering brace, which is that carbon fiber plate that connects the front gear box to the two steering posts.
the plate that you might be confusing it with is the bellcrank plate, which connects the steering posts to the tie rods, and it has three ackerman holes in it too.
steering brace?? front top plate?? front plate?? front brace??
bellcrank plate?? ackerman plate?? steering rack??
man..i'm getting confuse..is this all their right name..different people give different name for the same part..why not use standard name that the factory have given on manual book..
arghh is offline   Reply With Quote
Old 04-27-2006, 07:09 PM   #1853
they are all the same thing. it's this.
http://www2.towerhobbies.com/cgi-bin...?&I=LXLMY0&P=7
again, all the same thing. it's part #40607 here.
http://www.jamminproducts.com/x1croption.htm
does this clear things up?
Losi Rock Rey
Old 04-28-2006, 07:23 AM   #1854
DRKWNG's Avatar
Has anyone tried the M3 compound Crimefighers yet? I usually run M2's but one of the local pros said the M3's hook up better on a dry dusty track.
Does anyone have the new ackerman plate? Is there any difference from the old one except looks?
Old 04-28-2006, 10:31 AM   #1855
there's no point in getting it because no one ever breaks an ackerman plate.
Losi Rock Rey
Old 04-28-2006, 12:20 PM   #1856
D_Ames's Avatar
Send a message via AIM to D_Ames
They don't break the ackerman plate, they bend it. That breaks the flange off the bearing. The new ackerman plate is much stiffer and won't bend. No bearing issues anymore.
D_Ames is offline   Reply With Quote
Old 04-28-2006, 06:56 PM   #1857
SavageSYNTH25's Avatar
Send a message via AIM to SavageSYNTH25
The M3's grip very well when the track is packed in, but there really only work good if there is a little moisture in the dirt. Once the track starts drying out bad and "grooving", the M3's roll over pretty bad. If you're running on a track like this with the M3's, I'd suggest running a 2.0-2.5 rear block to loosen the rear end up some. I've found that the M2's are dialed in most places- the M3 is kind of iffy on some tracks.
The new Ackermann plate is CNC'd (I believe) and a bit thicker, removing flex and keeping the ackermann straight. It also may have less bump steer, I don't know. I don't drive my car hard enough to bend the ackermann. One fix I have found is to run Kyosho rubber sealed (flangeless) bearings and a shim with a larger O.D. than the bearing instead of the stock flanged bearings. That way, if the ackermann does flex some, the flange doesn't break. Just a thought.
SavageSYNTH25 is offline   Reply With Quote
Old 04-28-2006, 09:09 PM   #1858
arghh's Avatar
they are all the same thing. does this clear things up?
i know.. what i mean is use part name as the factory given.. so there's no 3 or 4 name for a same part..
Old 04-28-2006, 09:46 PM   #1859
Thanks Guys
Try the 3.5 block (if you have one) and the thin rear swaybar.
Also, running a shorter wheelbase would tighten the rear of the car up. The longer wheelbase along with less toe will free up the rear end, causing it to get squirrely on power or when landing.
Old 04-29-2006, 10:15 AM   #1860
hey guys,
i just got my King Heads upper steering brace ( ) and it came with the plate itself and another little peice with 2 large holes and 1 small hole drilled in it. what is this extra peice for? do you put it under the plate at the forward gear box screws to give it more clearance? does anybody else have this part and could give me an explanation?
here's what i'm talking about, it's that little peice.
http://www.carolinasrc.com/Webstore/...idproduct=1399
Losi Rock Rey
Jammin/Hongnor X1 - so close yet so far jono mad racer Nitro Off-Road 5 05-08-2011 06:40 AM
anybody close ????? slowpokeRRR Minnesota and North/South Dakota Racing 0 08-24-2007 10:21 PM
close please pwnzor R/C Items: For Sale/Trade 0 06-29-2007 12:40 PM
close Big B R/C Items: For Sale/Trade 0 02-02-2007 10:29 PM
please close racenut123 R/C Items: For Sale/Trade 1 04-30-2003 05:08 PM
